Old 09-09-2013, 12:56 AM   #1561
Northern TerraTory
Location: Darwin,Northern Territory-The Top End of Australia
Oddometer: 15
Fitting new sprocket?
Ok, another stupid question, or questions. I need to install my new 15T sprocket and I've never done it before (first bike in years). I am mechanically minded though, and have pulled apart and rebuilt things all my life, so don't panic!
I assume I will need to readjust the chain after, so do I just loosen the wheel nut and 'tentioners' to fit the new sprocket? Does the bike have to be on a stand? Or can I get the old one off and the the new one on without touching the rear wheel? Nah, didn't think so.
I haven't got a torque wrench, but I suppose that's a must? Torque settings anyone?
Any other advice most welcome!
Northern TerraTory screwed with this post 09-09-2013 at 01:49 AM
Northern TerraTory is offline   Reply With Quote
Old 09-09-2013, 02:00 AM   #1562
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,242
19,0 Nm torque.
I would loosen the rear axle, and tensioners. With enough slack in the chain you should be able ot lift the chain off of the front sprocket and then remove the sprocket.
Mine didn't require heat or a gear puller and just slid off.
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 09-09-2013, 05:33 AM   #1563
Northern TerraTory
Oddometer: 15
Originally Posted by RuggedExposure View Post
19,0 Nm torque.
Cheers RE.
Old 09-09-2013, 05:38 AM   #1564
Chuffa
TR650 Terra
Chuffa's Avatar
Oddometer: 160
I don't take a torque wrench out on the trail so I get a feel for the torque by using a spanner (or socket), make a mental note of the starting angle, loosen the nut & then tighten it back to the starting angle of the spanner. Repeat a couple of times until you're comfortable you'll remember the force needed. Easy.
Chuffa is offline   Reply With Quote
Old 09-09-2013, 12:13 PM   #1565
Pacificus
Oddometer: 60
Originally Posted by kurvenkrycher View Post
The Hepco Becker replacement rack ist around 100Euro - without pannier racks. So it may be worth checking the price at your place, if available.
Thanks but I think that is only a plate to bolt to the plastic factory rack.
I'm going to attempt to make my own rack, and pannier holder & panniers. I'm also going to look into making my own crash bars and engine guard. If I were to buy all these things it would almost double the cost of the bike! I really don't know how these manufacturers can charge so much for such simple things made of basic materials. I don't mind paying a fair price but the prices I've seen are outrageous.
Pacificus is offline   Reply With Quote
Old 09-09-2013, 12:13 PM   #1566
Pacificus
Oddometer: 60
Originally Posted by DirtyOldMan View Post
I dumped mine at 50 mi. or 100 can't remember. Oil only no filter. Then changed oil and filter at 600. Used dino oil not synthetic. Then at 1500 mi. I changed oil and filter and went to synthetic.
Probably excessive, but it's my first brand new bike in a long time and I was susceptible to old wives tales and other rumors.
Originally Posted by RidingDonkeys View Post
TCI's racks are on the website now, to include a tail rack. Tom hopes to be shipping by October.
https://tciproductsusa.com/index.php...th=144_155_213
Sent from the voices in my head and transcribed by their drinking buddy...
Thanks.
Old 09-09-2013, 01:35 PM   #1567
IgnacioB
IgnacioB's Avatar
Oddometer: 83
Originally Posted by robl110 View Post
Any tall guys riding a Terra? I am 6' 5" and currently riding a plated CRF450X.
6'4" 250# coming from a plated XR650R and LOVE it! Strada, but Terra-fied when I want it to be. I've got 5K on the odo since May riding the fine-for-me-stock-seat and planning to ride the UTBDR from Washington State next year.
'13 Husqvarna Strada (with Terra option)
'05 Yamaha FJR1300 - 158K miles
'05 Yamaha FJR1300 - 30K miles
My Motorcycle Blog
IgnacioB is offline   Reply With Quote
Old 09-09-2013, 01:46 PM   #1568
robl110
robl110's Avatar
Oddometer: 44
Nice! Any modification done like bars/riser or does it fit well in its stock form?
robl110 is offline   Reply With Quote
Old 09-09-2013, 03:10 PM   #1569
IgnacioB
IgnacioB's Avatar
Oddometer: 83
None at this point. I haven't found a reason to change...but I'm not a guy that stands up on my motorcycle for 100 miles at a time....maybe a mile at a time.
My Motorcycle Blog
Old 09-09-2013, 04:28 PM   #1570
huskyKT
huskyKT's Avatar
Oddometer: 94
Originally Posted by hansi View Post
Got 6100 miles on my front tire now, still does the wobble and weave at 80 miles+. I think its broken in by now?
Weave only improves a little if I load up my tankbag with a full camelback and other weighty stuff, but will not go completely away.
Just about to spoon a set of Karoo 3 on, will install and balance myself, maybe that will make the difference.
Check the triple tree nut. Then, with no weight on the front wheel, loosen the axle and pinch bolts. Loosen the lower triple tree clamps. Wiggle everything a bit and start tightening in this order. Axle bolt, pinch bolts then triple tree clamps.
Sent from my iPad using Tapatalk HD
HuskyKT
If it ain't dirty you ain't riding enough!
Husky TR 650 for the dirt
Suzuki GV1200 Madura for the road
huskyKT is offline   Reply With Quote
Old 09-09-2013, 05:08 PM   #1571
Northern TerraTory
Oddometer: 15
19,0 Nm torque.
Jeez, 19NM? I could nearly do that by hand. Oh well, a dab of locktite will ease my mind.
Old 09-09-2013, 08:16 PM   #1572
DirtyOldMan
Oddometer: 1,900
How tight should the triple tree nut be?
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Old 09-09-2013, 08:35 PM   #1573
hasenpfeffer
hasenpfeffer's Avatar
Oddometer: 268
Is the triple tree nut the same as this spec in the workshop manual?
Fastening of steering upper plate nut 80,0
hasenpfeffer is offline   Reply With Quote
Old 09-09-2013, 10:01 PM   #1574
kurvenkrycher
n00b out of passion
Oddometer: 9
No, it's not. However, doing one your own is always the better choice.
kurvenkrycher is offline   Reply With Quote
Old 09-09-2013, 10:11 PM   #1575
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 302
Thanks, will do.
2013 Husqvarna TR 650 Terra
Never let your love run cold
hansi is offline   Reply With Quote
Times are GMT -7.   It's 11:31 PM.
