Old 05-20-2013, 11:17 AM   #76
GeeK_InsiDe
Moore Gas!!!
GeeK_InsiDe's Avatar
Oddometer: 330
You can see the the arrow, it's correct:
EDIT: The same on the 1200:
GeeK_InsiDe is offline   Reply With Quote
Old 05-20-2013, 02:56 PM   #77
rmhrc628
rmhrc628's Avatar
Oddometer: 2,529
new tire coming up Karoo 3
Oh wow I'm wrong.
It just seems arse about to draw mud to centre.
I wonder if you mounted the other way how it would work? For muddier riding I would def reverse the front for current and try it. Otherwise it must be average in the mud?
Ps those trails look awesome!! Is that some late season snow melt causing the mud?
rmhrc628 is offline   Reply With Quote
Old 05-20-2013, 07:39 PM   #78
raider
Big red dog
raider's Avatar
Oddometer: 1,582
Originally Posted by rmhrc628 View Post
Oh wow I'm wrong.
I believe there might be some difference in the design philosophy between a 35km/h tractor and a 160km/h motorcycle.
As mentioned earlier in this topic, front tyres with directional tread almost always face the "wrong" way to provide traction under braking on wet roads. Remember, this is not an offroad-only tyre, it's for highway use too.
14 R1200GS Adventure
raider is offline   Reply With Quote
Old 05-20-2013, 08:19 PM   #79
MADSTROM
MADSTROM's Avatar
Oddometer: 1,446
GeeK_InsiDe
There absolutely nothing wrong with your English. You would not want to see most members attempts at posting in Swiss. Thanks for taking the time to post these pictures.
MADSTROM is offline   Reply With Quote
Old 05-20-2013, 08:26 PM   #80
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Ain't no such thing as "Swiss!" It's Schwyzerdütsch!
Uf Wiederluege!
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 05-20-2013, 08:40 PM   #81
rmhrc628
rmhrc628's Avatar
Oddometer: 2,529
Perhaps a topic for another day but pushing water out of the way and clearing the tyre of water etc is first principle.
There's little difference in the concept of keeping the tyre clear of mud and or water
Old 05-21-2013, 09:12 AM   #82
GeeK_InsiDe
Moore Gas!!!
Oddometer: 330
Didn't see your question.
No melting snow, just a good rainy week :)! And in the forest, no sun to dry this mud
In fact forest trails are nearly always wet and muddy because we don't have a lot of sunny days without rain in between...
Old 05-22-2013, 02:20 PM   #83
Wildman
In my castle
Wildman's Avatar
Oddometer: 17,953
Uf Wiederluege!
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 05-22-2013, 04:34 PM   #84
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 8,322
That front tire looks noisy and lots of vibrations.
True?
Only a biker knows why a dog sticks his head out of a car window.
RobbieO is offline   Reply With Quote
Old 05-22-2013, 11:04 PM   #85
GeeK_InsiDe
Moore Gas!!!
Oddometer: 330
Less vibrations than the K60 Scout I had on my 950 Adv, but a little more noisy ;)
Old 05-24-2013, 09:43 AM   #86
DS Rider
DS Rider's Avatar
Oddometer: 70
this is correct, as there is no drive to a front wheel on a motorcycle (ususally). The front tyre is mounted in a manner that clears water and mud under braking. As per the photos you see.
Remember, the rear wheel drives the bike, the front wheel stops it
DS Rider is offline   Reply With Quote
Old 05-24-2013, 05:12 PM   #87
rmhrc628
rmhrc628's Avatar
Oddometer: 2,529
How does that front tyre clear water and mud? The mud enters the side and is channeled to the centre. Even car tyres are direction based so they channel water out, not direct it in.
I still reckon that front is mounted wrong way for anything but dry pavement
Old 05-25-2013, 12:16 AM   #88
DS Rider
DS Rider's Avatar
Oddometer: 70
Imagine the front tyre skidding, it will then channel mud and water from the centre out through the sides. Any time you apply the brakes you get a small degree of tyre slip. (if i remember correctly approx 13% slip gives maximum braking) so this effect happens each time you brake, while the same but in the opposite direction is happening on the rear, because that end is driving.
Old 05-25-2013, 12:45 AM   #89
jengel451
1 Cool MotherF#$cker
Oddometer: 789
^^^ agree 100%.
can you imagine going into slime and tapping the front brake with the tire blocks pointing the same as the rear? Talk about ice.
That being said, curious how that rear would work on loose dirt trying to use the back end to steer or locking up the rear down a hill
jengel451 is offline   Reply With Quote
Old 05-25-2013, 01:41 AM   #90
rmhrc628
rmhrc628's Avatar
Oddometer: 2,529
How does the front tyre have any connection to the rear ? It doesn't.
Your argument about flex might make sense on pavement only.
You want the front and rear to clear mud and water.
There is no way in mud that mounting would clear better than changing its direction. It would clog up and be terrible
Times are GMT -7.   It's 12:20 AM.
