Old 12-20-2012, 07:50 AM   #1
Lupus60 OP
Lupus
Lupus60's Avatar
Oddometer: 4
Wossner hi-compr for DR 650 se
I put the DR 650S piston engine Wossner high COMPR. After examination of the pressure in the engine is turned 10 atm. Before replacing the engine was 9 atm. I have a question to colleagues who do the same or not has no effect on engine life? Thank you Google and you;)
Lupus60 is offline   Reply With Quote
Old 12-20-2012, 12:52 PM   #2
NJjeff
NJjeff's Avatar
Oddometer: 1,089
The DR650 has an automatic compression release.
At engine cranking speeds the exhaust valves are held open for a moment to bleed off some pressure making it easier to crank over.
This will prevent you from taking any kind of meaningfull reading.
On the cam there is a small weighted arm with a spring. At very low speeds this arm is held inward by the spring. The other side of the arm has a small finger that briefly opens the exhaust valves.
Once the engine starts up the spring is overcome by centrifugal force and the arm swings slightly outward. This moves the finger and allows the exhaust valves to function mormally.
NJjeff is offline   Reply With Quote
Old 12-20-2012, 01:12 PM   #3
Lupus60 OP
Lupus
Lupus60's Avatar
Oddometer: 4
Thank you! My problem is this: I'm going far away to Mongolia, fuel in this area is less than 90 oct. I'm afraid combustion detonation! I do not know how it will affect the durability of the engine. I'm sorry, but I have to translate the text;)
Old 12-20-2012, 01:40 PM   #4
NJjeff
NJjeff's Avatar
Oddometer: 1,089
I can only speak of gasoline in the U.S. But in my DR all I have ever used is Regular (87) octane.
My bike has an un-modified engine. I have never had it ping and the bike has 37k Miles (59,000 Km).
I know there are several octane measurment methods, is 87 in the US the same as yours. I cannot say.
Mongolia sounds great. Please take pictures and post a ride report for all to enjoy.
NJjeff screwed with this post 12-20-2012 at 05:31 PM
Old 12-20-2012, 01:49 PM   #5
Lupus60 OP
Lupus
Lupus60's Avatar
Oddometer: 4
I hope everything will be fine. Photos of the show, of course, Mongolia. Now only winter ...
http://www.youtube.com/watch?v=dvp7hhnodIY
Times are GMT -7.   It's 05:56 PM.
