Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 09-21-2013, 10:04 PM   #121
Dino3310
Oddometer: 673
Awesome job Paul, looks fantastic, cant wait to hear her crackling down a back straight
Dino3310 is offline   Reply With Quote
Old 09-21-2013, 11:57 PM   #122
trustme OP
trustme's Avatar
Oddometer: 977
Thanks for all the kind comments & encouragement.
Little things make a difference, I used a paper thin gasket on the primary drive cover , a different clutch basket & alloy pressure plate meant there was not enough clearance so the basket & plate rubbed on the outer cover. 2 X normal thickness gaskets seems to be the answer , no noises , clutch that clutches , gearbox does it's gearboxy thing, no noises . Will put the primary belt back on & try next weekend.
Also replaced the throttle cables & Amal throttle assembly with a Tomaselli quick action assembly & new cables . I should have known. Why is wog shit is never quite plug & play , had too mess with cable outer lengths to make it all work, could not possibly be Triumph stuff at fault.
That's all till next weekend.
I hate this itinerant lifestyle
trustme is offline   Reply With Quote
Old 09-23-2013, 12:59 AM   #123
Micawberism
Oddometer: 266
Italians make good tyres though!
Excepts when they go flat, then daygo wop wop wop wop
Micawberism screwed with this post 09-23-2013 at 02:07 AM
Micawberism is offline   Reply With Quote
Old 12-31-2013, 10:20 PM   #124
trustme OP
trustme's Avatar
Oddometer: 977
Happy New Year from Team Winston.
The last 4 months have been chaos. All work & no play has made Trustme a very dull boy.
Winston has languished under a cover in the corner.
The Barry Sheene & the Burt came & went while I worked & Winston sat.
I've promised myself 'This year is going to be different ' . I've been at home the last 10 days, sorted out a lot of the minor stuff that takes time, gearbox is fixed , lock wiring done, oil leak gone. Tomorrow is another run up & down the road, then testing at Taupo.
First race is at Taupo in early Feb, work is full on for Jan then calms down.
Well here hoping.
Old 01-01-2014, 05:39 PM   #125
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
Looking Good, should be nicer without the ape hangers
Going to run it in pre 72?, as long as it looks pre 72 from 100 metres your in.
Voltaire is online now   Reply With Quote
Old 01-01-2014, 08:08 PM   #126
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,499
Originally Posted by trustme View Post
oil leak gone.
It's British. Doesn't that just mean there's no oil in it?
Have noted the Taupo date in my diary, will hopefully get down for a look.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 01-02-2014, 06:01 PM   #127
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,688
That looks very nice. Good luck with the racing. Have those headers been coated? Doesn't look like like a rattle can job.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 02-02-2014, 02:38 PM   #128
clintnz
clintnz's Avatar
Oddometer: 3,499
Called into the Taupo track yesterday to check out some classic action. Team Winston was in attendance & looking sharp:
And racing!
After some jetting changes the day before the old Bonnie was apparently going pretty well.
Cheers
Clint
clintnz screwed with this post 02-02-2014 at 04:11 PM
Old 02-02-2014, 03:09 PM   #129
trustme OP
trustme's Avatar
Oddometer: 977
Thanks for that Clint & good of you to drop by.
I'll post up pics later. Had a good dice with that Laverda, he was missing gear changes, I just got past him down the back straight on the last lap then the miss I kept chasing all weekend kicked in at 6000 rpm & he slipped back through, bugger, bugger, bugger.
The Laverda died on the wind down lap, dead electrics & a fractured muffler. Winston still has the miss. The joys of old tragics racing .
Old 02-02-2014, 03:10 PM   #130
trustme OP
trustme's Avatar
Oddometer: 977
Yup, it is a rattle can job
Old 02-02-2014, 03:32 PM   #131
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,634
Good Stuff, whats the laverda ...? SF750?
You doing Friday at HD?
Old 02-02-2014, 04:38 PM   #132
Padmei
enamoured
Oddometer: 3,707
looks very cool. Well done TM & clint
Padmei is online now   Reply With Quote
Old 02-02-2014, 05:57 PM   #133
trustme OP
trustme's Avatar
Oddometer: 977
SF750 , once he gets it sorted it should go well.
Definitely on for Friday. Retorqueing [ is that a word ] the head today. Got to buy a new sun shade, windy Taupo turned old faithful inside out.
Adrian got some rods & we cable tied it together. Right about then there was a call on the PA, the flag marshals wanted the poles for their flags returned !!! hmmm ??
Old 02-02-2014, 10:44 PM   #134
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,929
bikes or riders?
These are the best days
Mark_S is offline   Reply With Quote
Old 02-02-2014, 11:09 PM   #135
trustme OP
trustme's Avatar
Oddometer: 977
Some years ago I pulled onto a freeway in New Jersey. I said to the guy in the toll booth, ' Does this take me north or south '
' Either way ' came the smart arse reply
200 yards later the road split north & south
' EITHER WAY '
Times are GMT -7.   It's 12:46 AM.
