Old 12-19-2012, 04:31 PM   #1
grumpyman OP
Oddometer: 84
950 clutch line routing
the clutch line on my 950 run through a triangular bit of plastic just behind the steer tube
is there a reason i should not route it above this and then come back along the normal route
my issue with running it through the plastic is that it is held in place by the radiator and it looks like i will have to take both tanks off and let the rad hang to move this bit of plastic
grumpyman is offline   Reply With Quote
Old 12-19-2012, 05:15 PM   #2
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,401
My clutch hose is routed through the same plastic gizmo as the brake hose, and the choke cable. It is on the front of the top triple clamp.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 12-19-2012, 05:29 PM   #3
grumpyman OP
Oddometer: 84
different bit of plastic
the bit of plastic i am talking about is behind the lower part of the steerer tube about ten inches further along the line from the bit your referring to
Old 12-19-2012, 06:58 PM   #4
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
I don't see anything like that on mine, but it is a very early model. I think the later models had some plastic parts in that area that mine does not.
Sorry I couldn't help.
G.H.W.S. 1878-1962
Old 12-19-2012, 09:28 PM   #5
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
The 950's just ran them down the inside of the frame, sort of in where that plastic bit sits and then down the side of the airbox.
I haven't paid that much attention to the routing on my 990. But either way as long as you don't pinch it, let it come into contact with something that will allow it to melt or have rub thorugh, I can't see that it would make any difference how it is routed.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 12-19-2012, 11:15 PM   #6
grumpyman OP
Oddometer: 84
thanx
i am guessing the p.o. did when he was doing some electrical nonsense and had everything off...
Old 12-20-2012, 09:05 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,582
Yes, you need to remove the mounting bolts from the radiator to get that plastic triangle piece out of the frame section just aft of the steer tube. From the KTM factory the clutch hose is routed through there and by the plastic insert, its a tight fit on the hose.
Keep in mind that this triangle part did not show up until 2005 if I recall correctly... the early bikes did not have it... and that whole area behind the steering tube would get packed with road debris.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 12-20-2012, 09:45 PM   #8
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
Do you think this would be a good retrofit?
G.H.W.S. 1878-1962
Old 12-21-2012, 01:42 PM   #9
grumpyman OP
Oddometer: 84
i just cut the old line
and ran the new one above the little plastic bit...
in hindsight i guess i could have loosened the other tank and the radiator
but i kept thinking that i was going to have to drop both tanks and looked for another way to route it
Old 12-21-2012, 04:59 PM   #10
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
I can't see the point - my '04 never collected road debris in that area.
Old 12-22-2012, 09:47 PM   #11
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,582
If its not fitted with one, yes I think its a good update. They are cheap
Part Number: 60003087000
Description: SPLASH PROTECTOR FRAME 05
all of about $4 USD
Old 12-23-2012, 11:15 AM   #12
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
all of about $4 USD
Thanks.
Though it hasn't been a big problem, some mud has collected there, and is annoying.
G.H.W.S. 1878-1962
Times are GMT -7.   It's 02:49 AM.
