Old 04-11-2013, 07:16 PM   #616
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,736
Go Racks? ... cont'd
I got the other half completed…..yippee!
The 1" offset kept them tucked in nicely. And I set the lower brace very tightly against the heat shield. I don't like my legs hitting any protrusions behind me.
All the edges are rounded off smooth too.
The crossover bridge took some contemplation….to make it mount properly, like I wanted .
The threaded holes in the subframe are very deep inside the plastic tail rack mount. AND the plastic rack surface is at a steep angle, not parallel to the threaded bolt holes. So, I cut two metal spacers very precisely which extend evenly a little distance above the plastic rack….
Then, I filed the surface parallel to the ground ( more or less). This really help level out the bridge and give it a solid mount against the subframe far below. It took some long strong bolts, to be certain…
And, I slipped on a tight fitting nylon spacer to fill the gap inside the steel spacer…..just because!
Goes in like so:
Just need my rattle can of paint and some warmer weather to finish up this project. Because my "paint shop" consists of a wire shirt hanger suspended from a tree limb in the yard.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 04-11-2013, 08:46 PM   #617
Blaise W
Blaise W's Avatar
Oddometer: 679
Super Nice Job High Five! I really like the crossover and thought about doing that too. Two top supports per side will hold up the world! Think about making a back loop though, to support that rear fender and keep it from shaking up and down, maybe cracking like a few have.
Blaise W is offline   Reply With Quote
Old 04-11-2013, 08:53 PM   #618
TurbStLCards
Doesn't Like Stuff
TurbStLCards's Avatar
Oddometer: 63
Originally Posted by HighFive View Post
Ah ha.....pipe notcher. Thank you! Added to the List.
I was using .024 wire and settled on a heat setting of 3 (out of 4) on my little Hobart 140 Handler. Had the speed at 45 (about midpoint). I purchased extra pipe to practice on, and was burning thru the tubing on the hottest setting. Knocking the tarnish off with a wire wheel seemed to help it take better.
I seemed to be getting good penetration most of the time....when it was buzzing along nicely, and then suddenly it would all go to pot. Some spots just didn't want to take a weld without major fuss, when nothing else had changed. It's was quite puzzling, I'd be running smoothly then "bam....pop, crackle, snap". So yeah, there was a bit of grinding & re-welding at times. Kind of frustrating, but still a blast to do. The sense of accomplishment is huge!
I have plenty of extra pipe left to play with. So, keep the advise & council coming...
HF
I didn't see an answer to this yet. IT might be something as simple as your inert gas bottle running low. What gas are you using or is it flux core? I'm a Lincoln man so I'm not familiar with the Hobart but you say it is little. I would guess that you exceeded the duty cycle and it is just asking for a rest. So I would just stop when that happens and just go smoke, or drink a mountain dew, wack off, whatever you do to pass the time, then come back and finish that bitch!
Lookin' good!
TurbStLCards is offline   Reply With Quote
Old 04-11-2013, 09:08 PM   #619
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
I agree. The tail dong needs to be cut off or supported.
Lookin' good!
It could be the ground cable coming lose. Or possibly not using any nozzle gel.
You are using nozzle gel, right HF?
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 04-12-2013, 03:18 AM   #620
RuggedExposure
Oddometer: 1,247
Useful Information/Specs
Valve clearance (with engine cold)
Intake............................................ .................0,009 0,011 in (0,23 0,28 mm)
Exhaust........................................... ............. 0,015 0,017 in (0,38 0,43 mm)
Spark plug type.............................................. .................."NGK" MAR9A-J-G06
Spark plug electrode gap............................................... .....0,024 in ( 0,004 in)
0,6 mm ( 0,1 mm)
Drive chain dimensions........................................ ...................520KR0 112 links
lubricating oil................................ CASTROL POWER1 RACING SAE 10W-50
Oil and oil filter replacement.................................................. ................... 0,44 Imp. Gall. / 0,528 U.S. Gall. / 2.0 l
Topping up oil between minimum and max. level.................................. 0,055 Imp. Gall. / 0,066 U.S. Gall. / l 0.25
Torque Specs (Nm):
Fastening of tank assembly screw on LH side 8,0
Fastening of mesh oil filter on chassis 10,0
Fastening of oil pipe clamps 3,0
Fastening of plug on union for oil drainage from chassis 24,0
Fastening of oil delivery/return/breather pipes on engine 38,0
Fastening of rigid pipes on engine cylinder head seat 12,0
Fastening of engine to chassis on LH side 5,0
Fastening of oil refuelling cap on chassis 10,0
Fastening of ECU to support 8,0
Fastening of ECU support to chassis 8,0
Fastening of ignition/starter lock 19,0
Fastening of handlebar clamps 19,0
Fastening of steering upper plate nut 80,0
Fastening of handlebar clamp screws 19,0
