12-13-2012, 05:28 PM
#31 | |
Registered
Oddometer: 427
An other issue with this whole thread is that "standing up your bike" will happen regardless of riders action. Most bikes have a geometry which will stand up. Very few bikes are capable of braking without standing up. Only is slippery conditions you have to stand the bike up before braking. In the end all depeneds on the conditions, bike and rider skills. It may be smart to teach new riders not to brake in a curve but it is not the whole truth.
----------------------------------------- If you are thinking outside the box, its better to know the box first. ----------------------------------------- |
12-13-2012, 08:47 PM
#32 |
Well there it is..
Oddometer: 1,100
Keep the green ones off the front brake while leaned over. Teaches them to use Both brakes and square the handlebars, at the same time downshifting so they are ready to get out of the way. The exercise is viable, but I hate it, most crashes happen here in an MSF class because they won't square the bars before braking..
12-14-2012, 03:06 AM
#33 |
Citizen of the world
Oddometer: 1,096
Why are people insisting on looking at how to brake in a corner ... I always am looking for when I can hit the gas
12-14-2012, 04:38 AM
#34 | |
Lost in Space
Oddometer: 1,825
![]() You can play with the physics of this at low speed, ya know, just to see what happens for yourself when you apply the rear brake. The bike will naturally try to go toward the vertical when just the REAR brake is applied during a turn. Don't believe it? While in a low-speed turn, drag the rear a little and you can feel the bike lift away from the turn (i.e. if turning hard left the bike will try to lift toward the right, toward the vertical). I'm no physicist, but I've been riding for 50 years and it works on all kinds of bikes regardless the type of suspension, speed, road surface, etc. Just don't lock the brake. In a low speed maneuver if you slip the clutch and apply a bit of throttle (so you don't stall the engine - do that and you'll fall like a rock ) the bike will be very stable even in a full-lock low speed turn. Using this technique I can turn even my RT or GS in a circle at full steering lock within the width of two standard parking spaces.The same physics are in action at higher speeds, but with more variables thrown in for excitement (inertia of the wheels, traction/tire flex, ass-pucker syndrome (the "third hand" ), frame flex, suspension, rider position (affects the center of gravity), etc. At speed you can even throw in some significant front braking to help. This is why I will never own a bike with linked brakes; I want to control each one individually and not have some computer doing it for me and quite likely fucking it up.I learned this technique years ago while racing motocross/enduros and competing in trials, it really works in low-traction settings and works even better on asphalt. Practice, practice, practice! Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT |
12-14-2012, 10:04 AM
#35 | |
A proud pragmatist.
Oddometer: 2,862
![]() If that cop was idiotic enough to pull that dangerous manoeuver, I don't think I could have discussed with him per my usual wink wink....!
Have tools, will travel!
12-14-2012, 10:18 AM
#36 |
Oddometer: 799
Gradually applying the brakes while leaned over in a turn can actually tighten the turn and does not have to stand the bike up.
David 2005 KTM950 Adventure, 2005 Yamaha Vmax, 2002 BMW K1200RS, 2005 Suzuki SV650S, 1991 Honda VFR750, 1990 Honda Hawk GT, 2004 Honda CRF250X, 2000 Buell Blast................ |
12-14-2012, 03:30 PM
#37 | |
Oddometer: 2,900
12-15-2012, 05:27 AM
#38 |
jack of all trades...
Oddometer: 6,587
One does NOT have to stand the bike up and not get back into the turn. I'm thinking almost every time we ride there is at least one time where I will stand the bike up briefly to do a bit of harder braking than might be allowed in full lean, then lean back in.
It rarely is fully upright, but it is enough to allow the braking I need (quick action based on knowledge from experience, not drawn out thought process mid corner). That is the key - knowing WHAT to do and HOW LONG OR FAR to do it. When I "sit up" in a corner I don't have to remain as such. It might be a quick action to avoid somthing in the road or to take off a bit of speed because of being a bit fast in the corner... any of a variety of reasons. Am I at a dangerous point? Rarely. It is just what I have to do to keep the margin of safety. Have I ever been at that dangerous point? Sure, but kept it on the road (in most cases - on the dual sport it may be possible to go off a bit and keep it upright). Of course I'm not "racing" on the road and that helps make it far less danger than being at the edge. Just my thoughts and ways. If it helps, great. If you don't agree, fine. It just works for me.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens! Mark - klx678 95 KLX650C w/Vulcan piston bigbore, 90 Zephyr 550 |
12-15-2012, 07:08 AM
#39 |
Oddometer: 10,330
So, you're screwing up your entry speed so bad that halfway through the turn you have to srtaighten up and use the brakes, then tip back into the turn. That's interesting. I can't even conceive of that.
Jim Moore "Marines good. Press bad" -Turkish |
12-15-2012, 08:05 AM
#40 | |
Just Beastly
Oddometer: 6,454
There is idiocy being shared in this thread. This thread has FAIL all in it. I am simply amazed. Maybe it's the medium, and we are not sharing information clearly. Or maybe some of the people posting really do not get it as much as their posts suggest they do not. WOW... Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
12-15-2012, 08:19 AM
#41 | |
Red Sox Nation
Oddometer: 8,902
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
12-15-2012, 10:28 AM
#42 | |
Oddometer: 172
Boy, that sounded all smarter than I intended. |
12-15-2012, 11:04 AM
#43 | |
Oddometer: 246
Into the dark side of our nature to look we all need. The energy, the passion there is. Afraid of that people are. Pieces of us it holds busy denying we are. |
12-15-2012, 11:50 AM
#44 |
Oddometer: 4,554
If you are leaned over until hard parts are dragging, and have to panic stop you can not even roll off the throttle until you stand it up a bit. THEN and only then can you apply some brake, hopefully Before you hit something. This is why you should save race cornering for the racetrack. Modern tires usually have good enough traction that while things are draggin you are not using all the tire traction. You would have some left to brake with BUT that will cost you ground clearance and you will lever a tire off, and lowside so you can not use it..There may be exceptions. Beemers are a bit better because of the suspension design but they still squat a bit on braking, so do not trust it.
Rod |
12-15-2012, 01:15 PM
#45 |
Oddometer: 1,376
Great tires even at the limits of lean aka hard parts dragging, aren't fully utilized and have some to offer for both braking or accelerating.
