12-30-2012, 10:36 AM
#76 | |
Oddometer: 11
New 336° cam from BMW
Ha ! I wish. I run in AHRMA Production Lightweight , and I must keep the same stroke and bore (plus a small overbore is allowed). I am running the R50/R60 /5/6 Bings, those are the only allowed carbs. Then again, you know all this because I believe you have built a R75/5 AHRMA racer in the past... There is not a lot of information on making the R50/5 go fast and keeping it a 500cc. Most just suggest putting a 600 or 750 top end on it. That is fine for the street, but I need to keep it 500cc and production looking from the outside. A lot of questions: Will the 600 heads work ? Or will the valves hit the cylinder walls ? What is the best valve size for the 500 ? What is the best cam profile for the 500cc displacement ? What is the best way to raise the compression ? Dual plugging is not an option so I am worried a piston with too much dome will not provide an efficient burn on a single plug. So many options, so little time… Daniel |
12-30-2012, 11:31 AM
#77 |
Oddometer: 1,483
Using heads and/or cylinders off a 70.6mm stroke motor won't work on an R45/R65 case. The difference in stroke makes developing a decent compression ratio difficult. If you are going to use the R45 cases and crank I suggest using the stock heads with valves from an R65. Bore to 1mm oversize; you can get pistons from a number of aftermarket sources.
On the other hand, you could really cheat, taking the motor out to 750cc. As long as you don't look significantly faster than the other bikes, or win too often, no one should ask for a tear down
12-30-2012, 11:43 AM
#78 |
Oddometer: 11
I need to keep it legal, 500cc max. With a R50/5 bottom end, pistons, and jugs, can you use R60/5/6 heads ? Would the larger valves help or hinder the performance ? Or would it be better off sticking with the R50/5 heads and just do a good port job ?
12-30-2012, 12:07 PM
#79 | |
Oddometer: 735
Its an R65 with 450 cylinders and pistons, finding the 450 kit was hard enough and they were never imported to down under. Where can i get oversized pistons? ![]() cheers |
12-30-2012, 12:10 PM
#80 |
Oddometer: 735
12-30-2012, 12:35 PM
#81 | |
enamoured
Oddometer: 2,517
12-30-2012, 03:32 PM
#82 | |
Loose Pre Unit
Oddometer: 3,977
It reminds me of the Honda XLV750 I had - max hp at 7,000, red line at 8,000 and limiter at 8,250. I had that bike on a dyno a couple of times and the power curve was exactly the same a Honda's - it only lost a couple of hp between 7,000 and 8,000rpm. I used the over rev on gravel too, but also to save wasted upshifts between corners on the road - let it spin out to 8,000 and then into the next corner. I'd like to do this with the R65 too. |
12-30-2012, 06:42 PM
#83 | |
Oddometer: 1,483
I've never had an R45 apart, so I don't know what the chamber or piston dome are like. Got any specs? |
12-30-2012, 06:45 PM
#84 | |
because I can
Oddometer: 6,203
12-30-2012, 08:29 PM
#85 |
Loose Pre Unit
Oddometer: 3,977
I just calculated it all out, and then lost it all....should've written it down the hard way. Anyway, my final point was that bore/stroke is about piston speed, and you can't compare a 650 to a 1,000cc engine....better to compare the R65 to a Triumph 650. At 7,250 the 82mm stroke Triumph has a piston speed of 19.8 m/s, or 3900 ft/min. The 61.5mm R65 is doing 14.86 m/s or 2925 ft/min, at 8,000 the R65 is 16.4 m/s or 3228 ft/min, at 9,000 18.45 m/s or 3631 ft/min.
At 9,000rpm the piston speed of the R65 is lower than the Triumph at 7,000rpm - and the Triumph was considered to be a revver in it's day. |
12-30-2012, 09:17 PM
#86 | |
because I can
Oddometer: 6,203
12-30-2012, 09:47 PM
#87 |
Loose Pre Unit
Oddometer: 3,977
Valve train has always been the limiting factor with pushrod engines, that's why ohc is now the prefered option. But plenty of pushrod engines can be made to rev well, some even stock. I used to rev the unit 500cc Triumph twins to over 10,000rpm, completely stock. So if it's happy at 8,000rpm with no valve float issues, that's still safe on these engines - the bottom engine is up to the task ?
12-30-2012, 09:59 PM
#88 | |
Oddometer: 735
12-30-2012, 10:05 PM
#89 | |
Oddometer: 1,133
After doing this to my racer, it's happy running to 8500 with no problems. I have an oil pressure gauge just in case. I believe some people have machined the pump thinner so it draws less oil. I'm not familiar enough with the R65 engine to know if it's a problem with them too.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. Bertrand Russell |
12-30-2012, 10:07 PM
#90 | |
Oddometer: 3,793
http://www.moorespeed.co.uk/classic-racing |
