Old 12-17-2012, 04:06 PM   #1
MudratinOz OP
Adventurer in training
MudratinOz's Avatar
Oddometer: 795
sidestand help
My sidestand switch hasnt worked for some time, so decided it was time to get it sorted.
If my understanding is correct when these fail the bike will not start, but that is not the case with mine, aways able to start the bike regardless of wethr the stand is down or not.
anyway removed the switch to clean and test the switch and out of curiosity tried starting the bike with the switch removed, bike started no problems.
I thought that with the switch dissconnected ie open circuit, then the bike should not have started, am I on the right track here ??
switch tested ok
Next thing that has me guessing is what to check next and why bike started ?
KTM 2012 990 ADV ABS - BLUE
The orange does grow on you. You will not notice it at first..but it starts with a few innocent KTM stickers,.progresses to a KTM key ring, to KTM coffee mug and next thing you know, you have gone completely mad and start wearing orange tee shirts.It is a very bad infection..is this yeast infection (Bronx)
MudratinOz is online now   Reply With Quote
Old 12-17-2012, 04:55 PM   #2
spafxer
spafxer's Avatar
Oddometer: 2,333
Try putting it in gear with the wires open. It should die.
spafxer is offline   Reply With Quote
Old 12-17-2012, 05:00 PM   #3
MudratinOz OP
MudratinOz's Avatar
Oddometer: 795
Just tested it all again, bike starts regardless of whether switch is connected or switch position or if in gear.
Old 12-17-2012, 09:55 PM   #4
spafxer
spafxer's Avatar
Oddometer: 2,333
Any chance a previous owner bypassed the safety switches in another location? It doesn't necessarily have to be done at the side stand.
It is also possible to bypass the clutch switch. If this was done then the starter can be engaged with the bike in gear and clutch released. Be ready for the jump forward !
Old 12-18-2012, 05:29 AM   #5
MudratinOz OP
MudratinOz's Avatar
Oddometer: 795
Yes after re-reading the H.O.W I'm thinking next course of action will be to check for Clutch bypass and Gear selector bypass, but I'll wait till I have the tanks off next or I get bored
Old 12-20-2012, 06:19 PM   #6
AirDale
AirDale's Avatar
Oddometer: 18
What I found with my 2007 SE was it would start and go into gear but when I began to release the clutch the engine would die. I ended up cutting the switch wire after the last connector and wiring the red and black wired together and left the blue wire with no termination, wrapped it all up, plugged it back together and it worked as it should. No aftermarket plug and no wait and no $30.
AirDale is offline   Reply With Quote
Old 12-20-2012, 09:17 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,156
The 950 ADV and the SE use different systems to detect the side stand position and therefore one modification will not work on the other. The ADV uses a physical rotary switch where the SE uses a hall effect switch. The 990 is different as well, 2.2k ohm resister between blue and pink will keep the ECM happy, splicing them directly together will not work. The 950 ADV will work by tying the green and black together.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is online now   Reply With Quote
Times are GMT -7.   It's 04:53 AM.
