Old 12-09-2012, 07:51 AM   #1
brittrunyon OP
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 534
Starter Hang-up
I have a Nippondenso starter in a '92 GS that I installed in 2007, 25k miles ago.
With the change in the weather, that is Winter, and the cold morning starts, the starter engages but seems to hang-up in that position for a few seconds.
When the bike or the outside temperature is warm it's starts normally.
Is this a sign of shelling out $ for a new starter?
Or might it just need a good cleaning?
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 12-09-2012, 07:54 AM   #2
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
Clean and grease the bendix gear.
bmwblake is offline   Reply With Quote
Old 12-09-2012, 08:39 AM   #3
motosavant
Master Lurker
motosavant's Avatar
Oddometer: 5
Yep,that should do it.If not,I'll be glad to have a look at it.
Don't question authority-they don't know,either.
motosavant is offline   Reply With Quote
Old 12-09-2012, 08:43 AM   #4
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 534
So I know I can clean & grease the bendix gear (engages with fly wheel) without disassembling the starter, that's easy.
But should the investigation go a step further?
I found this link http://advwisdom.hogranch.com/Wisdom...ng_starter.pdf but thats a Valeo starter.
1992 R 100 GS (ZED)
2007 F 650 GS
Old 12-09-2012, 10:53 AM   #5
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,233
After 6-7 years of operation it might be a good idea to disassemble, inspect, clean and lubricate the starter.
--Bill
'73 R60/5 Toaster
Old 12-09-2012, 12:24 PM   #6
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
i agree. my earlier comment was more directed at the portion of the gear that is inside the housing, not just the external bendix gear. you can see the internal part that twists when the start engages the flywheel in page 7 of the pdf you linked at the top of the page.
the pdf is for a valeo, but the ND starter is very similar, at least to an airhead valeo. the one for the 1150gs appears to be a bit different.
--Bill
Old 12-10-2012, 07:27 AM   #7
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 534
Thanks for the offer!
.....but I going where I've never gone before........... inside my starter.
My first question, is there printed assistance (other than the afore mentioned pdf) for the uninformed about dismantling, inspecting & cleaning a Nippondenso starter?
1992 R 100 GS (ZED)
2007 F 650 GS
Old 12-10-2012, 11:46 AM   #8
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
if you folllow the directions in the clymer manual for taking apart a valeo that was fitted to airheads you'll be pretty close. otherwise see if rick at ME has directions that are specific to the ND starter.
Times are GMT -7.   It's 08:37 PM.
