Old 12-09-2012, 12:55 PM   #1
Steve in Santa Fe OP
Steve in Santa Fe
Oddometer: 15
Talcum tubes
Having just spent the better part of an hour levering off a Michelin Anakee rear (hooohaaah those babies don't want to give it up), I am reminded of a trick bicycle racers use.
When installing a new tube, they rub it down with talcum powder...make is easier to install, position and remove. Plus it tends to make the tire less inclined to 'grab' the tube and spin it if pressures are low.
I am going to give it a run, as I had quite a time getting the tube out of this beast.
Steve in Santa Fe
1980 BMW 100RT
2005 DR 650
Steve in Santa Fe is offline   Reply With Quote
Old 12-09-2012, 12:59 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,521
I put a few squirts of the talcum powder in the tire and rotate it to spread the talc before mounting the tire to the rim.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-09-2012, 01:03 PM   #3
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,359
Old bicycle mechanics trick. Cuts down on snakebite flats as well. Use good stuff, 100% cornstarch powder, talc tends to clump while cornstarch does not.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 12-09-2012, 01:38 PM   #4
MagyarMan
MagyarMan's Avatar
Oddometer: 692
Caution: cornstarch can explode under the right conditions---no smoking!
MagyarMan is offline   Reply With Quote
Old 12-11-2012, 02:11 AM   #5
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,632
I have a big garbage bag with talc in it. Before fitting the tube, put it in the bag, hold closed but with lots of air in it so the tube has room to tumble as you gently shake it. Carefully remove the tube to avoid clouds of talc escaping. Loosely tie the bag between uses.
Insert the tube without the valve core. After fitting the tyre, inflate the tube to 10 psi then deflate again. This will untwist the tube and let it position itself. Fit the valve core and inflate to seat the bead then drop to required pressure.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 12-11-2012, 05:43 AM   #6
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
Deserving of an entry in the Shop Tips and Tricks Thread.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 12-11-2012, 09:05 AM   #7
Velociraptor
TrackBum
Oddometer: 1,128
I always do that. Also spray soapy water on the bead so the tire will slide down into the rim on the opposite side of where you are levering the tire off the rim. Makes life so much easier. Works for tubes and tubeless tires.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Times are GMT -7.   It's 03:18 AM.
