01-22-2013, 01:28 AM
#1 |
Oddometer: 482
I'm thinking I want to use Mobil 1 in my 1979 R100RT engine but not sure if I should use Mobil 1 15W50 (auto) or Mobil 1 V-Twin 20W50 (motorcycle)?
There's a lot of chatter over on the oilhead side, but search comes up with nothing on the airhead side about either Mobil 1 oils. So, any airhead owners using Mobil 1? If so, are you using Mobil 1 15W50 designed for cars or Mobil 1 V-Twin 20W50 designed for motorcycles? I know the Mobil 1 V-Twin 20W50 has stuff in it for engines that have common crankcases for engine/trans/wet clutch, like my Honda's and Suzuki's have, but the airhead engine does not share it's crankcase with the transmission and it has a dry clutch so it seems that the Mobil 1 15W50 designed for car engines would be the logical choice here. Then there's the whole 15W50 vs 20W50 thing... Anyone? Anyone? Bueller? ![]() TINK |
01-22-2013, 01:39 AM
#2 |
Oddometer: 1,002
I'll dive in.......
You want an oil suitable for flat tappet OHV engines not fitted with catalytic converters. Such oils come with plenty of ZDDP an additive used until quite recently in oils but taken out because it does not work well for catalytic converters. I use a Valvoline VR1 20-50 oil marketed towards use in classic racing cars and bikes. It contains ZDDP. It's a mineral oil. API SL Oils available in your country will vary and castrol 20-50 sold in Europe is probably formulated differently that Castrol 20-50 sold in the US.
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback chasbmw screwed with this post 01-22-2013 at 02:14 AM |
#3 |
Oddometer: 84
Hello !
Your bike has a separate gearbox. So it is more like a car than another bike. (there are some cars with the gearbox in the same box as the engine but they are the minority). But, I for one, disagree with synthetic oil in an airhead (and in an oilhead too). These oils have trouble conforming to the maximal viscosity (the 50 figure). So they often fail when we need them : when it's hot and we ride hard... (you can check this by comparing the viscosity of hot 15W50 synthetic and 20W50 mineral oil. The latter being more viscous than the former... ) Last but not least, BMW warn against using API SJ and above oils in an airhead because these oils lack a lot of additives which are very useful in an airhead designed a long time ago with the metal of the era. Metals used in today's cars are very different.... so oil needs are very different too. I would stick to a car oil from mineral base 20W50 viscosity rated API SF~SG or SH as BMW advised to use... And this will save a lot of money too... |
01-22-2013, 05:23 AM
#4 |
Oddometer: 35
There is insignificant difference between Mobil 1 15w-50 and Mobil 1 20w50 currently available as shown by published graphs. i have been using Mobil 1 15w50 in seven of my air cooled motorcycles since it was available. I recently switched my 83 R100 over to it after a top end overhaul. This oil is a great choice and will do well in your BMW .Change your oil and filter at the prescribed intervals and ride knowing your motor is protected.
01-22-2013, 05:47 AM
#5 | |
OH.THAT'S GONNA HURT
Oddometer: 3,814
+20 on this!!!!!! From what I've experienced with Cast 20w50 auto oil in one old car, trashed cam and tappets, I will always use oil with ZDDP in old cars or the airhead!!! The ZR1 gets high marks, synthetic is not needed especially when changing oil every 3,000 miles. Yeah I know you can extend the oil change interval with synthetics, but I have problems getting past that...5-7,000 mile oil changes I just can't bring my self to do that!!! But it's your bike and money do what you want....
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) One Less Harley screwed with this post 01-22-2013 at 05:52 AM |
#6 |
ShadeTreeExpert
Oddometer: 4,992
I'm a believer in the ZDDP additive for my Airhead. I have seen pictures of other rider's bikes that have pitted cam lifters and cam shafts. This is usually where the problem starts and a common factor when this is reported is the oil that was used. The most well intentioned think they are doing the right thing by using a motorcycle oil or using Synthetic oil. I stay away from motorcycle oil and Synthetics and I use an oil that I know has ZDDP in it.
I'd like to know how much ZDDP is in the oil that Chas BMW uses. He's on top of stuff but I don't know where to get these figures. How does it compare to BMW Brand motor oil? BTW that's what I use because I'm sure it has enough ZDDP in it. Of course BMW has different oils for their different vintage bikes. They have one specifically for Airheads. And it's Dino Oil. It's 20W50. I really like something a little cheaper though.
Never memorize something you can look up. ---Albert Einstein |
01-22-2013, 07:05 AM
#7 |
call me iggy
Oddometer: 600
Is this the first oil thread of this winter season? Took a while didn't it?
But I don't have a dog in this fight, since I just use BMW 20w50, but I thought the ratings for motorcycles were API/SAE SJ and JASO MA. I'll verify what's on the BMW bottle when I get home tonight. *EDIT* well, whaddya know, it's SG
Current: 93 R100GS, 04 XR650L Prior: 73 CB350, 77 R100/7, 83 R100RTI love every motorcycle I've owned and even some that I haven't. ignatz72 screwed with this post 01-29-2013 at 06:08 PM |
01-22-2013, 07:22 AM
#8 |
Wannabe rider
Oddometer: 1,308
I love Mobil 1 and have not run anything else in any of my motorcycles (or vehicles for that matter). But I've read enough now about airheads and the reasoning to go with "older" dino oils with higher ZDDP contents that I have been swayed.
I found this interesting response from Pennzoil while searching info on oils. It gives PPM (part per million) ratings on various API oil ratings (SH, SJ, SL, etc). http://xs650temp.proboards.com/index...y&thread=14648
"We are very good at preparing to live, but not very good at living." -Thich Nhat Hanh 1973 BMW R60/5 |
01-22-2013, 07:32 AM
#9 | |
Oddometer: 1,002
Well if you want the best of both worlds try 1 guart of Valvoline VR1 20-50 1900 or so ppm Zddp and 1 quart Rotella T 15/40 maybe 1300 ppm zddp mixed......ah wtf......xsjohn
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
01-22-2013, 07:34 AM
#10 |
Oddometer: 482
Castrol 4t
Now for something completely different...
What about Castrol 4T, anyone using this? It's an old school mineral base SG oil. TINK |
01-22-2013, 07:43 AM
#11 |
So much to ponder
Oddometer: 2,551
Best part about this thread is that Tink is finally getting his bike finished. Can't wait to see it at the next OC vintage meet.
Originally Posted by DR. Rock once you leave the pavement, it's like entering a parallel universe... a wormhole in both space and time... sometimes you won't believe you're still in the United States, or in this century. |
01-22-2013, 08:03 AM
#12 | |
Oddometer: 482
Clear prop!
#13 | |
Oddometer: 234
Andy 2009 BMW R1200RT 1981 BMW R100RS 2006 KLR 650 |
01-22-2013, 08:11 AM
#14 |
NED
Oddometer: 315
In the winter I use Rotella 15w40 - 20/50 otherwise. Once I rebuld this engine I may go to synthetic, however conventional has done just fine. My 2 pennies.
01-22-2013, 08:44 AM
#15 |
ridetowork
Oddometer: 350
Mobil 1 1-w-50 or 20w-50
I have used Mobil 1 15w-50 and the Mobil 1 motorcycle 20w-50 which Mobils markets as V twin, for Harleys. I found that the 20w-50 is quieter than the 15w-50. Some airhead gurus on the airlist do not like the car 15w-50 Mobil1.
Form the Mobil website: "Mobil 1 V-Twin 20W-50 motorcycle oil will help provide excellent performance in motorcycle engines that are designed with a common engine/transmission lubrication system or where the engine lubrication system is separate from the transmission system. In the case of the latter, follow the manufacturer's recommendation for the type of fluid to be used in the transmission. It is also designed to help provide the proper frictional characteristics necessary for wet-clutch engine/transmission systems."
motocicletta Santa Monica, CA '88 R100GS |
