Old 12-17-2012, 07:26 AM   #1
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,042
Question Leather side bags on R80G/S
I think leather side bags would looks cool on R80G/S. Did anybody try to install leather side bags? I know ST supposed to come with them but I can't find any pictures or info on such bags.
Thanks,
Andrew
motogon is offline   Reply With Quote
Old 12-17-2012, 10:55 PM   #2
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 740
I have never seen leather panniers fitted to either a G/S or an ST, I have tried using throwovers on my G/S but the strap between them was not long enough due to the offset of the exhaust. You might have to have some custom made to fit over the original pannier frames.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 12-18-2012, 05:08 AM   #3
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,042
I want something like this but taller.
Andrew
Old 12-18-2012, 08:32 AM   #4
slmyers
Oddometer: 24
Leather panniers
No longer available from BMW, but have a look at these.
http://www.maxbmwmotorcycles.com/fic...3&rnd=08102012
slmyers is offline   Reply With Quote
Old 12-18-2012, 09:27 AM   #5
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,706
You can't see the rear one too well, but the three bags all held together and could be taken out as a unit in 5 minutes or....separated. Made some carboard patterns, flew all the way east to my friend the cobbler and then we started cutting/sewing. Designed some simple SS brackets, couple holes in the subframe side plate, never failed/galled or cause corrosion problems.
Brackets....because someone asked before, they looked like that,quick plan and scribbles off the top of my head because the bike was sold....no pics.
Note that I have the BMW mounts on there, also had another set of even older leather bags, I'd mount those to travel for weeks, then remove them and the OEM brackets and use the upper bags only for day to day use. 5 bags on the road.....more than enough.
Thinking of doing something like that for my K, that may be difficult re: the seat/luggage plate angles but not impossible.
Have tools, will travel!
Old 12-25-2012, 12:04 AM   #6
Ua the Destroyer
Ua the Destroyer's Avatar
Oddometer: 237
I know its an r100 but you get the idea
I made these for the r100 when I had it. I think leather panniers look great on an airhead. They had an abs stiffener I sewed into the backsides, and mounts added to that to fit the oem pannier racks. Used them stuffed full all the way to laguna seca and back last year. I've been thinking of making a set for my 1150, just not sure if they'd look right on it.
Ua the Destroyer is offline   Reply With Quote
Old 12-25-2012, 06:14 AM   #7
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,042
Looks cool, where you get that?
Andrew
Old 12-25-2012, 09:49 AM   #8
Ua the Destroyer
Oddometer: 237
I made them. Thick saddle leather sewn together and i used brass hardware and rivets throughout.
Old 12-25-2012, 10:41 AM   #9
squish
Out of the office.
Oddometer: 6,298
Look at horse places they will know someone who can make a saddle bag.
Edit more info.
Ok now that I'm sitting at my computer here's what I've found
There are a number of places that cater to the horse crowd, you can normally get them to build you a set for around 150-500 (or more if you want to spend that much)
But remember these are for horses so you might have to work with them to get the right dimensions.
I've found that the once ridgid boxes will start to get soft and formless if there's a lot of weight carried in them, or if they get really wet often,
That can be solved by making stiffeners inside the bags and a kind of "L" shaped bracket that the bag sits on supporting the weight.
When I was thinking about this style of bag I worked out a way to make a kind of hoop that hooked onto the stock R80ST bag mounts while supporting the bottom of the bag.
As far as I know BMW only offered leather bags as an accessory, those bags had kind of funky proportions, tall, skinny and narrow, more vertical then horizontal.
You had to get a different frame for them.
If you don't mind smaller bags, look toward the retro hipster bicycle culture where there are a lot of options for leather and waxed cotton and leather bags.
On vacation for a spell
squish screwed with this post 12-25-2012 at 03:22 PM
squish is offline   Reply With Quote
Old 12-25-2012, 11:41 AM   #10
Ninthlord
Cadmium Enriched
Ninthlord's Avatar
Oddometer: 283
Check it out
Harley dyna rigid leather. Got 'em at a Harley swap meet for $15.
-CG
Ninthlord is offline   Reply With Quote
Old 12-25-2012, 12:33 PM   #11
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,042
Can you post close-up pictures of the bag? What is measurements of your bags?
Andrew
Old 12-25-2012, 12:36 PM   #12
motogon OP
Like wind
motogon's Avatar
Oddometer: 1,042
Good price, but I like rectangular bags.
This one looks perfect to me!
Andrew
Old 12-25-2012, 03:08 PM   #13
Ua the Destroyer
Oddometer: 237
When I get home ill find some bigger pics of them. They're gone with the bike but I might have saved the pattern at work.
Old 12-25-2012, 03:33 PM   #14
_cy_
Oddometer: 6,312
that looks kick ass!! how's the size compared to stock bmw hard cases?
Old 12-25-2012, 04:35 PM   #15
kels
Oddometer: 17
Beautiful bike, what is the make, model, and year?
kels is offline   Reply With Quote
Times are GMT -7.   It's 01:15 AM.
