Old 12-16-2012, 11:09 AM   #1
m800mm OP
Oddometer: 74
Battery tender ?
Is it possible to hook up a battery tender to the power socket on
the dash or is there a diode that won't let voltage back in the system?
m800mm is offline   Reply With Quote
Old 12-16-2012, 11:13 AM   #2
propilot10
Oddometer: 121
On mine it works. 2012 adv. no idea on earlier years.
propilot10 is offline   Reply With Quote
Old 12-16-2012, 11:15 AM   #3
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,776
Works fine for me doing it that way.
2011 990 adv
2012 wr250r
You don't know what you don't know
findLadukebob
Ladukebob is offline   Reply With Quote
Old 12-16-2012, 11:55 AM   #4
edzt
edzt's Avatar
Oddometer: 17
KTM.......diode
edzt is offline   Reply With Quote
Old 12-16-2012, 12:07 PM   #5
skipman
skipman's Avatar
Oddometer: 175
If it had a doide it would cost atleast $300 to replace it...LOL
Not responsable for broken windshields.Please stay back 300ft.
'10 KTM 990r
skipman is offline   Reply With Quote
Old 12-16-2012, 01:22 PM   #6
Portman
Portman
Oddometer: 48
Worked fine on my 2008 ADV and works fine on my 2011 ADV.
Portman is offline   Reply With Quote
Old 12-16-2012, 01:44 PM   #7
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,876
In case the battery is low, it could be too much for the power socket wiring.
I do not know if the fuses would protect the wiring harness from overcharge.
Cheers.
Old 12-16-2012, 03:27 PM   #8
Weldit
Weldit's Avatar
Oddometer: 336
my c-tek tender only puts out 3 amps max - so no problem there
works perfect
tried the same on the honda 4 wheeler - no go - it is switched with ignition on honda
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 12-17-2012, 08:14 AM   #9
MT950
"OLD" Adventurer
Oddometer: 246
Have used a Deltron batt. tender on all my bikes for years with no problem. 07 990 and 06 950 Adv's both plugged into dash (adapters for this are avail) ! Never a problem and battery always charged! I just leave the bikes plugged in all winter "unless I'm riding them!
MT950 is offline   Reply With Quote
Old 12-17-2012, 11:04 AM   #10
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,748
07 990
Batt Tender
Been doing it since day one.
Never a problem, works just fine.
Still on the original batt.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-17-2012, 03:09 PM   #11
EZ300
EZ300's Avatar
Oddometer: 1,005
07 990 Adventure
Battery Tender Jr. I have it on a timer for about 2 hours a day plugged into the dash.
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 04-24-2013, 02:59 PM   #12
RedFrogTango
RedFrogTango's Avatar
Oddometer: 729
I have a BMW battery tender for maintaining the gel battery in my 04 R1150R Rockster. Any idea if I can use the BMW tender on my 07 990 Adventure?
RedFrogTango is offline   Reply With Quote
Old 04-24-2013, 05:44 PM   #13
Deviant666
Present
Deviant666's Avatar
Oddometer: 534
Yes, do it all the time...
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 04-29-2013, 11:11 AM   #14
RedFrogTango
Oddometer: 729
FWIW - I have verified that a BMW battery tender (black metal case w/ 2 LEDs) made for gel batteries (my R1150R) will work on an '07 KTM 990 Adv, and that it will charge when connected to the socket on the dash of my KTM.
Times are GMT -7.   It's 05:33 AM.
