Old 12-13-2012, 08:36 PM   #1
MiteyF OP
MiteyF's Avatar
Oddometer: 1,995
Help with a BMW 650 "project" - ABS removal?
I recently bought a 2002 BMW 650 engine and frame for a whopping $100, complete with wiring, swinger, TB etc. The plan is to swap the engine into a modified frame I have. After tearing into it a little, there's a LOT of wiring that I would like to minimize. I'm planning on building a sort of dirt tracker/gravel/FS road runner, and I don't want the ABS (among other things). I'd like to get rid of all of the hard lines, wires etc that are associated with it, as opposed to just using the switch to turn it off.
Is there a writeup anywhere on how to do this? What can I remove? Do I need to add any resistors, splice any wires etc etc to fool the ECU?
ANY help would be greatly appreciated!
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 12-15-2012, 07:47 AM   #2
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 716
I'm pretty sure that on the F650 the ABS is an independent part of the brake system. You should be able to remove the wheel speed sensors and all wiring related to them. There may also be a signal from the speedometer tot eh ABS module, not sure. Without the speed sensors in the system, the ABS cannot function. The wiring harness for the ABS module can be traced from the module to other points in the harness and removed.
The rest should just be the hydraulic side of the system. The ABS system plumbs into the standard brakes in a way to override the operator input when the system senses wheel lockup. So in essence the ABS system "doubles" the connections into the hydraulic brakes. The calipers are the same as a bike without ABS. So remove the ABS module and the respective steel and rubber lines from it to the calipers and front and rear master cylinders (front brake lever, rear brake pedal). Either plug the lines where the ABS tees into the system, or simply replace all the brake lines with standard brake hoses run from the master cylinders to the front and rear calipers.
Not sure if there are separate check valves in the ABS circuit, or if they are built into the ABS module. But once you route brake hoses direct from the lever/pedal to the calipers, any other parts in the ABS system can be removed/sold. I doubt there is any connection between the ABS module and the engine ECM, so no wiring issues there.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 screwed with this post 12-15-2012 at 07:58 AM
Andyvh1959 is offline   Reply With Quote
Old 12-15-2012, 04:55 PM   #3
MiteyF OP
MiteyF's Avatar
Oddometer: 1,995
Wonderful, very useful info. Thanks!
Times are GMT -7.   It's 11:23 AM.
