Old 12-12-2012, 02:06 AM   #1
Hrspwr Hero OP
wipe off 50 or.....
Hrspwr Hero's Avatar
Oddometer: 76
UHF radio cover
Does anyone know where I can buy a waterproof/dust proof cover for a handheld uhf radio?
Just an extra layer of protection for a splash proof radio :)
Hrspwr Hero is offline   Reply With Quote
Old 12-12-2012, 04:05 AM   #2
Quirky
Quirky's Avatar
Oddometer: 585
I just use a snaplock sandwich bag and a rubber band. Just cause I'm a cheap bastard.
What about a condom? anyone single use only
BMW R1200GS, Yamaha WR250R
SPOT link
Quirky is offline   Reply With Quote
Old 12-12-2012, 11:18 AM   #3
DMME
Old Fart, Older Bike
DMME's Avatar
Oddometer: 282
Try a wetsuit type stubby holder
pop a hole in for the aerial, and when you get to camp you can use it for its intended purpose too
DMME is offline   Reply With Quote
Old 12-12-2012, 11:38 AM   #4
wairau
richie
wairau's Avatar
Oddometer: 1,418
Something like this?
http://www.ebay.com.au/itm/GME-CC51-...3#ht_662wt_922
wairau is offline   Reply With Quote
Old 12-12-2012, 01:20 PM   #5
excTC
Carbon Ktm lifeform
excTC's Avatar
Oddometer: 164
The camping shops have waterproof plastic covers for phones for about $20. Kathmandu. It might not fit the aerial.
KTM 530 EXC Royal Enfield Bullet 500 KTM 690R. Spot link The Land of Pickled Fish and Beyond
Team690 on the APC
excTC is offline   Reply With Quote
Old 12-12-2012, 01:46 PM   #6
XRman
XRman's Avatar
Oddometer: 3,012
camera case
I use a neoprene camera bag that attaches to my jacket belt. It has flap that closes over the top with a velcro closure. the aerial fits out the side of the flap. I use a rubber band from an inner tube to secure the flap in case the velcro gets clogged and lets go. it works OK and is splash proof.
XRman is offline   Reply With Quote
Old 12-12-2012, 02:08 PM   #7
Hrspwr Hero OP
wipe off 50 or.....
Oddometer: 76
Hmmmmm....... Hadn't thought of neoprene.........
Thought of the ziplock bag but was hoing for somthing elegant.
The radio I have is IPX5 splash proof which says something about ok with 2 x 6mm jets of water.
I'm thinking of using one of the Ram universal finger mounts to get it on the handlebars, maybe then I can just bag right over the whole thing. Get the electric sandwich bag sealer out
Old 12-12-2012, 02:21 PM   #8
XRman
XRman's Avatar
Oddometer: 3,012
Thumbs down condensation
I thought about a handlebar mount but then you have to disconnect too many cords when you get off for gates etc. PIA.
My way you have it all on your body and no need to disconnect PTT& radio leads.If it gets really wet you can zip lock it for a while.
Sealed permanently would lead to condensation I suspect, and eventual failure. Maybe???
Old 12-12-2012, 06:58 PM   #9
matt_ali_walsh
Oddometer: 28
Your radio may be splash proof, but all bets are off once you plug anything in to it..... We have small Icoms and one failed in the rain. Icom came to the party whan I suggested the manual didn't actually mention the plugging in bit, but we just use plastic bags now - not too pretty but effective
Matt & Ali Walsh
R1150GS, R1100GS '77R100RS & '55 R50 (kit form)
matt_ali_walsh is offline   Reply With Quote
Old 12-13-2012, 11:33 AM   #10
DMME
DMME's Avatar
Oddometer: 282
[QUOTE=XRman;20235471
Sealed permanently would lead to condensation I suspect, and eventual failure. Maybe???[/QUOTE]
Spot on, NEVER try seal anything fully, if the box/bag/enclosure is rated as waterproof (IP67, JIS7) drill a small (2mm max) hole or 2 in the lowest point/s to allow water out. YEARS of experience talking
Old 12-13-2012, 12:13 PM   #11
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,504
sandwich bag sealer? luxury!
I made a cover with some heavier clear plastic bag stuff, heated a steel bar up with the gas torch to weld it together. Worked good until the rubber band holding it on broke & it blew off, will make a mk2 as I'm about to re-fit the comms system.
It looked a bit manky but I consider that a good thing - a dust covered bit of rubbish is less likely to get nicked than a shiny gadget.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Times are GMT -7.   It's 03:08 AM.