Fastening of fork plate side screws 19,0
Fastening of brake pipe screws to pumps/callipers/ABS ECU 24,0
Remove the two screws of the bottom yoke on LH side and refit with plate 12,0
Tightening of bushing for adjustment of swinging arm clearance 6,0
Fastening of swinging arm pin to chassis 120,0
Fastening of engine lower screw on chassis 38,0
Fastening of engine LH screw to chassis 38,0
Fastening of engine RH screw to chassis with spacer 38,0
Fastening of engine front clamp nuts 24,0
Fastening of engine clamp plate - close 56,0
Retrieve the lower clamp upper screw - reclose 56,0
Retrieve the lower clamp lower screw - reclose 56,0
Fastening of clamp on throttle body coupling 0,6
Fastening of earth cable to engine cylinder RH side 8,0
Fastening of nut for starter motor cable 6,0
Fastening of neutral sensor cable to engine RH side 0,8
Fastening of turn indicator screws 2,0
Fastening of light support to upper plate 5,0
Fastening of front fairing support bracket screws to light support 2,0
Fastening of filter box air temperature sensor 2,0
Fastening of cover to filter box base 2,0
Fastening of central front locking to filter box base 2,0
Fastening of filter drawer to filter box base 1,5
Fastening of filter drawer to filter box 2,0
Fastening of top of shock absorber 56,0
Fastening of bottom of shock absorber 56,0
Fastening of rear suspension kinematic mechanisms 80,0
Fastening of airbox to RH seat of chassis 2,0
Fastening of expansion tank to chassis (LH side) 1,0
Fastening of airbox to chassis (LH side) 8,0
Fastening of pinion guard 4,0
Fastening of rear chassis 28,0
Fastening of fuel tank to rear chassis 8,0
Fastening of fuel tank to chassis (RH side) 8,0
Fastening of gear shift pedal to chassis 13,0
Fastening of number plate holder to rear chassis 2,0
Screws for fastening saddle release onto chassis 8,0
Screws for fastening saddle release onto chassis 3,0
Fastening of rear mudguard lower clamp to chassis 2,0
Fastening of ECU to support plate 6,0
Fastening of ECU support plate to rear mudguard 1,5
Fastening of sprocket 19,0
Screw for fastening footrest fixing plate onto support 8,0
Fastening of rear brake master cylinder 8,0
Fastening of rear stop switch cover 0,7
Fastening of stop switch support 2,0
Fastening of rear brake lever 28,0
Fastening of side stand 38,0
Fastening of side stand switch 5,0
Fastening of silencer to chassis 19,0
Fastening of silencer and manifold clamps 19,0
Fastening of front manifold to cylinder head 19,0
Fastening of Lambda sensor to manifold 45,0
Fastening of heat-protecting cover onto exhaust manifold 8,0
Fastening of RH and LH footrest supports to chassis 56,0
ABS - Fasten rear brake pipe to master cylinder using screw and two washers 10,0
ABS - Fasten rear brake pipe to master cylinder using screw and two washers 24,0
Fasten the delivery and return pipes to engine seat 3,0
Fastening of top of radiator to chassis 8,0
Fastening of BLOW-BY pipe from filter box to engine ignition cover 2,0
Fastening of BLOW-BY pipe to filter box 2,0
Fastening of horn 5,0
Fastening of voltage regulator plate to engine 5,0
Fastening of front mudguard / fork guards 5,0
Fastening of front wheel axle 80,0
Fastening of screws on fork feet 8,0
Fastening of front brake calliper 38,0
Connect and fasten front brake pipe to brake calliper seat 24,0
Terra-fastening of wire guide plate to LH fork guard 1,5
Strada-fastening of wire guide plate to mudguard 1,5
Fastening of front wheel speed sensor 8,0
Fastening of voltage regulator 8,0
Nut for rear wheel assembly pin 30,0
Tighten rear wheel axle to torque 100,0
Screw for fastening brake hose ring to swinging arm seat 7,0
Fastening of rear wheel speed sensor 8,0
Fastening of chain casing 8,0
Terra-fastening of pushrod to front mudguard tail 1,5
Fastening of front fairing / front mudguard lower clamp to plate 8,0
Front fastening of front fairing lower clamp to light support 2,0
Rear fastening of front fairing lower clamp to light support 2,0
Fastening of front headlight to support 2,0
Fastening of voltage regulator guard 5,0
Fastening of anti-theft cover 2,0
Fastening of rear brake oil tank 2,0
Fastening of chain slider to swinging arm 5,0
Fastening of clutch control assy clamp 5,0
Fastening of LH switch to handlebar 2,0
Fastening of front master cylinder to handlebar 5,0
Fastening of RH switch to handlebar 2,0
Fastening of throttle control to handlebar 3,0
Fastening of front brake disc to rim 11,0
Fastening of rear brake disc to rim 11,0
Fastening of tone wheel to brake disc 5,0
Fastening of chain roller 8,0
Fastening of fuel pump ring nut to tank 6,0
Fastening of fuel cap ring nut 3,0
Fastening of reflectors to number plate holder 0,8
Fastening of turning indicators 2,0
Fastening of licence plate light to number plate holder seat 3,0
Fastening of tail light to number plate holder seat 3,0
Fastening of radiator guards 1,8
Fastening of sides to chassis 1,8
Fastening of side connecting cover 1,8
Fastening of scoops 1,8
Fastening of tank cover 1,8
Fastening of heat-protecting covers onto silencers 5,0
Fastening of front fairing 1,8
Fastening of luggage rack 19,0
RE Fotowerks
Old 04-12-2013, 03:52 AM   #621
Ol'NumNuts
Getting Stupider
Oddometer: 352
Niiiiiiiiiiiiiiiiiiiiiiiiicccce...
