Old 12-23-2012, 04:06 PM   #1
rdhj OP
NJ Dual Sport Rider
rdhj's Avatar
Oddometer: 191
Tusk Grip heater resistor size
anyone have the tusk grip heater kit with the white rectangular resistor...i need to get a new one and need the size off of it
rdhj is offline   Reply With Quote
Old 12-24-2012, 07:50 AM   #2
Wapner
Oddometer: 24
Mine says 10 W 2 Ohms.
Wapner is offline   Reply With Quote
Old 12-24-2012, 11:25 AM   #3
rdhj OP
NJ Dual Sport Rider
rdhj's Avatar
Oddometer: 191
cool..thanks
Old 12-24-2012, 01:15 PM   #4
outfront
outfront's Avatar
Oddometer: 77
resistor
Originally Posted by rdhj View Post
cool..thanks
I believe they are 2k ohms. I had those on one of my bikes. high was to hot and low was to cold; so I bought a 1k ohm resistor from Radio Shack and eliminated the 3 position switch to a two position. I basically had a medium heat only.
2012 KTM 990R
06 KTM 525 EXC
74 Yamaha RD 250
outfront is offline   Reply With Quote
Old 12-24-2012, 06:41 PM   #5
Beezer
Oddometer: 5,865
can't be K ohms unless it is used in a transistorized controller. E=IxR
1000 ohms in series would limit current to less than .oo12 Amps
P=IxE so, .0144 watts max
1K pot on the base of a transistor controller would be OK... I built one for my vest with a 500 ohm in the base circuit
Beezer is offline   Reply With Quote
Old 12-25-2012, 06:25 AM   #6
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,388
I had one break on me recently. I zip tied it to my fork tube and the stress from the flexing broke a lead off at the resistor. Now I have it hanging in the breeze. I had a 10W 1 ohm resistor I replaced it with. The original was a 2 ohm. You can get them at the rat shack.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 12-25-2012, 07:27 AM   #7
Peanuts
Peanuts's Avatar
Oddometer: 1,666
I bought a different switch so the grips were in parallel for high and series for low. No need for that vulnerable resistor...
Peanuts is online now   Reply With Quote
Old 12-25-2012, 04:17 PM   #8
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
how's the heat in the low position? from what I've read wiring them in series has the grips drawing anywhere from 25 to 50% of the high setting. my bike doesn't have a lot of electrical output so wiring in series should help. do you have any idea how many watts they draw in the low position(series) compared to the high position?......thanks
nice drawing by the way.
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor is offline   Reply With Quote
Old 12-25-2012, 04:43 PM   #9
duck
duck's Avatar
Oddometer: 10,403
JMHO: Spend $4 and turn them into variable heated grips. Best $4 I ever spent:
http://www.advrider.com/forums/showthread.php?t=737165
duck is offline   Reply With Quote
Old 12-25-2012, 05:05 PM   #10
D.T.
D.T.'s Avatar
Oddometer: 11,388
Thumb
Now that's what I like about these forums. Good advice!
Old 12-26-2012, 11:32 AM   #11
Peanuts
Peanuts's Avatar
Oddometer: 1,666
Thats a cool idea.
Old 12-28-2012, 05:51 PM   #12
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
I think substituting this electronic flasher for the 2-ohm resistor will work well; this flasher only costs $12.99.
http://www.autozone.com/autozone/par...fier=6417_0_0_
I analyzed the DPCO switch cirucuit, with the help of an electrical engineer. The Tusk Heated Grip Kit consumes about 9.0 watts per grip on low setting, with the resistor consuming about 7.2 watts. The high setting consumes about 17.8 watts per grip. Therefore, the low setting generates about 1/2 the heat of the high setting, and wastes 7.2 watts from the resistor.
The DPCO switch circuit consumes about 4.42 watts per grip on the low setting, which is about 1/2 the heat generated by the Tusk setup on low heat, and 1/4 the heat generated by the high setting. Therefore, I think I am going to install an electronic relay in place of the resistor. The LED dimmer is very nice, and inexpensive; however, it's just too large for me.
Spud
Spud Rider screwed with this post 12-28-2012 at 05:59 PM
Old 12-29-2012, 03:18 PM   #13
Peanuts
Peanuts's Avatar
Oddometer: 1,666
This device is tiny and will handle 144 watts.
http://www.ebay.co.uk/itm/Slim-3-Key...item27c55e0488
its about 1/2" wide x 2" long and 1/4" thick and remembers the last setting after power off, so can be used in place of the resistor and fine tuned to give the desired heat setting. Or velcro onto the dash for fiddling about on the move.
Old 12-29-2012, 04:41 PM   #14
duck
duck's Avatar
Oddometer: 10,403
You can get 20A flasher relays for $2.49 from China on Fleabay:
http://www.ebay.com/itm/Electronic-L...73268e&vxp=mtr
Old 12-29-2012, 06:23 PM   #15
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
Thank you for posting the good tips, gentlemen!
Spud
Times are GMT -7.   It's 10:40 AM.
