Old 12-10-2012, 12:19 PM   #1
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 552
Question 1974 R75/6 starter button loose
Anyone have experience with this problem:
My 1974 R75/6 wirh the /5 switch gear on handle bars the starter button is loose - 2 set screws that hold it on are tight. Starter button works fine but if you touch it it wiggles around. I have had the bike for 5 years and just noticing this is there a way to tighten it up??
Airhead
1974 R75/6 for sale & 1989 R100GS & 1983 Honda CB1000
Biebs is offline   Reply With Quote
Old 12-10-2012, 12:27 PM   #2
pkboxer
Oddometer: 95
Righty Tighty
If you remove the two small screws and gently pull out the switch.
(Helps if you feed the wire harness into the side of the switch.)
There's a large flat head screw under the switch. This connects the housing for the 2 small screws to the whole mount.
Hope that makes sense.
pkboxer is offline   Reply With Quote
Old 12-10-2012, 04:44 PM   #3
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 552
Thanks - I will do that fix. Just didn't know what I would find in there.
Airhead
Old 12-10-2012, 10:40 PM   #4
ontic
Oddometer: 1,070
And be careful you don't tighten it too much- it is a very short thread into cast alu and can strip easy (DAMHIK). Locktite is probably a good idea.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 12-10-2012, 10:51 PM   #5
mfp4073
mfp4073's Avatar
Oddometer: 2,488
Sounds like my headlight switch on the other side. It wouldnt get tight or would loosen up. I put some silicon in there and gently tightened it up. Has stayed in place for 4 months now just fine. I like the idea of loctite, just make sure not to get the permanent kind!
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 12-11-2012, 08:25 PM   #6
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 552
Thumb Thanks this fixed it!!
Plus a litle blue locktite!! Should be good to go!!Thanks
Airhead
Times are GMT -7.   It's 05:23 AM.
