Old 12-09-2012, 02:33 PM   #1
Usmcpilot OP
Ready to Ride
Oddometer: 60
I used the wrong oil filter
Ok, here's a good one. I was completing the annual maintenance on my 2011 R1200GSA and opened the box with the oil filter only to notice that it was the filter for my 2000 R1200C. This was a big disappointment as I don't have another filter and the nearest BMW dealer is about 3 hrs north in San Antonio. I decided to give it a try and low and behold, it fit. It is the same thread and diameter but a little taller than the one for the GS. It doesn't leak and seems to work perfectly.
So here's the question. Is there any reason that I should be concerned with using the R1200C filter on my GS temporarily until i can get the correct filter on the bike. The only thing I could think of is that there might be some difference in the flow rate of the oil between the two bikes but that seems very unlikely.
Thoughts.
Please be kind. This is not my first oil change and I have never made this mistake before.
Usmcpilot is offline   Reply With Quote
Old 12-09-2012, 02:42 PM   #2
LaurelPerryOnLand
Oddometer: 3,478
If it doesn't leak...shouldn't be a problem...so order your other 'correct' one and you'll be good.
BTW..."cleared to land...taxi to the ramp".
PS...don't do it again or we'll "Aircraft on Ground" your aircraft.
LaurelPerryOnLand screwed with this post 12-09-2012 at 03:39 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 12-09-2012, 03:01 PM   #3
baloneyskin daddy
bikaholic
Oddometer: 2,103
Don't let BMW find out, They'll void your warranty.
baloneyskin daddy is offline   Reply With Quote
Old 12-09-2012, 03:05 PM   #4
johnny80s
johnny80s's Avatar
Oddometer: 250
It is too late. We are watching you...
johnny80s is offline   Reply With Quote
Old 12-09-2012, 03:08 PM   #5
Usmcpilot OP
Ready to Ride
Oddometer: 60
I don't tell the dealer anything. I try not to ask them much either. Most of the time I find their advice misleading or just plan wrong.
Old 12-09-2012, 03:08 PM   #6
Usmcpilot OP
Ready to Ride
Oddometer: 60
Damn, busted!!!!!
Old 12-09-2012, 03:14 PM   #7
Hikertrash
Oddometer: 2,834
As long as your bash plate still mounts, it should be ok. In the FAQ, they list a Dodge Neon filter for the 1200GS, but its too long for aftermarket bash plates. I've been buying the K&N filters off of Amazon for $15 and I see Touratech now carries them for the same price. No special wrench needed for them either. They use a socket for removal.
Hikertrash is offline   Reply With Quote
Old 12-09-2012, 03:16 PM   #8
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,694
If it fits and there isn't any interference with the skidplate, replace it when you do the oil next.
If there is interference, refrain from riding anything too gnarly until you can get the proper length filter fitted.
If you're all about the destination, take a fucking flight.
Twilight Error is offline   Reply With Quote
Old 12-09-2012, 03:40 PM   #9
Usmcpilot OP
Ready to Ride
Oddometer: 60
The skid plate does fit so I guess I will keep it until the next oil change. Thanks for the tip on the K&N filters on Amazon. I will order some tonight.
Old 12-09-2012, 03:47 PM   #10
LaurelPerryOnLand
Oddometer: 3,478
K&N-164 are the ones. $10.98 at that River place.
LaurelPerryOnLand screwed with this post 12-09-2012 at 07:54 PM
Old 12-09-2012, 04:18 PM   #11
Wild Pig
Looks like avatar.
Wild Pig's Avatar
Oddometer: 86
I've got that same K&N on my 1150RT, 1200GS, and 2003 4Runner.
Makes buying in bulk easier!
Jim
"You pass through places, and places pass through you."
Wild Pig is offline   Reply With Quote
Old 12-09-2012, 04:30 PM   #12
Usmcpilot OP
Ready to Ride
Oddometer: 60
Looks like they want $24.44 now. Any links to the $15.00 ones?
Old 12-09-2012, 04:38 PM   #13
t6pilot
Oddometer: 549
Check with Beemer boneyard,
Think I got a dozen for about $15 each shipped, including new washer. These were BMW filters not aftermarket
t6pilot is offline   Reply With Quote
Old 12-09-2012, 05:30 PM   #14
vipergeek
Oddometer: 3
K&N-164 $14.99 at Cycle Gear on-line.
vipergeek is offline   Reply With Quote
Old 12-09-2012, 05:37 PM   #15
Phat
Oddometer: 55
Final drive will fail for sure now. Good luck with warranty work
Phat is offline   Reply With Quote
Times are GMT -7.   It's 05:37 AM.
