Old 12-24-2012, 11:24 AM   #16
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Originally Posted by atomizer View Post
Thank you. Hoping it will survive my trip till I get back to work on it. Could you post the link again to your thread that describes the symptoms? The one you posted below just links back to this Thread. Thanks again...
Fixed http://advrider.com/forums/showthread.php?t=801192
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-24-2012, 11:32 AM   #17
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,582
direct link to the thread with detailed instructions on making a LC8 sprag from LC4 sprag.
http://www.advrider.com/forums/showp...5&postcount=17
You will need a big breaker bar or pneumatic impact to get the crank bolt loose, then a grub screw (to push against) and a puller (pusher bolt really) to push the flywheel off the crankshaft taper, then you can get to the sprag.... will also need 648 loctite for reassembly.
If you dont have the parts available, in a pinch and IF you can get the flywheel off... you can tighten the perimeter spring on the sprag to put more preload on the sprag pals... but this is only work around to the probably required replacement of the pals and the spring.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 05:19 AM.
