Old 02-06-2013, 09:17 AM   #16
benzine
adv
benzine's Avatar
Oddometer: 188
It's not the outside rubber that seals the metal cap. I think it's un inside rubber o-rong that seals the bearing-pen and the metal cap under the upper tropple clamp.
Thanx for your reactions
Regards
Todo es possible, para nada es seguro!
mooi spul ... hé!
www.lc8.nl
benzine is offline   Reply With Quote
Old 02-06-2013, 10:13 AM   #17
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,138
Regards
I just looked at the parts book, and shows nothing between the metal cap, and the T-clamp. The pic does show a sealing ring between the cap, and the bearing. It is labeled "54601184000 STEARING HEAD GASKET TOP."
I haven't had mine apart for a while, but I think the seal is so labeled because, as Hipster said, it is not a standard o-ring.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 02-06-2013, 10:19 AM   #18
benzine
adv
benzine's Avatar
Oddometer: 188
Yup! Seen it at KTM-Parts.
Thnx
mooi spul ... hé!
www.lc8.nl
Old 02-10-2013, 05:12 AM   #19
go2cnavy
go2cnavy's Avatar
Oddometer: 519
That small o-ring is in the wrong spot.
There should be large rubber circular rubber gasket that goes around the diameter of the head tube after the top bearing goes in... Then the metal top plate sits above the bearing under the top triple clamp with the small o-ring on top of it.
If you look under the top triple, you'll see a small recessed ares where this mysterious small o-ring is supposed to seat.
go2cnavy is offline   Reply With Quote
Old 03-04-2013, 05:55 AM   #20
Hipster
Hipster's Avatar
Oddometer: 1,775
Anyone have a photo showing this small 0-ring? What size it is, it's not shown in the microfsich?
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is online now   Reply With Quote
Times are GMT -7.   It's 08:45 AM.
