Old 03-15-2013, 09:26 PM   #451
kjackbrown
Oddometer: 104
TR650 debadge
Ugh...so I have been envious of those of you that removed (or maybe bought new plastics to do a color change and they were bare) the factory TR650 graphics. Just now I pulled out the hair dryer and heated up the right side "TR650" decal and began to remove it. Well low and behold Husky had applied a clear coat over the body panel AFTER attaching the decal ! Now my right side has a huge patch of non-glossy plastic that is way larger (above and below) than the decal
So my master plan was to take the TR to the local car vinyl wrap shop tomorrow to have custom graghics (SM650 tank-ish) created for the TR but now I have to re-think everything
It looks like now I may as well paint the graphics on since I need to re-clear the entire panel anyways.
I REALLY did not want to ruin the factory finish
kjackbrown is offline   Reply With Quote
Old 03-16-2013, 02:37 AM   #452
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,099
The air filter access might be of some value?
Good luck with the accent
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is online now   Reply With Quote
Old 03-16-2013, 05:10 AM   #453
RidingDonkeys
Purveyor of Awesome
RidingDonkeys's Avatar
Oddometer: 8,603
Interesting. My dealer pulled my tank decals off, so I don't know what is involved, but it only took him a few minutes and there is no sign that it was ever there. I can't imagine applying the clear coat after applying the decal. That makes no sense, and nobody else seems to have run into that. Perhaps a little buffing will smooth it?
Sent from the voices in my head and transcribed by their drinking buddy...
Sit Stay Ride: The Story of America's Sidecar Dogs
More info at www.sidecardogs.com
Clinging to sanity, one motorcycle at a time.
RidingDonkeys is offline   Reply With Quote
Old 03-16-2013, 08:12 AM   #454
BigJimWA
BigJimWA's Avatar
Oddometer: 1
Originally Posted by Nev.. View Post
I had a similar issue. Shortly after I bought my Terra I took it back to the dealer because it appeared to be down on coolant ( though it's almost impossible to see the coolant level in the overflow bottle through the viewing window even though the coolant is very dark blue colour - WTF were husky thinking ?). They added approx 50ml to bring it up to the max line. Took my Terra in for it's 1000km service a few weeks later and when I was riding it home from the shop (peak hr traffic) I noticed that the temp gauge was showing about 3/4. Prior to this it had never gone over 1/2. Next day i started it from cold at home. Within about 3 mins of stationary idling the fan came on. About a minute later the warning light flashed and the gauge showed 1/1.
Took it back to the dealer. He put it on MOSS but no fault codes. He says the cooling system wasn't touched in the 1000km service. Noted that when the warning light comes on, the fan blows cold air and the fan side of the radiator is cold but the side with the cap and the hoses is hot. Indicates the thermostat not opening I think. He took the radiator cap off and the water level is low in the radiator even though there is still coolant in the overflow.
Topped up about 200ml of coolant into the radiator and reclosed it (total cooling capacity is only a tad over 1 litre I think so this is significantly low). Since then it's run fine and the cooling operates normally and the fan cuts in/out as it should. There was no obvious sign of any coolant leakage during the first 1000km. Still puzzled where the coolant went and how it got so low in the radiator without drawing back from the overflow bottle.
Your issue sounds very similar. I'd check if the thermostat is not opening (fan blowing cold air as in my case) and then check the coolant level in the radiator.
Staying with the spirit of the thread... What temp gauge are you talking about? I haven't found mine. Christ I hate being an idiot but I should be used to it by now
-- BigJim
It's MY fantasy; My rules...so piss off!
Husqvarna TE650 Terra
Harley 1200N
BigJimWA is offline   Reply With Quote
Old 03-16-2013, 08:36 AM   #455
RidingDonkeys
Purveyor of Awesome
Oddometer: 8,603
Hit the M button on your digital dash. It will scroll through the different readouts under the speed on the speedometer. The big gauge of bars is engine temp.
Old 03-16-2013, 09:15 AM   #456
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,002
the bar graph is there no matter what the other displays are set to read though, right?
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 03-16-2013, 09:57 AM   #457
RidingDonkeys
Purveyor of Awesome
Oddometer: 8,603
Doh! You're right.
Old 03-16-2013, 10:14 AM   #458
kjackbrown
Oddometer: 104
Silicone hose set
In response to an email I sent to Samco yesterday.....
