Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 01-26-2013, 10:30 AM   #121
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,681
Originally Posted by Steve in NZ View Post
i found spectro oil solved the box issues.
Steve, can you expand on that? anyting to make a beemer box more smooth interests me. I usually just bung old EP 90 in there.....
Voltaire is offline   Reply With Quote
Old 01-26-2013, 10:58 AM   #122
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
Originally Posted by cooneyr View Post
Other thing to worry about is pace - enough so can maintain balance, not too much to stall or come to a stop if you hit a sizeable rock or so that you get downed by your bow wave. Mid revs first gear normally is about right.
Your welcome to come practice. Plenty of places down here to play ;)
Cheers R
Yes, I think really struggle with the right pace. I'll need to find someone who can dig a ditch and fill it with rocks and water, never mind the current. That would be a good practice. I think they do that at those fancy Enduro courses overseas.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 01-26-2013, 11:02 AM   #123
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
Originally Posted by Padmei View Post
Have you had a look at your pushrod piston thing? I have always had a hard time changing between 1st & 2nd or finding neutral when hot. I have found it is the same on both gboxes. I thought I had cracked it when I gave the piston a good sanding.
It seemed to do the job for a while however noticed it's still quite hard.
That's my next job. I have the old metal version in there. Does anyone know if they made different strength clutch springs for the various bikes? Because my clutch is not original.
R1150GS
R80GS Basic
Old 01-26-2013, 11:18 AM   #124
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,681
For airheads there are two pressure plates, a std one and heavy duty one, The R65 was 'catching' on changes so will report back next week on if its better, I pulled out the clutch pushrod assembly, cleaned it, greased it. the roller bearing on the pivot arm was seized, so that should be better now.
Old 01-26-2013, 11:46 AM   #125
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
I've put up with this for several years and will be kicking myself, if it's an easy fix. But hey, I'll take it.
R1150GS
R80GS Basic
Old 01-26-2013, 12:03 PM   #126
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,045
2 of my BMWs having had horrible gearboxs. Hard to change gears, find neutral etc.
put Spectro oil in the gearbox and huge transformation. i think Spectro used to supply BMW with the branded oil they sold.
unsure if they still do.
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Old 01-26-2013, 12:51 PM   #127
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
I found these relays on the the Supercheap website, but haven't got a clue which one would work.
R1150GS
R80GS Basic
Old 01-26-2013, 01:56 PM   #128
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,363
What do you want that replay to do? That relay might work for accessories like lights & horn, where you need a feed directly from the battery.
LED flasher here. But that wont work with your switches or wiring.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 01-26-2013, 05:07 PM   #129
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
I was hoping that for this sort of money the relay would know what to do. Thanks, now I know what to get. It just seems like less of a hassle to buy the proper flasher, than to piss about with resistors.
With the flasher I will be able to change the rear indicators as well. I've never like them, they get knocked off, or vibrate loose by themselves. They also make Basil look porkier than he really is. If Steve B would finally send me my LED tail light, I'd be almost set.
Now all I'll need is for someone to come up with a plug and play LED headlight.
R1150GS
R80GS Basic
Old 01-26-2013, 05:31 PM   #130
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
Apparently, all I need to do is to connect the two point where the red line is.
I had no idea what I was looking at. It's bloody big.
The search continues....
R1150GS
R80GS Basic
Kokopelli screwed with this post 01-26-2013 at 05:48 PM
Old 01-26-2013, 05:58 PM   #131
Phreaky Phil
Oddometer: 1,890
The forks were great, taking some big hits without problems. The hardest bit I did would have been going up the Carrick Town track, at the end of a long day. Because of the exposed rock, it had potential for pain and breakage. We had sections of loose crushed rock to cross and the Lammermoors were rutted and wet in places, but it was great fun going though there.
Apart from the having a really heavy clutch, the R80 went well. Very comfortable and surprisingly agile. On gravel it will keep up easily and the on more technical sections it will get through. Water crossings were terrible. I just hate stalling in deep water. But I just don't have all that much experience with the deeper ones. I like short sharp and fast :-).
Have you fitted a new clutch cable. My clutch used to be heavy, ( I rode another Basic and couldn't believe hoe light the clutch was) and even though the cable appeared ok and was lubbed, I put a new one in. What a difference. It is lighter pull than my DR
Phreaky Phil is offline   Reply With Quote
Old 01-26-2013, 07:46 PM   #132
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
Voltaire was just here a moment ago. We unhooked the cable and you could well be right. I've never lubed the cable, because I thought they were teflon coated and should not be lubed. Teflon can swell up when in contact with oil.
I'll order a new cable and then I'll know.
R1150GS
R80GS Basic
Old 01-26-2013, 09:26 PM   #133
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
I couldn't find a sheepish grin icon, so this one must do. After Voltaire left, I went and lubed the cable with fork oil. It's all I had. It made a huge difference. I can still feel and hear a bit of roughness, so I am guessing that the old cable has done some damage inside the sleeve. I've just ordered a new cable from Motoworks. Do new cables have to be lubed?
The old cable did not last long in this case, but I never lubed it, because I read somewhere that BMW cables were teflon coated and did not react kindly to lube. Oh well, at least I'll have developed some grip strength in my left hand.
R1150GS
R80GS Basic
Old 01-26-2013, 10:18 PM   #134
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,363
I don't lube for the same reason. BUT you can get teflon based lube.
Another thought - is it BMW or Venhill?
Old 01-26-2013, 10:42 PM   #135
Kokopelli OP
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,704
The cable came from motoworks.
R1150GS
R80GS Basic
Times are GMT -7.   It's 10:33 AM.
