Old 12-14-2012, 10:46 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
Feeler Gauge for valve check
Hey guys... I'm doing the valve check on my 990 ADV and am trying to find the right feeler gauge for the job. Mainly trouble finding a metric gauge. Do you all just convert to mm?
A link to one online would be awesome !
Thanks and Happy Holidays !
skidxr is offline   Reply With Quote
Old 12-14-2012, 11:01 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,698
I use inch gauges and convert.
Peanuts is offline   Reply With Quote
Old 12-14-2012, 11:02 AM   #3
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
I've had luck w/ Sears/Craftsman gauges.
Craftsman 26 Leaf Offset Gauge
Old 12-14-2012, 11:08 AM   #4
gozirra
Spam?
Oddometer: 160
0.10mm=(.004") inch is rounded off, mm is true
0.13mm=(.005") inch is rounded off, mm is true
0.15mm=(.006") inch is rounded off, mm is true
0.18mm=(.007") inch is rounded off, mm is true
0.20mm=(.008") inch is rounded off, mm is true
0.23mm=(.009") inch is rounded off, mm is true
Pulled this from somewhere long time ago for some reason, maybe helpful?
Dunno, can also find metric gauges at pepboys, Here
first place I looked, if non US, well I would check any auto repair place.
gozirra is offline   Reply With Quote
Old 12-14-2012, 11:23 AM   #5
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
Thank you.. This helps.
I found this in the right sizes. Do you think the handles would help or hurt?
http://www.autotoolworld.com/product...e5FMgodBkAAiA#
skidxr screwed with this post 12-14-2012 at 11:37 AM
Old 12-14-2012, 01:10 PM   #6
Steveman
Steveman's Avatar
Oddometer: 471
KTM offers a set of metric feeler gauges for a few bucks.
Steveman is offline   Reply With Quote
Old 12-15-2012, 07:58 AM   #7
jas123
jas123's Avatar
Oddometer: 115
Millimeters to inches is/ millimeters x .03937
Inches to millimeters is / inches x 25.4
jas123 is online now   Reply With Quote
Old 12-17-2012, 08:12 AM   #8
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
Luckily, the ktm cannot tell a difference between metric and standard valve lash.
Sporting Wood is offline   Reply With Quote
Old 12-17-2012, 11:08 AM   #9
Steveman
Steveman's Avatar
Oddometer: 471
PN for KTM feeler gauge 59029041000
Old 12-17-2012, 11:13 AM   #10
markjenn
Oddometer: 10,482
Until recently, I used inch gauges and converted. The precision involved in valve clearance checks is not that high and you can certainly get acceptable results doing this. But you will get a little bit of extra precision with metrics - the worst-case roundoff error can conspire to be significant - I think I computed once it can be as much as 50% or the increment in shim sizes. So I got a metric set recently. They're surprisingly hard to find at US stores, so I bought online (perhaps on Ebay) - they're made by KD. But one thing I don't like is that they start out at 0.04mm with 0.01mm increments, but go to 0.05mm increments abruptly at 0.10mm. This means doing something common like 0.12mm (a typical intake valve spec) requires stacking two gauges.
- Mark
markjenn screwed with this post 12-17-2012 at 11:23 AM
Old 12-17-2012, 03:17 PM   #11
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
Thank you all for the help. I have the feeler gauge issue worked out now.
I have everything apart and have checked the valves.
I have one intake on the front cylinder that is right at .10 (i can get the .004 feeler gauge in but not the .005) This being in spec but at the low end should I re-shim it to the other end of the spec?
Thanks again... This has only taken me a week to get this far.
Old 12-17-2012, 03:32 PM   #12
markjenn
Oddometer: 10,482
You'll get lots of opinions on this... mine is that if a valve is within spec, then leave it alone, especially if it involves pulling cams that otherwise can remain undisturbed.
- Mark
Old 12-18-2012, 04:01 AM   #13
Steveman
Steveman's Avatar
Oddometer: 471
- Mark
+1
(unless you are racing that bike)
Old 12-18-2012, 01:47 PM   #14
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,030
Buy Quality They Last A Lifetime
and it's worth about that much. Few blades so hard to nail down clearances with the possible combinations. DAMHIK
Google-up your local MAC or Snap-On Tools dealer and find out his schedule in your area so you can meet his truck somewhere. You can usually find them at all the major shops in town at least once a week depending on where you live.
They have feeler guage sets like you won't believe- and they don't cost as much as you'd think. There are metric sets that go down to very small thicknesses so adding blades to get a good read is easy. Get some with long tapered blades as they fit in between the cam bridges easily. Furthermore they actually sell replacement blades if you ever damage any in your set.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 12-18-2012, 02:55 PM   #15
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,253
Thanks for posting that.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Times are GMT -7.   It's 03:58 AM.
