Old 12-23-2012, 12:49 AM   #1
bcfellow OP
Oddometer: 22
SAS removal resistor - double check
I've read the threads on the SAS removal (and appreciate the great help it's been), but I wanted to double check the range of the resistors. I threw my multimeter on the SAS valve and the whatchamacallit up at the front that goes to the canister and I got roughly 19 ohms and 26 ohms (or thereabouts).
In all the threads I've read, people are using 20 kOhms to 22kOhms (20,000 - 22,000). Is my multimeter off, or is the resistor value up in that range due to increased resistance when operating, or other?
Thank you for the time and help.
bcfellow is offline   Reply With Quote
Old 12-23-2012, 02:19 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
If you have a TuneECU cable, you can disable SAS. No lights / error codes will be thrown.
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 12-23-2012, 03:50 AM   #3
Steveman
Steveman's Avatar
Oddometer: 470
put a plug in the return line of SAS. done.
Steveman is offline   Reply With Quote
Old 12-23-2012, 05:19 AM   #4
Peanuts
Peanuts's Avatar
Oddometer: 1,029
Higher resistance means less current, this means you can use a lower wattage resistor. I use 22k 0.25 watt and works fine.
Peanuts is offline   Reply With Quote
Old 01-20-2013, 05:41 PM   #5
Supahflid
Wheelieless
Oddometer: 2,903
So does that mean remove all the equipment, turn off the SAS and don't install a resistor? Is there also an "on/off" for the charcoal canister?
Supahflid is offline   Reply With Quote
Times are GMT -7.   It's 05:51 AM.
