Old 12-15-2012, 11:43 PM   #1
Konflict Motorsports OP
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 861
Touratech Suspension
Konflict Motorsports & Suspension and Touratech-USA have been working together on the new line of Touratech Suspension by Tractive and would like to introduce the exciting new line of purpose-built suspension for adventure touring motorcycles with luggage.
As the only suspension tuner in the USA that has had the chance to disassemble & inspect the product we would like to share this information with the ADV members. We offer custom tuning & currently are the only authorized Touratech Suspension center in the United States.
The four lines of suspension are as follows, currently we offer these for BMW 1200 GS and Adventure.:
Extreme $1795.00
PDS, Remote Reservoir, Adjustable shock length (certain models), High & Low Speed compression adjustment, rebound adjustment, hydraulic spring pre-load adjustment.
Expedition: $1495.00
Remote Reservoir, Adjustable shock length (certain models), High & Low Speed compression adjustment, rebound adjustment, hydraulic spring pre-load adjustment. PDS can be added as an option (requires parts & labor)
Explore HPe: $1695.00
Electronic controlled pre-load adjustment, rebound adjustment.
Explore: $795.00
Rebound adjustment, manual pre-load adjustment.
Product Summary:
Bottoming Control with secondary compression dampening technology which prevents bottoming out. The (PDS) Position-dependent Dampening System is like a hydraulic pillow at the end of the stroke.
Available on Extreme & Expedition as an option (requires parts & labor)
Remote Reservoir, made from high-strength aluminum, keeps the fluid cool and ensures pressure stability in the shock which results in better performance. The reservoir also increases fluid volume by 50% extending the life of your shock.
Available on Explorer HP, Expedition, and Extreme.
Adjustable Shock Length, allows 8mm (-4mm to +4mm) of length adjustment to fine tune the ride height of your bike.
Available on Expedition & Extreme.
Adjustable high-speed and low-speed compression dampening allows absolute control of shock tuning to give you the precise handling characteristics you want in any conditions.
Adjustable Rebound Dampening allows you to fine-tune the ride characteristics to meet your preferences.
Available on Explorer, Explore HP, Expedition, and Extreme.
50% more preload adjustment than other shocks on the market. A generous 15mm of adjustment allows proper spring pre-load set-up. Most shocks have 8-10mm which is not enough to accommodate the varying quantities of long-distance luggage or even a passenger.
Available on Explore HPe, Expedition & Extreme.
Hydraulic Spring Preload Adjustment allows quick changes to be made to the preload by twisting the knob with your hand.
A floating piston separates the air and the oil to prevent oil foaming also known as cavitation. This technology ensures that your shock will have smooth and consistent performance even in punishing environments.
Available on Extreme, Expedition, Explore HP, Explore HPe, Explore.
Cold forged 6082 T6 aluminum shock body machined to exacting standards offers high-strength and maximum heat dissipation.
High-strength stainless steel bushings ensure the mounting points of the shock will go the distance.
Low-friction seal with integrated Teflon back-up ring maximizes performance and extends the life of the shock.
Oversized 16mm high-strength shaft made of chrome-moly steelfor maximum strength and durability.
Available in a range of spring rates to match the rider weight requirements.
Dampening (valving) set up for fully-loaded R1200GS or GSA right out-of-the-box.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports screwed with this post 12-16-2012 at 08:44 AM Reason: Mod
Konflict Motorsports is offline   Reply With Quote
Old 12-16-2012, 06:24 AM   #2
wmfleet2
Oddometer: 985
ok ,,,you klr owners step up
wmfleet2 is offline   Reply With Quote
Old 12-16-2012, 10:50 AM   #3
LoFlow
Oddometer: 992
Good info, nice options too.
The highway's a storyteller...No time to write it down.
LoFlow is offline   Reply With Quote
Old 12-17-2012, 05:36 PM   #4
TouratechUSA
Made For Adventure
TouratechUSA's Avatar
Oddometer: 488
The Touratech crew has worked with Konflict Motorsports over the years for custom suspension solutions and we have tremendous confidence in the work they do. We are pleased to have them on board with us as we launch Touratech Suspension in the US!
Thanks,
Paul Guillien| General Manager
Touratech-USA / CycoActive, Inc.
(206) 323-2349 ext. 226
TouratechUSA is offline   Reply With Quote
Times are GMT -7.   It's 03:15 AM.
