Old 12-10-2012, 05:01 PM   #1
CanadaBiker OP
Oddometer: 276
in-tank petcock strainers no longer avail?
So I've checked several places and it looks like the petcock 'sock' strainers are no longer available?
Part number #16 12 2307112
Is there somewhere else I should look? I checked MaxBMW, BobBMW, and a few others.
Thoughts?
2005 Suzuki DR650
CanadaBiker is offline   Reply With Quote
Old 12-10-2012, 05:18 PM   #2
moosehead
moosehead's Avatar
Location: south of the checkerboard....Bruce Penninsula
Oddometer: 276
Motobins have them...
http://www.motobins.co.uk/bmw-parts.php?model=R Series 2 valve Twin
at bottom of this page
plus have everything else you need.
I usually allow week for delivery in normal times from England. May be a bit slower at Xmas...happy hunting.
Or try Hucky's in the USA
Or use in-line filters in both fuel lines until you get them
retired from work - not life
moosehead screwed with this post 12-10-2012 at 05:21 PM Reason: add'l info
moosehead is offline   Reply With Quote
Old 12-10-2012, 06:08 PM   #3
bmwrench
Oddometer: 2,266
They went NLA a while back, then became available again. I haven't ordered any recently, but have decided not to panic anymore when I see NLA. The last time I did I had a bunch of springs made to hold the eccentrice for ATE Calipers. Then they became available again.
bmwrench is offline   Reply With Quote
Old 12-10-2012, 07:05 PM   #4
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,955
Thoughts?
Do you have straight or 90 degree petcocks? The straight ones have an additional strainer in the nipple end, you don't have to remove the petcocks from the tank to check/clean it.
Big Bamboo is offline   Reply With Quote
Old 12-10-2012, 07:17 PM   #5
DaveBall
DaveBall's Avatar
Oddometer: 1,163
Most people just use the inline filters. They work and you can see when they need replacing.
DaveBall is offline   Reply With Quote
Old 12-10-2012, 07:40 PM   #6
CanadaBiker OP
Oddometer: 276
Thanks for the link. Forgot about them.
I have the straight ones. I did order the smaller strainer that goes in the bottom of the petcock. Do you think it will be enough? I guess it is odd that they have two separate screens.
I also ordered those inline filters, just to be safe. But if I could have new OEM, I might go without the inline ones.
Thanks.
2005 Suzuki DR650
Old 12-10-2012, 07:55 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,951
I used only the small ones for several years. Never knew that I didn't have the bigger ones in place till I recently took apart to clean everything. Was probably flowing slow but still worked. Lots of flakes in small screen area. Now have both small and larger screen in place. I've never used filters but could. Don't really see what the extra filtration would do. Screens seem to be enough.
---Albert Einstein
Old 12-10-2012, 07:57 PM   #8
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,176
The in-tank filter socks are advanatageous in that theyhave a much greater area than the in-petcock or inline filters and are less prone ro getting overloaded and clogging. In addition, since they have gasoline swilling back and forth on a regular basis they tend to be self-cleaning. When I do my yearly tank "cleaning" in the Spring I remove the tank and slosh a quarter-gallon of gas (with a couple ounces of denatured alcohol) around vigorously and pour that gas out quickly to remove sediment and trapped water.
Even then, I consider the in-tank filters as primary and use sintered bronze in-line filters as secondary.
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 01:57 AM.
