Old 12-23-2012, 08:12 PM   #1
AdvRonski OP
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 706
Updated DIY Radiator Guard
Last winter I used the down time to make a stainless steel rad guard, details- HERE
It turned out a little on the heavy side, but it could probably with stand a shotgun blast, and seemed to work well.
I did have one incident, though. ( This one time, at band camp.............)
While heading home from Moab via Sego Canyon, I hit the freeway at Thompson, and ran her up to 90 mph in the 100+ degree heat. After about 30 minutes, the coolant temp shot up, and it began to spray Engine Ice onto my right boot.
I had to slow to 45-50 to keep it at least close to the normal temp, but I made it back to Grand Junction OK.
After topping up the coolant the next day, I had no further problems for the rest of the year.
But, I wondered if the tight mesh of the rad guard wasn't flowing as much air as I thought.
I decided to make a lighter guard out of stainless steel, without the expanded metal, but with a coarser, heavier gauge mesh.
Here's the chunky original-
And the new, improved version-
The lighter outer frame still makes a fairly stiff structure when mounted-
But, how to measure relative airflow through each guard?
I made a crude airflow meter from cardboard and duct tape, and used a partially shrouded fan to provide the air.
First, the baseline reading. ( Try not to laugh too hard at my contraption)-
The unrestricted airflow moved the weighted flap about 7-8 inches. Actually, the flap is "zeroed" at 2 inches, but I just didn't think to move the high-tech base to set it to zero. So, call it 5-6 inches.
OK, now the original guard is put in place-
Wow, only about 1.5-2 inches of deflection/airflow. That guard really choked off the air to the radiator!
And, finally, the new and improved version is tested-
Holy Cow! Roughly 3.5-4 inches! That's about twice the flow of my original guard!
Granted, the whole thing is pretty crude, but it's clear that airflow will be much improved.
Plus, it's almost a pound lighter-
The installed unit fits and looks good. Well, to me anyway.
Next Up- I update the waterpump with a CJ Design Super Shaft and 2009 impeller and cover.
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski screwed with this post 12-25-2012 at 07:24 AM
AdvRonski is offline   Reply With Quote
Old 12-23-2012, 11:22 PM   #2
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,030
Aint science wonderfull :)
rossguzzi is offline   Reply With Quote
Old 12-24-2012, 05:23 AM   #3
bajarider1
bajarider1's Avatar
Oddometer: 28
Nice work and I like how thorough you were in the R&D department.
bajarider1 is offline   Reply With Quote
Old 12-24-2012, 08:58 AM   #4
Steveman
Steveman's Avatar
Oddometer: 471
Looking at the "old" design it was clear that this will cause trouble, covering at least a third of the radiator. Way to much imho.
Cross my fingers that new design will work. I use no rad guard BTW and never had an issue
Merry Christmas !
Steveman is offline   Reply With Quote
Old 12-24-2012, 04:22 PM   #5
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 720
Nicely done.
HeatXfer is offline   Reply With Quote
Old 12-24-2012, 05:09 PM   #6
Scott Baja
el semental negro
Scott Baja's Avatar
Oddometer: 232
Very impressed! Clean nice looking work, and very clever testing. You are to be highly commended!
Scott Baja is offline   Reply With Quote
Old 12-24-2012, 07:30 PM   #7
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,156
brilliant
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 12-26-2012, 01:06 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,011
Nice accessory
I find your lab equipment brilliant. Nice improvisation. Cheers.
Old 12-26-2012, 09:43 AM   #9
Megadeus
Motorcycles are therapy
Megadeus's Avatar
Oddometer: 221
You best Redneckonize! Ya' Hear!
Megadeus is offline   Reply With Quote
Old 12-26-2012, 12:22 PM   #10
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,473
Backwash issue?
I wonder if the fatter mesh creates a large backwash diverting flow to the outside of bike's radiator as well as restrictive flow?
Great food for future thought.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer screwed with this post 12-26-2012 at 07:55 PM
DesertSurfer is offline   Reply With Quote
Old 12-26-2012, 10:29 PM   #11
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,089
" I'm not a Doctor, I have a Master's Degree",..." IN SCIENCE!!"
Were did you find the wire mesh? McMaster-Carr?
"Son, you can't do both"
Old 12-27-2012, 04:24 AM   #12
AdvRonski OP
Oddometer: 706
I had to think about that one a bit, but it was Summit Racing- http://www.summitracing.com/parts/aa...2270/overview/
They also have the AN fittings and hose for the remote oil drain mod- $50 shipped.
Ronski
Times are GMT -7.   It's 05:39 AM.
