12-10-2012, 08:39 PM
#1 |
Oddometer: 1,082
Interesting GS pic...
Anybody know about this particular bike? At first glance it looks standard, but a few interesting bits are lurking...
![]() - forks (is that a G/S bottom clamp?) - wheel hub - brake rotor - passenger footpeg mount - torque arm Anything else? Aside from missing springs, the center stand looks different to me also. Pic says 1987 - prototype maybe?
Operation: Battle Panda |
12-10-2012, 08:53 PM
#2 |
More tacos than you
Oddometer: 5,123
You missed the drain and fill plugs on the swingarm. Yes, the paralever was originally designed to be a wet swingarm. Forks look to be Marzocchi M1s. Front hub appears to be machined rather than cast. Probably before they had their casting tooling made.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
12-10-2012, 08:56 PM
#3 |
Oddometer: 1,082
I was gonna mention it, but thought it was cheating 'cause I wasn't sure I could see them...
12-10-2012, 08:58 PM
#4 |
Oddometer: 1,082
Hub looks quite complex, but looks like it would do away with some weight of the production disc carrier.
12-10-2012, 09:15 PM
#5 |
Oddometer: 824
What years/models were they "wet"?
"No hour of life is wasted that is spent in the saddle." =Winston Churchill= |
12-10-2012, 09:25 PM
#6 |
Oddometer: 1,082
None - only seen on pre-production bikes. Presumably it was nixed for liability reasons - that rear boot just waiting to spew oil over the rear tyre.
I am curious if anyone runs a wet paralever - I bet there's someone out there... Oil may not play nice with the shaft damper material though.
#7 |
More tacos than you
Oddometer: 5,123
Prototypes only. Everything that got sold was dry. Look at the parts fiche. It still shows the fill plugs on the swingarm. 88 and 89 models have the raised flat on the swingarm where it was never drilled for the plugs. They eliminated it later, but you can still see where the tooling was modified to eliminate them on the later ones.
12-10-2012, 10:36 PM
#8 |
Somewhere else
Oddometer: 373
I wish my GS was still that clean, it makes me want to get out there with the polish.
If it's in the Touratech catalogue then you don't need it No man is an island, except for the Isle of Man |
12-10-2012, 11:25 PM
#9 |
enamoured
Oddometer: 2,498
12-11-2012, 12:22 AM
#10 |
In need of repair
Oddometer: 1,434
No cross over in the exhaust headers
No return springs in the centrestand. |
12-11-2012, 05:04 AM
#11 |
Oddometer: 60
Those appear to be the rims that run tubeless tires- weren't they in production later (when the oilheads came out)?
12-11-2012, 05:31 AM
#12 |
Scope Creep's Victim
Oddometer: 2,214
No, the GS's all had the spoked tubeless type rims. There are some tires that you have to run tubes though ... Heidenau K60 front comes to mind ..
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
12-11-2012, 08:57 AM
#13 |
+/- V TDSPP
Oddometer: 19,941
Is that a Basic?
What to do... What to do... |
12-11-2012, 11:19 AM
#14 |
Oddometer: 1,082
Nope, a pre-production R80GS, by the looks of things. Close though.
Do tell. I've run a front K60 tubeless.
12-11-2012, 02:29 PM
#15 |
Oddometer: 58
It might not be a real BMW but a BMC:
