Old 02-24-2013, 02:20 PM   #61
bobinaustin OP
planning for the adv
bobinaustin's Avatar
Oddometer: 205
Well I guess i will put everything back together as I have no leaks. I didnt get any responses to this last post or two so I guess I will put it all back togeher and take it for a test ride?? whats the worst that could happen?
_____________________
2004 R1150GS
bobinaustin is offline   Reply With Quote
Old 02-24-2013, 02:47 PM   #62
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,380
The clutch only bleeds from that single point. I replaced the OEM part with a BMW bleed screw, see the sticky at the top of the oilhead section for information on parts.
That makes the bleed simple. ONce you get it right, no leaks and all the clutch should feel very nice when pulled.
Good luck.
Originally Posted by bobinaustin View Post
Ok so I guess I got it done. The reason why I don't sound convinced is it took several attempts of putting the slave on and finding loose banjo bolts etc. after several starts and stops I got the slave on and bled the clutch but in not sure I bled it properly. I guess my question is how do I know it's been bled properly??
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is online now   Reply With Quote
Old 02-24-2013, 03:38 PM   #63
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,982
Bob, you'll know if the bleed was good by the way the clutch feels and if the friction zone is the same as when new.
def is online now   Reply With Quote
Old 02-25-2013, 10:46 PM   #64
bobinaustin OP
Oddometer: 205
Well... I put everything back together tonight and took her for a spin. The clutch lever seems to be pulling back further than normal and engaging too soon. I will adjust the lever with the knob tomorrow morning but I am wondering if another bleed is in order?
2004 R1150GS
Old 02-27-2013, 08:14 PM   #65
rhafe123
Oddometer: 83
Smae thing happened to mine...
'07 R1200GS. I replaced the slave and bled, bled, bled till I was blue in the face. Turns out it was the master cylinder (on the lever).
rhafe123 is offline   Reply With Quote
Old 03-02-2013, 07:17 AM   #66
def
def's Avatar
Oddometer: 9,982
Bob,
Any further progress? Is your clutch now working correctly?
Old 03-02-2013, 10:22 PM   #67
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,757
Now that you know how to do it, the 2nd bleed will go a lot faster.
I've been following your thread for a while now. Did my first clutch bleed last week (1150GSA) and had a break in the rain yesterday so I took it out to see how it felt.
Felt perfect. Yay!
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 04-05-2013, 10:05 AM   #68
PF Flyer
PF Flyer's Avatar
Oddometer: 57
same thing - kinda
2002 R1150R with 64k. New clutch, slave, trans input shaft and seals at 38k. Clutch fluid changed every year. Over the winter I lubed the splines along with all other maintenance. When I was done the trans engages about one half inch off the bottom(from the grip). This level stays constant over time in the garage. I have re-bled a couple of times, tapping things along the way. I used a mightvac and manual methods. If I pump it up I get normal engagement for 3-4 pulls. I get a nice 2-3 foot squirt from the master with the cover off. I have never repacked the bearing in the slave. Felt is dry and no obvious leaks around slave, which is clean. I did my homework and found this. If I should start a new thread let me know
Are the conditions different enough to point to something other than the slave?
thanks
The trouble with normal is it always gets worse - BC
PF Flyer is offline   Reply With Quote
Old 04-05-2013, 10:35 AM   #69
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,877
thanks
When I do them I PUSH the fluid UP from the bleed hose holding the bleed hose as low as possible.
Ever since I started doing them that way, it's taken less than 5 minutes to effectively bleed the system
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 04-05-2013, 11:20 AM   #70
Ravenslair
Oddometer: 473
I thought about pushing from the bleed hose since that is how they fill it. What adapter are you using or did you put something together? I figure Home Depot or Lowes should have a gas or water fitting that will fit the thread of the fill adapter and I can rig something from there to a pump.
Ravenslair is offline   Reply With Quote
Times are GMT -7.   It's 04:52 PM.
