Old 03-14-2013, 07:05 AM   #436
trapperj
Oddometer: 494
Fan
I have 1200 miles on my TR and I don't remember my fan ever comming on. It's been cold here in east TN ..but I have put some fairly aggressive miles on the bike. It's idled for 10 minutes or so and the temp gauge may just touch 1/2 or a bit more on the gauge. I know when the Moss was done a few weeks back the dealer had the bike idle for a good bit. I would think if a bike shuts off after a short idle time in cold weather...something wrong! Maybe a couple of air bubbles that fools the sensor into thinking the bikes burning up?
trapperj is offline   Reply With Quote
Old 03-14-2013, 07:35 AM   #437
Harder1
braaaap!
Oddometer: 60
Brake Light fix
We need to develop a list of things for new owners to look out for. So far we have:
-Lean mixture (MOSS fix)
-Air in coolant system (Burping fix)
-Brake light stays on (Still haven't tackled this myself but someone else on here did)
-Rear fender cracking (Tail dong needs removed /lightened)
Anything else?[/QUOTE]
Hey Rugged, here's a link to some pics. Simple fix. Cheers,
http://www.cafehusky.com/threads/if-...e-light.29590/
Harder1 is offline   Reply With Quote
Old 03-14-2013, 08:29 AM   #438
Roadscum
Oddometer: 2,395
Perhaps the over heating is caused by an air bubble in the coolest circuit.
Seems the symptom point to that.
Regards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 03-14-2013, 10:13 AM   #439
Blaise W
Blaise W's Avatar
Oddometer: 676
One of the first things I did on both my Husky's was to drain, flush and fill the cooling system. Why? Because nobody could tell me for sure what kind of coolant was in it. Regardless, on refill I made sure to circulate the coolant and purge air from the system. No overheating issues so far, but Summer is coming!
Blaise W is offline   Reply With Quote
Old 03-14-2013, 10:29 AM   #440
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
No doubt! I hvae to do this today, because tomorrow we start the first leg of our journey and will be going from the high 20's to mid 90's around Yuma. I can't have this thing frying on me in the middle of nowhere.
On a side note, I'm going to try and get that knobby tire on the rear today after work and get pics up.
How long do you guys think this tire (http://www.michelinmotorcycle.com/index.cfm?event=M12xc) will last?
It will be a mix of mainly dirt, rock, sand, small stretches of pavement and hiway. 1500-1600 miles most likely.
Should I haul along my Sahara just in case?
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 03-14-2013, 11:08 AM   #441
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,694
My fan turned on for the first time on Monday. The bike was idling in 70 degree weather and I was stopped at a light. I jumped, it scared me. Strange new noises from a new bike can do that, especially on your first liquid cooled bike. :eek:
Sent from the voices in my head and transcribed by their drinking buddy...
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is online now   Reply With Quote
Old 03-14-2013, 03:21 PM   #442
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
No way! You should be fine with it. Unless it starts chunking knobs at 75mph along the hot pavement. If so, slow down....
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 03-14-2013, 09:13 PM   #443
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,120
I asked the sales guy if the TR had a 'hop up' kit like my previous TE's did.... O2 sensor replaced with plug, etc.
He said there is a reflash of the ECU they can do, but recommend putting on some miles first to break it in.
That stuff is usually a hot topic in brand specific threads - I haven't run across it yet. What's the word?
Throttle response off idle is pretty fluffy until it's good and warm - though I'm completely ready to put that to it being a spanking new motor that hasn't had many heat cycles run thru it yet.
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 03-14-2013, 09:44 PM   #444
RuggedExposure
Oddometer: 1,247
On the way home today while hauling ass down the old railroad bed at 60-70, the bike got really hot. After I stopped for a second to open up some gates, the warning light came on.
When I got home I let it cool then took the cap off the radiator.
I poured in a good amount of fluid, let it run for a minute or two then shut it off to cool down again. While running it was burping out air bubbles.
A few cycles of this and I got most of the air out of the system. The bike seems to idle fine now without the fan coming on almost immediately. You would think the shops setting up these bikes would do this... what the hell did I pay for with that 'assembly' charge?
RE Fotowerks
Old 03-14-2013, 09:50 PM   #445
RuggedExposure
Oddometer: 1,247
HF
I hope you're right. This tire seems much harder than the Sahara... hope that means it lasts longer.
I haven't even had my Terra a month yet and the Sahara is wearing down. Going on 1600 miles already!
The bike sure looks more aggressive though:
Can't wait to try it out tomorrow on the 'pre-run' portion of the trip over to El Paso
RE Fotowerks
Old 03-15-2013, 01:23 AM   #446
FabOneUp
FabOneUp's Avatar
Oddometer: 137
Alright RE! . Looking forward to a ride report!
FabOneUp is offline   Reply With Quote
Old 03-15-2013, 06:54 AM   #447
wolftrax
wolftrax's Avatar
Oddometer: 444
RE I'm loving your rides. Still have a temp tag on and your groovin a gnarly knob and riding the piss out of her. Can't wait for your ride report.
Mark
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 03-15-2013, 07:31 AM   #448
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Run that tire till its a slick!
I've run a D606 until you could barely see a knobby outline remaining.....when I had to. Never gave me a problem.
Most people change tires much sooner than they really need. Sure, fresh knobs are always better, but I've taken many a good tire off the hands of someone who said it was worn out and useless.....when more than half the knobs remained (and raced on it).
So I'll run one bald before versus hauling spare rubber (on a bike this size), given the choice. It ain't like you're running unsupported thru Mongolia on this trip. I am not familiar with the particular tire you have chosen....have no idea how it wears. Just sayin most any tire should be able to survive a 1,600 mile excursion.
Adios amigo
Laissez les bons temps rouler
River-dirt-chi
HF
HighFive screwed with this post 03-15-2013 at 07:37 AM
Old 03-15-2013, 07:37 AM   #449
RuggedExposure
Oddometer: 1,247
Mark
Ha! I knew someone would appreciate the paper tag. The dealer said its good for 90 days so I might as well take advantage of that, not like they're going to run out of plates at the DMV.
My Meanstreak had 12k miles on it within the first 6 months that I bought it. Then I moved an hour closer to work for a few years. Now that I moved an hour away in the other direction (no carpools out here in BFE), it looks like the Terra is going to get the same treatment.
RE Fotowerks
Old 03-15-2013, 07:40 AM   #450
RuggedExposure
Oddometer: 1,247
Adios amigo
River-dirt-chi
HF
Thanks for the advice.
My main concern is mesquite thorns once the knobbiness is gone. I probably won't be doing much over 70 on the way home and will be using as little pavement as possible. Bullitman281 wants to check out Tombstone on the way home (if we make it that far) so I'm sure there's going to be some pavement pounding around there.
The mesquite thorns out here are horrendous but the slime does a great job fighting them off.
River-dirt-chi!
I love that movie.
RE Fotowerks
Times are GMT -7.   It's 05:25 AM.