Gonna commit that all to memory eh? Are ya?
Out of 10,000,000 sperm, YOU! Were the one who WON! So, Do your Mamma Proud.... Go Hard! Or go home.... Cheers, Havagoodone....
Ol'NumNuts is online now   Reply With Quote
Old 04-12-2013, 03:58 AM   #622
RuggedExposure
Oddometer: 1,247
I'm stuck with desk duties tonight.
It took me 2 hours to format that so ADV would accept it under the 40,000 character post limit.
Enjoy.
RE Fotowerks
Old 04-12-2013, 04:17 AM   #623
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,267
Thumb
This explains a few things...
The oil capacity 2.25 litres ?
Doing a 9,000km oil, filter and air change tomorrow. I'm taking it to the dealer for the valve adjustment in a couple of weeks. (I have a good local guy, he says it's a 3.5 hour job) Take pix RE
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is offline   Reply With Quote
Old 04-12-2013, 04:26 AM   #624
RuggedExposure
Oddometer: 1,247
Reading the service manual, it recommends oil changes every 10,000km (6200 miles)...
Am I the only one changing mine every 3k miles?
RE Fotowerks
Old 04-12-2013, 05:00 AM   #625
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,736
Lookin' good!
Thanks for the input, TurbStL: Argon mix....still had about 1/3 bottle according to gauge....running solid at 20 psi regulator setting when I pull the trigger. Welds were fairly short period, and at approx half way on the heat setting and speed....so it shouldn't been exceeding duty cycle. Hhhhmmmm.....
HF
Old 04-12-2013, 05:05 AM   #626
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,736
Nozzle gel Search me...
What's that?
Probably answers your question.
I have taken good measures to significantly improve my grounding. Did figure that out early on, after some frustration. So, I think I maintained a solid ground directly to the piece.....and it wasn't moving.
HF
Ps. Awesome List, by the way. Super thanks for building that!!!
Old 04-12-2013, 05:15 AM   #627
RuggedExposure
Oddometer: 1,247
What's that?
HF
http://www.sears.com/hobart-nozzle-gel/p-00920752000P
It will help with weld spatter, and helps with a smoother bead. May or may not fix your issue, but you should use it anyways.
RE Fotowerks
Old 04-12-2013, 05:17 AM   #628
Beemermcr
Big, Dumb, Happy!
Beemermcr's Avatar
Oddometer: 293
Enjoy.
Thanks!! Already copied and pasted to Notes!!
Paul Baird
Sandy, UT
2013 Husky/BMW/KTM Terra
2000 DRZ "Burro"
Beemermcr is offline   Reply With Quote
Old 04-12-2013, 05:54 PM   #629
hansi
Teurer Abenteurer
hansi's Avatar
Oddometer: 307
I'm with you there. Very rarely go past 3000 miles on oil changes.
2013 Husqvarna TR 650 Terra
Never let your love run cold
hansi is offline   Reply With Quote
Old 04-12-2013, 07:26 PM   #630
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,736
Oil Change Interval
Yup....approx 3,000 miles or so, for me typically.
HF
p.s. On my Berg390, I'll go by hours instead....since its mostly slow speed trail riding. Ok, maybe not so slow. But you get the idea.
Times are GMT -7.   It's 06:11 PM.
