Old 12-12-2012, 05:29 PM   #1
midfat OP
wholesome dirtiness
midfat's Avatar
Location: Socal, between the mountains, desert and ocean
Oddometer: 222
Conti Trail Attack on 950SE?
I am wearing my asbestos face mask, so flame away. I'm about to ask a tire question for the SE...
I searched, but could not "quickly" find an answer. Anybody running the Conti Trail Attack on their SE? Looks like a good solution for street -- without SM wheels. The rear is a 150/70-18, so a bit wider than stock. Front is a 90/90-21, so that's perfect. I'm replacing my worn out 908/TKC combo after 5000 miles. I've run the Pirelli A/T Scorps in the past. Not my favorite tire. Looking to be on pavement for a while.
midfat is offline   Reply With Quote
Old 12-12-2012, 06:17 PM   #2
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,084
Na nobody would put those on a SE
dogsslober is offline   Reply With Quote
Old 12-12-2012, 06:34 PM   #3
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,263
K60 is the about the best allround tire for a 950. Check with Craig at CJ Designs.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 12-12-2012, 08:15 PM   #4
River6822
Fat kid on a 950 SE
River6822's Avatar
Oddometer: 361
I use them as my street tire and like them but I haven't had much confidence with them on anything more technical than a dirt road.
2013 KTM 1190 Adventure
2007 KTM 950 SE
2004 KTM 450 EXC
1979 Suzuki GS850
1993 Harley Café Project
River6822 is offline   Reply With Quote
Old 12-12-2012, 09:02 PM   #5
David37
David37's Avatar
Oddometer: 410
Currently running the Conti Trail Attacks on my 950SE. IMO they are one of the best street tires you can put on an 950SE. Don't expect too much from these tires when you leave the pavement.
David37 is offline   Reply With Quote
Old 12-12-2012, 09:35 PM   #6
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 222
Okay, sounds like the Conti might make a decent alternative to the Scorpion A/T. After the third time that tire stepped out on me with modest throttle, I decided to give something else a try. Now, mind you, this being an SE, I should expect a little tail slide from time to time, but the 908 with knobs was a better rear tire on pavement than the Pirelli. Gonna give the Contis a try.
midfat screwed with this post 12-13-2012 at 08:12 AM
Old 12-12-2012, 10:33 PM   #7
mousitsas
mousitsas's Avatar
Oddometer: 2,993
Enduro 3 sahara 140/80 on the back, Anakee2 on the front. Perfect on the street, very good off it.
Old 12-13-2012, 07:31 AM   #8
NKL
Oddometer: 202
I run them on my 990 Adventure for road work and they are brilliant.
NKL is offline   Reply With Quote
Old 12-13-2012, 09:55 AM   #9
Qwik
Adrenaline Addict
Oddometer: 6,947
The only problem is they dont wear out. ten K miles on mine when I pulled em and sold em.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 12-13-2012, 02:19 PM   #10
Sacal
Sacal's Avatar
Oddometer: 132
6000 miles on Conti TA's so far (990A), autobahns, mountain twisties, the potholed roads of eastern Europe and some trail work thrown in for good measure. In the dry they behave very well, in the wet leaned over if you give it a handful they will slide and spin but always in a controllable and fun way when you learn to trust them The first time I got the rear spinning leaned over in the wet it happened in such a controlled way I actually though it was the clutch slipping! On dry trails they work well but be warned anywhere near wet mud. Definitely recommended for road work, don't forget that for road work it's not always how fast you can go but also how fast you can stop
ad astra per alia porci
Sacal is offline   Reply With Quote
Old 12-13-2012, 05:23 PM   #11
katanarama
riding > posting
Oddometer: 182
I ride my 990 year around here in Vancouver and have Conti Trail Attacks on a 19/17 set up.
These tires are excellent in the dry and confidence inspiring in the wet. Good on graded dirt and gravel roads and passable on semi slick conditions. Anything really wet or muddy then you will struggle.
I rate them a great all around tire and the gain on the standard Scorpions for those riding 80/20 hiway/dirt roads is easily noticed.
katanarama is offline   Reply With Quote
Old 12-13-2012, 06:54 PM   #12
crofrog
Oddometer: 1,455
+1 these tires are fucking amazing... I'm at right around the same and they're still round. I did a burn out and it barely put a mark in them.
crofrog is offline   Reply With Quote
Old 12-13-2012, 08:48 PM   #13
midfat OP
wholesome dirtiness
midfat's Avatar
Oddometer: 222
Ordered a set from RMATV. $240 shipped, front and rear. I do quite a bit a canyon twisties living in So Cal. Like a said, the Pirelli Scorpions would step out on dry pavement with just a little throttle. I learns to anticipate it, but always felt like I was playing with fire. The Conti's sound like a much better street tire. And off road, he'll, I live in the desert. It's never muddy. If it is, I'll ride my plated 450.
Old 12-14-2012, 08:05 AM   #14
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,596
Trail Attacks work terrific on the road...
2013 KTM 690R Enduro
Chuckracer is offline   Reply With Quote
Old 12-15-2012, 06:08 PM   #15
jonz
Miles are my mantra
jonz's Avatar
Oddometer: 2,479
I used them for a 1000+ mile road trip on my SE with as many tight and nasty twisties as I could find. They were brilliant on pavement. I didn't really try them much on dirt - just a blast across a vacant lot with loose desert sand. I didn't really test them but they were fine. I pulled them off and they're waiting for the next street trip. On the plus side, they were easy to spoon on and off.
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is offline   Reply With Quote
Times are GMT -7.   It's 04:43 PM.
