Old 12-17-2012, 06:45 PM   #1
Baiazid OP
Baiazid's Avatar
Oddometer: 178
F800GS unstable at higher speeds
Hi,
recently I had 30.000km service and I asked them to replace tires as well.
Service consisted also in changing fork oil.
I have now Haidenau K60.
I went for a trip next day after the service and noticed on highway when I go beyond 110kmph, bike starts to be very unstable. Front fork starts to shake semi-violent (left and right). If I slow to 105 .. all is fine.
Before this I used to go 160kmph with no drama.
What can be?
Baiazid is offline   Reply With Quote
Old 12-17-2012, 06:53 PM   #2
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,269
Did they balance the tires? If the aignment was off it would track funny but since it's speed related I'd say an out of balance front wheel. Bent rim?
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 12-17-2012, 07:18 PM   #3
Baiazid OP
Baiazid's Avatar
Oddometer: 178
Saturday I am going again into the service.
Rim has a small bend (had that for last 2 years) and never affected my stability at any speed.
Tires look balanced (they have extra weight added on one side) but I cannot tell if was done properly.
Old 12-17-2012, 08:05 PM   #4
sorebutt
Oddometer: 1,933
If it is a tire balance issue it should be an up down type vibration. I'm gguessing front wheel alignment. Loosen the pinch bolts that hold the axle on one side. Then bounce the front end up and down a number of times. Then tighten the pinch bolts and take it for a spin.
sorebutt is offline   Reply With Quote
Old 12-17-2012, 10:32 PM   #5
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Could be a bad tire. Ive had a few sets of TKC 80's that got the death wobble over 80 mph.
Did they mount it right?
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 12-17-2012, 10:34 PM   #6
catweasel67
Oddometer: 8,856
sounds lke a wheel balance issue to me - maybe a weight fell off?
catweasel67 is offline   Reply With Quote
Old 12-18-2012, 03:42 AM   #7
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 283
It's most likely the tire, there are a few threads about K60's doing this when brand new and it goes away after a few hundred miles of break in
Angryrican is online now   Reply With Quote
Old 12-18-2012, 04:38 AM   #8
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,772
<-- What he sais. It'll go away after a couple hundred miles. Gives you another reason to get the bike out there and ride it... It's for safety reasons of course
Loutre is offline   Reply With Quote
Old 12-18-2012, 05:25 AM   #9
JRWooden
Oddometer: 4,293
A:
Do you know how that works?
What's going on in the first few hundred miles?
Old 12-18-2012, 05:30 AM   #10
ragtoplvr
Oddometer: 6,531
check your tire pressure. Now. Unstable on a motorcycle is most commonly a low or over inflated tire. You can pick up a nail in the dealer parking lot. If pressure is right, then you can look for other stuff. If you are recommended to run 42 psi for tire life, try the recommended pressures in your manual.. The longer life might not be worth it.
Rod
ragtoplvr is offline   Reply With Quote
Old 12-18-2012, 05:41 AM   #11
Dr E
Chasing after theory
Dr E's Avatar
Oddometer: 143
Have you checked your preload on your rear suspension? When that gets off, one of the signs will be front end wobble or instability.
Good luck!
Life is the last thing you experience before you die...living is what you do every day to get you to that point...
Dr E is offline   Reply With Quote
Old 12-18-2012, 07:59 AM   #12
runnin4melife
Oddometer: 806
I don't take my TKCs above 80mph because it feels as if the bike is floating, put a set of road tires and I can go well over 120 with no problem. Same rims, same suspension just the tires. Some are worse than others, My first set of TKC80s, the front was really bad but I didn't have my new suspension then so I just rode it out and they went away (I pulled and checked balance, and whether the rim was bent or true, all was fine). I have never ran the K60s so don't know about them. I was looking at them for my Alaska trip so I hope they don't have an issue at 80+...
runnin4melife is offline   Reply With Quote
Old 12-18-2012, 10:23 AM   #13
DoWorkSon
Oddometer: 276
Just got k60's on my F8... They are fine at 80mph+... No issues, feel similar to stock street tires..... They have less than 50 miles on them too. Just a slight vibration at low speeds(15 mph), but not bad
DoWorkSon is offline   Reply With Quote
Old 12-18-2012, 01:27 PM   #14
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 283
Originally Posted by JRWooden View Post
A:
I don't, I'm going by the scientific evaluations of the members of this forum
joking aside it's mention quite a few times in this forum in different tire threads, I personally have never had the issue but I'm am super anal about tire pressure setting on and off road and dialing in suspension
Old 12-18-2012, 06:40 PM   #15
JRWooden
Oddometer: 4,293
Originally Posted by itsatdm View Post
I have posted this before without any feed back. A 15 min free mod, what do you have to lose?
Feedback: It worked for me, thanks Gary!
Times are GMT -7.   It's 12:23 PM.
