12-20-2012, 01:04 AM
#1 |
Oddometer: 108
Disabling the ABS system
Anyone know how to permanently disabling the ABS system on the 990 adventure
12-20-2012, 05:10 AM
#2 |
Forest Flyer
Oddometer: 4,831
Lots of these guys know. It's been talked about enough.
Google: site:advrider.com "orange crush" disable disconnect abs Essentially, buy some "S" parts that never saw ABS
.....Ride Oregon First "got no problem with keeping truly roadless areas as wild.... On the other hand, if it has been logged or mined and roads already exist,, ...then that land should be open for public use" (peterman) |
12-20-2012, 08:08 AM
#3 | |
Wile E Coyote SuperGenius
Oddometer: 1,164
http://www.advrider.com/forums/showt...6#post20257686 |
12-20-2012, 09:44 AM
#4 | |
Oddometer: 1,020
Just move the rear sensor away from the the ring... put a washer behind it. or get an S rear brake line and plug the outlet in the pump, and have just abs on your front wheel only, and never have to worry about tuning it off when offroad. One of the best mods I have done.
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
12-20-2012, 10:05 AM
#5 |
Two Wheeled Addict
Oddometer: 5,240
First I have heard of this Mod.
Speed bumps never seem to make me go any faster |
12-20-2012, 12:13 PM
#6 |
Oddometer: 1,020
I'm not the 1st to do it, been around for a while.
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! Dusty screwed with this post 12-20-2012 at 05:53 PM |
12-20-2012, 05:49 PM
#7 |
incognito
Oddometer: 15,957
Just pull the ABS fuse.
the sun does not have no prisoners |
12-22-2012, 05:21 PM
#8 |
Unbunch yer panties!
Oddometer: 1,107
Um, no. This nukes the speedo on later 990s.
Unplug or move the rear sensor, this will fault the system and you will be good. I'd like to know more specifics about the rear S line mod above.... S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
12-22-2012, 06:24 PM
#9 |
Oddometer: 1,020
From the what did you do thread... you posted on the page..
I removed the 2 lines to the pump and plugged the holes, got a line for the S and bled. I really like this setup... can still steer with the back when needed and for the panic situations when flying down the gravel and unexpected critters pop out... no freakin out on the front is nice.
