12-12-2012, 10:12 AM
#16 | |
Just Beastly
Oddometer: 6,478
I've done this on the track when I made a ham fisted maneuver, WAAAAY over cooked a turn (think hitting neutral by mistake or some such thing). I am now going waaaaaay faster than I needed to be to negotiate the turn. Stand the bike up, brake very hard, lean it back down and continue. No problem. Same applies on the street for numerous reasons. If you can't or won't do this, you shouldn't be riding on the street. I consider this basic motorcycle skills, to properly control the bike and be a safe rider, in control at all times. Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
12-12-2012, 10:31 AM
#17 | |
Oddometer: 443
The track is much wider and has more run off. Plus you are closer to the limit on the track on traction due to the nature of it.
04 KLR 650 07 KLR 650 06 sv650s 07 Ducati Monster |
12-12-2012, 10:33 AM
#18 | |
Just Beastly
Oddometer: 6,478
PERIOD. End of story. Barry
12-12-2012, 10:47 AM
#19 | |
Oddometer: 443
You think the average rider is at the limit of their traction during the turn and can't brake and turn? Standing up shouldnt even be considered the option since that almost guarantees a crash. Braking won't automatically throw you on the ground.
12-12-2012, 10:49 AM
#20 | ||
Just Beastly
Oddometer: 6,478
I agree with this statement. Barry
12-12-2012, 11:53 AM
#21 | |
Oddometer: 795
brake while leaned over, no problem, no need to "stand the bike" first. if you do, you could possibly not have enuf stopping distance before going straight off the road better to brake and as you slow lessen you lean angle continue thru the curve till your stood up at a stop Im' not sure what the issue is ?
RandyO IBA # 9560 07 VeeStrom 99 SV650 82 XV920R A man with a gun is a citizen A man without a gun is a subject |
12-12-2012, 11:55 AM
#22 |
Oddometer: 795
does not allow for maximum braking if there isn't enuf room going straight
12-12-2012, 12:30 PM
#23 |
Oddometer: 797
5)So you’re into a right-hand corner and you must stop your bike for whatever reason. You close the throttle and sneak on the brakes lightly, balancing lean angle points against brake points. As you slow down, your radius continues to tighten. You don’t want to run off the inside of the corner, so you take away lean angle. What can you do with the brakes when you take away lean angle? Yes! Squeeze more. Stay with it and you will stop your bike mid-corner completely upright. No drama. But don’t just believe me…go prove it to yourself.
This is one of the Disalvo drills.
David 2005 KTM950 Adventure, 2005 Yamaha Vmax, 2002 BMW K1200RS, 2005 Suzuki SV650S, 1991 Honda VFR750, 1990 Honda Hawk GT, 2004 Honda CRF250X, 2000 Buell Blast................ |
12-12-2012, 12:43 PM
#24 |
Oddometer: 4,545
You have a traction budget. If you are at 100% of available corner traction then you are screwed. If you are at 75% you can add 20% braking, as the bike slows you stand up, and your corner traction percent goes to 0 as the braking traction percent goes to near 100% and you successfully stop. Then can happen in much less feet than you might think.
Rod |
12-12-2012, 02:19 PM
#25 | |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,090
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
12-12-2012, 06:15 PM
#26 |
Just Beastly
Oddometer: 6,478
Some of the posters in this thread lack reading comprehension or riding comprehension, or both.
My vote is BOTH ! Carry on. Barry
12-12-2012, 07:29 PM
#27 | |
Oddometer: 335
Have you ever ridden a bike before? First off, no shit your gonna be straight not leaning to far to the side when your stopped. Other than Leaning on a foot which I don't count. If you cannot stop at this trun without crashing then how would handle it? Just go at it at the speed limit the at the last second throw the bike up and slam on the brakes? No. You ease on the brakes like every other situation. And if you cant brake while cornering then you shouldn't be on a bike. What would you do here?
I ride a bullet. A 2 wheeled, multiple-explosion powered machine with enough moving parts to remove entire fingers. Surfaces hot enough to cook flesh. It propels me at neck-breaking, bone-snapping flesh-tearing speeds, over and trough obstacle's I can only see as blurs. Its a sport that kills the careless, maims the best, and spits at the concept of mercy. |
12-12-2012, 07:48 PM
#28 |
Oddometer: 443
So you don't trail brake on the track? It is the same thing, just keeping the traction under 100 percent usage. Lean the bike over a bit, and take a little brake off. All up to the apex. The only difference is on the street you are not using 90% lean traction just to turn at the apex. You are using like 40% and you have 50% left that you can brake with.
12-12-2012, 08:37 PM
#29 |
Grumpy Young Man
Oddometer: 3,752
You can also use the full width of the lane.
12-12-2012, 09:16 PM
#30 |
Oddometer: 443
