Go Back   ADVrider > Riding > Mapping & Navigation > GPS 101 - Which GPS For Me
Old 12-10-2012, 11:29 AM   #1
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,700
There HAS to be an Android app out there that will do this
I have tried so many android apps that ALMOST fit the bill that I cannot believe I can't find one that does all I want it to.
I need an app that will have:
  1. Offline maps
  2. Create a route via a computer (webapp or similar) then upload to the app or an app that I can upload GPX routes to.
  3. Give me offline, TURN BY TURN directions through my predetermined route.
That wouldn't seem to be that difficult to find, but it is. The only one I have found that comes close is Osmand and the turn by turn directions are terrible.
Anyone have any other ideas?
Thanantos is offline   Reply With Quote
Old 12-10-2012, 01:08 PM   #2
Craig McCurdy
BIGMAC
Craig McCurdy's Avatar
Oddometer: 1,467
Try this, "Dual Sport Maps" by "Craftycoder"
http://www.advrider.com/forums/showthread.php?t=753520
Craig McCurdy screwed with this post 12-10-2012 at 01:14 PM
Craig McCurdy is offline   Reply With Quote
Old 12-10-2012, 04:29 PM   #3
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,700
I have it. No turn by turn directions.
Old 12-16-2012, 04:59 PM   #4
DaMonk45
I B Da Monk
DaMonk45's Avatar
Oddometer: 309
What I use
[QUOTE=Thanantos;20218567]I have tried so many android apps that ALMOST fit the bill that I cannot believe I can't find one that does all I want it to.
CoPilot Live
http://www.copilotlive.com/us/naviga...FUeRPAod5GoAbA
So far it has worked for me.
mach1mustang351
The adventure riders are the ones, I think, that push their comfort zone whatever that means.
DaMonk45 is offline   Reply With Quote
Old 12-16-2012, 09:44 PM   #5
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,700
I may be wrong, but it's my understanding that Copilot only allows you to choose between 3 options of alternate routes between two destinations.
2013 V-Strom
Old 12-17-2012, 02:24 AM   #6
DaMonk45
I B Da Monk
DaMonk45's Avatar
Oddometer: 309
Thats is correct if you just want to follow what it wants.
I create my own routes on Google maps and copy that over and follow it.
mach1mustang351
Old 12-17-2012, 09:44 AM   #7
MrMac
Oddometer: 737
The main reason I stick with CoPIlot is because of the planning functions. While it offers 3 alternates for any route, you can still plug in as many waypoints as you want to customize to your content. Make sure you flag them as waypoints, not stops, that way, when you get close to one, it will automatically send you to the next (sometimes it doesn't quite work as well as it should..). The paid version of CoPilot offers a 'drag-route' function that allows you to set waypoints similar to what you can do in Google Maps. Or you can use POI's, intersections, addresses, etc. The routing algorithms are customizable and may be quite different from what you get from Google Maps for the same route. With CoPilot, you can prioritize your road preferences and select from different modes (car, motorcycle, RV, truck, bicycle, walking), and each uses somewhat different default preferences. In other words, you can 'avoid' or 'prefer' highways, secondary roads, etc. Just be aware that the road network in CoPilot is not as mature as some other programs. For example, it may not know about an un-paved road on your route (AMHIK ), just in case that is important..! Their road network no doubt needs improvement, particularly in rural areas! CoPilot is not perfect, but after trying a number of other options (including a Garmin) I keep coming back to using it as my primary navigation app.
In CoPilot, routes are saved as 'xxx.trp' files in the CoPilot/Save/NA folder on your Android. I've seen conversion programs on the 'net that are supposed to be able to convert between .kml/.kmz and .trip, but I haven't felt the need to try them. I have a copy of CoPilot on my Android tablet, where I can plan a route and transfer the .trp file to my Android GPS (Samsung Galaxy Player 4.2) or Phone (both with CoPilot), and use it there.
Keep in mind that if you are planning a route in Google Maps, it may route differently (or not at all) on your device because of variations in map data and routing algorithms found in your navigation programs, regardless of which one you use.
K13 Tiger Explorer XC, K7-KLR650
Some of the more aware dinosaurs warned of the dangers of an iridium-enriched nuclear reactor. 'If this thing goes off', they warned, 'there would be nothing left but cockroaches and mammals.'
MrMac is offline   Reply With Quote
Old 12-18-2012, 08:38 AM   #8
Thanantos OP
Ride hard.
Thanantos's Avatar
Oddometer: 3,700
Thanks for that Mac.
I think I will give CoPilot another try and see how it works out.
What do you use to design your routes with CoPilot?
Old 12-18-2012, 11:08 AM   #9
ShineySideUp
Oddometer: 114
Good reviews for EMFB [easy map for bikers] for droid.
Ride Free - Ride Far - But Ride
I wonder where that road goes?
ShineySideUp is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 03:10 PM.