"Hi, This is a kit we would consider bringing onto production but we do not yet have it available.
If we had demand for say 10 + kits and a donor set of hoses we could definitely do something. If you were able to donate the original hoses as templates for the factory to keep and be the one to help generate theinterest through means of a forum or owners club we could supply your set foc in exchange for efforts. The tooling cost is quite high so we need tohave this minimum order to justify the start up costs. If you can initiate we can of course handle all the customers names and payments etc. We would need the pre-orders and interest 1st though to validate the tooling costs.It will take around 6 weeks for 1st off production, we would not have a price until we had a set of hoses but always a fair price just depends onhow many hoses and complexity. Let me know and look forward to hearing from you.
Best Regards Richard "
I willing to sacrifice my ride for 6 weeks of R&D if 10 people are interested.
Also, Motor Hoses emailed me back but said they were at a show in Daytona and would let me know if they are interested once they return home. I will let you know what they say.
So, anyone interested in some high quality virtually indestructible silicone silicone hoses. They come in many colors....mine will be red :-P
Old 03-17-2013, 01:17 PM   #459
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 316
Don't know if it got covered here or not. So please forgive my stupid question: Will the BMW 650 Sertao oil filter work on the Terra/Strada?
2013 Husqvarna TR 650 Terra
Never let your love run cold
hansi is offline   Reply With Quote
Old 03-17-2013, 01:25 PM   #460
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 4,970
Yes-----the motors are identical.
I just changed my filter for the first time---a bit of a messy job----no good place for the old oil to go when you pull the cover off.
It took a bit more than 2 qts. with the filter change.
BigDog
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 03-17-2013, 06:32 PM   #461
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 316
BigDog
Thanks, BigDog.
Just coming up on the 1000 mile oil change and its time to order a filter. Been eyeballing the KN 151 for the Sertao on ebay .
When I changed the oil the first time the bike took 2 liters and 250 ml (250 ml=1/2pint) to get to the upper mark on the dipstick warm. Figure having to add the additional amount of oil because I pulled the bike upright of the sidestand while draining the oil?
Just passed 900 miles on the odometer today. Bike seems to be running stronger every mile, I think the exhaust note has changed a bit too.
Really impressed what this great little bike can do- on and off the road.
Got a good bit of power improvement from this boosterplug http://advrider.com/forums/showthread.php?t=841919, courtesy of the "Wuka King"since I installed it at 300 miles.
Thought I would miss the 105hp of my Triumph Tiger 955i a lot, but to the contrary I enjoy riding my Terra way more. Tons of grin factor.
Old 03-18-2013, 05:17 AM   #462
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 16,002
my stupid question of the day:
when did torx fasteners completely take over ?
my offroad tool kit just went thru some changes
Old 03-18-2013, 06:41 AM   #463
Deans BMW
Granpa Hoon
Oddometer: 3,334
Thanks, BigDog.
Very interesting installing the Booster Plug on your Strada. Could you elaborate please, what did it do to milege? and can you talk a little more about the power increase.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is offline   Reply With Quote
Old 03-18-2013, 06:48 AM   #464
Deans BMW
Granpa Hoon
Oddometer: 3,334
Do they check and adjust if needed the valves at the 600 mile service?
BTW, the Strada is fantastic playing go fast on some of these twisty roads up here. I stayed with a guy on a Kaw 1400 Ninga and a guy on his K1300S, the lean angle on this bike is amazing. I find that I am in full WFO mode on some of these fine mountain roads. Only have hit the rev limiter once, but spend a lot of time between 6 and 7.5 K R's. . this little wonder really hauls ass.
Dean O
Copperhill, Tn.
Old 03-18-2013, 06:49 AM   #465
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Regarding Torx fasteners, I'm not sure when....but 2010 F800GS was the first bike which I had them on. Then, my 2011 Husaberg came with them.
At first, I was bummed about it because I had to buy new tools for them. Then, I realized....Hey, I get to buy new tools
Now, I like them better than any other fasteners. They grip the tool superbly and don't seem prone to stripping or wearing out. Plus, there are only 2 or 3 sizes (typically) across the entire bike. It's changed my thinking....and the size of my onboard toolkit.
I carry a ratcheting screwdriver-type wrench with the bits stored inside the handle......and little else.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Times are GMT -7.   It's 01:12 AM.
