Old 12-11-2012, 04:38 PM   #1
Redclayrider OP
Long time gone
Redclayrider's Avatar
Oddometer: 745
Honda Forks and trees
I'm wondering if someone here can give me some help in Identifying this set of forks. I know they came off a Honda, I'm thinking a CR. I do not know what year. They came with a single disk front wheel.Where the top triple sits it is 62 or 61 mm.
They have what looks like a air valve on the top and what looks like 2 adjustment screws on the bottom of each fork leg. The top of the bottom triple stem (goes into the neck bearings) is 30 or 31 mm.
Picture of the forks and triple trees.
The top of the forks and triple tree
Bottom of the fork and what looks like adjustment screws
I am thinking of putting them on my 2003 Honda XR 650l. Anyone know if they will fit? What do I need to do to make them fit?
Thanks in advance for the help and if I posted in the wrong spot just move it. Please tell me where it got moved too. :)
Redclayrider is offline   Reply With Quote
Old 12-11-2012, 05:01 PM   #2
kubiak
Oddometer: 4,829
they look like 1989 to 1991 cr forks. if they are the 89 or 90 they should bolt right on to your xr. see if your xr bearings slide on the steering stem. if so they should work. i think around 91 they take different bearings. they are kyb units by looking at the fork seal area of the forks.
Old 12-11-2012, 05:33 PM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
first things first. The screws are in fact screws but they are for holding on the fork guards. Adjustments would be on the bottom of the fork leg.
you'll want a set of calipers that can hopefully measure in metric. Measure the stem at the bottom, that is hopefully 26 or 30mm which would be the ID of your bearing.
Your XRL uses 26 47 15 bearings. Based on looking in the bearing conversion page, there are a TON of CRs that use the same size bearings, but some use a 30mm ID bottom bearing. So if the stem you have is 30mm, you'll need the 30 47 15 bearing from all balls. Do the same measurement for the top.
http://www.allballsracing.com/index.php/forkconversion
You'll also want to get the seals for steering tube. Hopefully the stem length is the same between bikes. That's option B if the other doesn't work is to press the stem out of those CR forks and press in the XRL stem.
Take some measurements and report back
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 12-12-2012, 07:09 AM   #4
Redclayrider OP
Long time gone
Oddometer: 745
Taken with a cheep set of calipers by a near-sighted electrician.
Top and bottom of the stem, 26 mm. Top of fork 55 mm
There are 3 allen bolts at the bottom of each fork leg. On the right leg one of the allen bolts has a small flat head screw (like an adjustment, it dose not click but will not screw out. It just turns) There are 3 allen bolts on the left. One looks like it has a flat head screw in the center but I need to clean it up some more to be sure.
Old 12-12-2012, 07:39 AM   #5
kubiak
Oddometer: 4,829
the 3 allen bolts are for the fork slider covers, they should bolt on the xr by looking at the stem in the pics. i think it even has the same diameter axle to fit either the xr or cr wheel.
Old 12-12-2012, 10:04 AM   #6
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,862
Somebody must have painted the triples black, threw me for a minute, but you can see overspray on the stem. I was thinking KX forks until I noticed the overspray.
larryboy is online now   Reply With Quote
Old 12-12-2012, 02:52 PM   #7
Redclayrider OP
Long time gone
Oddometer: 745
Thanks for the help on my fork swap problem everyone. While they will not be good as a modern Cr450 set up, they should be stiffer than the stock legs.
Now to check on what Racetech has to offer for the fork tubes, see if the stock XR caliper will bolt up, get some new bearings, and slap it on!
Old 12-12-2012, 04:18 PM   #8
camperdad
camperdad's Avatar
Oddometer: 80
Question best usd option
It seems like there are dozens of ways to a do a USD swap. But my question is what is the easiest? Which year and what model requires the least amount of bearing swapping, machining, measuring, and fiddling with? Is there a certain year/model that comes close to accomplishing this goal with the maximum amount of benefit with a minimum amount of re-engineering?
camperdad is offline   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
