Old 12-28-2012, 01:21 PM   #61
mendoje
Oddometer: 235
Can anyone comment on this batch of 336 cams, on sale right now at Max BMW:
http://www.maxbmwmotorcycles.com/fic...3&rnd=08102012
from the parts fiche, "30.00% OFF-Getting rid of inventory!"
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 12-28-2012, 01:45 PM   #62
supershaft
because I can
Oddometer: 9,116
On sale or not, BMW parts are warrantied for a year in this country.
Old 12-28-2012, 08:39 PM   #63
mattcfish
R90SS/6
mattcfish's Avatar
Oddometer: 228
buy one and measure
$119.00 is an amazing price. Buy one and return it if it doesn't measure up. If it does, let us know.
I'll buy 2!
mattcfish is offline   Reply With Quote
Old 12-28-2012, 08:58 PM   #64
mendoje
Oddometer: 235
I have a lathe, all the right measuring tools and instruments, and I'm ready to plunk down my card to buy one. Referring to this sketch, at the peak of each lobe, we're looking for taper from back to front across the face, right?
mendoje screwed with this post 12-28-2012 at 10:02 PM Reason: added pic
Old 12-28-2012, 11:39 PM   #65
jbcaddy
Oddometer: 1,211
I'll buy 2!
That price was making me think yes, but they do not have any for /5. out of stock for years
jbcaddy is offline   Reply With Quote
Old 12-29-2012, 12:32 AM   #66
supershaft
because I can
Oddometer: 9,116
I'll buy 2!
Better yet, ask the parts guy to get out his plastic parts guy caliper and measure it for you. There are at least two tapered lobes there to compare the tapered lobes and the flat lobes if they have any.
Old 12-29-2012, 12:32 AM   #67
supershaft
because I can
Oddometer: 9,116
Yes.
Old 12-29-2012, 01:06 AM   #68
supershaft
because I can
Oddometer: 9,116
I'll buy 2!
What's retail now? That can't be much over dealer? When they are ground right they are awesome cams as you now know too! They do it all. Especially upper midrange! Right where I ride all the time. Man I am loving my new setup with my old 70k miles on it now 336!
Old 12-29-2012, 02:14 PM   #69
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,549
I bought a bean can 336 about 4 years ago, but ended up using a pre bean motor so had the local cam expert convert a 308 to 336, which included making a set of 'masters'
More recently got him to convert a R65 cam to 336 as well for a 500 race motor project.....and yes the phasing was taken into account....
You can see where material has been added.
Out of curiosity I put the vernier across the lobes and yes there is a taper.
The 336 in the R90 runs ok but I have not been able to get a good idle, not really an issue in a race bike, pulls really well up to the rev limiters cut out 7500. I used to use the tach but they read about 500 rpm high from memory, with the Ignitech you can read the RPM off the laptop during set up.
Voltaire is offline   Reply With Quote
Old 12-29-2012, 02:48 PM   #70
supershaft
because I can
Oddometer: 9,116
Did you have your 336's ground straight up or advanced 3*? I have no experience getting 336's timed straight up to idle. Advanced 3* I have gotten good idles out of three that I have set up and I have seen good idles out of other 336's as well. I would start with making sure your valves aren't leaking AT ALL. I sure would be sure and time copied grinds to in order to make sure what you got!
Why set your rev limiter so low? Piston speed is super safe until you are real close to 9000rpm. If your valves aren't floating and they shouldn't be with titanium spring retainers, rev it higher for more power. If it isn't making more power up there you still might be able to use the over rev to your advantage at some tracks. 336's have good usable over rev.
Old 12-29-2012, 03:19 PM   #71
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,549
Good points,I'm not sure on the advance, have to check with my Guru on that.... I have bugger all experience outside stock setup.
The motor was put together on a real low budget just to see if riding on the track was for me, the valve train is stock at this stage. Been looking at SS Manley valves ( lighter), titanium retainers and beehive springs.Another 1000 rpm would sure be useful, would be able to stay in front of the featherbed Dominator 850 after passing him on the corner under brakes....
Had a good season with the old girl, surprised quite a few, expecially the Harleys.
Old 12-30-2012, 07:07 AM   #72
DanMay
Oddometer: 43
New 336 cam from BMW
How did the 336 work out in your 500cc race motor ? I am interested in your experience, and curious if the smaller displacement and valve size will benefit from the 336 profile. I am currently racing a R50/5 with the stock camshaft.
Daniel
DanMay is offline   Reply With Quote
Old 12-30-2012, 11:13 AM   #73
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,549
Daniel
Its still on the bench at the moment, the rules here allow you to run parts that " look the same"....
So its really going to be an R45 motor with R65 heads, 336 cam and a light valve train.
I have not heard of anyone doing this....probably good reason.
Cylinder wall needs a smidgen taken out but shrouding could be an issue....as might the 36mm inlet ports.....its suck it and see territory.
For a r50/5 the 308 cam would probably work better .....once again pure supposition.
Old 12-30-2012, 11:23 AM   #74
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,235
.. the rules here allow you to run parts that " look the same".....
To me, a 1070 kit with Mikunis would look [sort of] the same as an R50. Close enough!
Old 12-30-2012, 11:36 AM   #75
DanMay
Oddometer: 43
Ha ! I wish. I run in AHRMA Production Lightweight , and I must keep the same stroke and bore (plus a small overbore is allowed). I am running the R50/R60 /5/6 Bings, those are the only allowed carbs. Then again, you know all this because I believe you have built a R75/5 AHRMA racer in the past...
There is not a lot of information on making the R50/5 go fast and keeping it a 500cc. Most just suggest putting a 600 or 750 top end on it. That is fine for the street, but I need to keep it 500cc and production looking from the outside. A lot of questions:
Will the 600 heads work ? Or will the valves hit the cylinder walls ? What is the best valve size for the 500 ?
What is the best cam profile for the 500cc displacement ?
What is the best way to raise the compression ? Dual plugging is not an option so I am worried a piston with too much dome will not provide an efficient burn on a single plug.
So many options, so little time
Daniel
Times are GMT -7.   It's 09:43 PM.
