Old 12-19-2012, 06:11 PM   #1
Zane Neher OP
Zane Neher's Avatar
Oddometer: 163
Clutch adjustment/Cable/screwed?
*I try using the search function but just seems that it only shows "new posts"..
*Is there an online Manual for 91 era DR250/350s?
I think I figured out the clutch cable adjuster but not entirely sure.
The problem I am having is I smelt something burning last night while out and about. Got home and removed the tank to see if anything was actually burnt, nothing. After checking front caliper to see if it was seizing I called it a night early. After work I couldn't get the bike started (Kill switch, Im an idiot) so I tried jump starting it. While the bike is in gear, I could hardly push the bike with the clutch lever pulled in. I assume this isn't a normal issue for this bike?
Also, while we're at it. I use Rotella in all of my other bikes. I'll assume it's equally as safe for this bike?
Im learning fast that this bike is not at all like a cruiser or sportbike..
Zane Neher is offline   Reply With Quote
Old 12-19-2012, 06:59 PM   #2
mcma111
mcma111's Avatar
Oddometer: 11,899
Well you certainly didn't smell the clutch burning.
Because it's inside the engine!!!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-19-2012, 09:00 PM   #3
Zane Neher OP
Zane Neher's Avatar
Oddometer: 163
Ha, fair enough.
I did find an online manual for a 350.
Old 12-20-2012, 02:48 PM   #4
JensEskildsen
Oddometer: 1,012
Originally Posted by Zane Neher View Post
While the bike is in gear, I could hardly push the bike with the clutch lever pulled in. I assume this isn't a normal issue for this bike?.
Yes it is, it gets smoother as the oil warms up, but here will still be some "drag"
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Times are GMT -7.   It's 03:12 AM.
