12-31-2012, 06:16 AM
#1 |
Oddometer: 41
Lighting: where do I tap into for 'turn on'?
Ok, so I've got my new fog/spot lights mounted, my fuzeblock installed under my seat(rear above fender), everything's looking good. I'm nervous about tapping into the factory wiring..where is the best/easiest place to tap into for my 'turn on' power?
12-31-2012, 06:59 AM
#2 |
Oddometer: 2,938
![]() Good question. Are you trying to have the entire fuzeblock wired to the ignition, so the key must be on for power? Not wanting to hijack your thread, but the reason I'm asking is that IS what I want to do. |
#3 |
Old guy
Oddometer: 1,362
Any wire that is hot with the switch on. Since you have everything under the seat I would think the tail light wire would work to activate your relay. I used the head light low beam but my relay was up front.
"What could possibly go wrong? " The Jerk2012 TE 250 2010 F 650 GS 1983 R 80 G/S |
12-31-2012, 07:09 AM
#4 |
Oddometer: 41
sounds good. thanks.
12-31-2012, 07:25 AM
#5 |
Oddometer: 41
@ Justkip, no, I'm running power directly off of battery to fuzeblock. The fuzeblock is cool because it has a relay and the ability to fuse either switched or constant power at any of the 6 outlets on the fuzeblock.
12-31-2012, 07:26 AM
#6 |
Oddometer: 485
Somewhere on here is a post by JVB, maybe about fuze blocks that says to use blue/green wire in diagnostic plug for the trigger. I used it with no problems. Easy to find, close to my fuseblock, easy to tap.
Old, but not Dead |
12-31-2012, 07:31 AM
#7 |
Oddometer: 2,938
Cool! That's exatly what I want. What fuzeblock?
12-31-2012, 07:33 AM
#8 |
Oddometer: 41
12-31-2012, 07:34 AM
#9 |
Oddometer: 2,429
use green/blue ]wire in diagnostic plug for the trigger. This is for a R1200GS.
A Positap makes it very easy to do so. +1 LaurelPerryOnLand screwed with this post 12-31-2012 at 08:11 AM |
12-31-2012, 07:39 AM
#10 |
Oddometer: 41
thanks all. I'm color blind, and, yes I know that's not good for wiring. Blue I have no trouble making out and I can always ask the mrs. Mine is 04 R1150GS..is the blue wire here the one you're referring to?
12-31-2012, 07:47 AM
#11 |
Oddometer: 606
I just soldered wire on low beam wire at headlight for trigger, easy to do and no need to splice any wires. Best thing is that aux lights dont come on until engine is running.
"If you have to ask, You wouldn't understand" 2005 1200GS "The Big Red Pig" |
12-31-2012, 07:55 AM
#12 |
Old guy
Oddometer: 1,362
Just a note, if you use a Positap you won't have to cut or solder any wires.
http://www.posi-lock.com/posiplug.html
12-31-2012, 08:07 AM
#13 |
Oddometer: 2,429
How does a Positap work?
12-31-2012, 08:14 AM
#14 |
Oddometer: 2,440
You did not mention the bike, but from your profile I am guessing it is the 1150GS. If so, you can tap the tail light as suggested above or the parking lamp if you working up front.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT -->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour -->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour |
12-31-2012, 08:17 AM
#15 |
Oddometer: 41
I have posi-taps. They work great, but are a little hard to find locally. Napa is the only place who stocks any and they only have one size meant for 12-18ga power/accessory. I guess I'll need to order some smaller ones to keep around the shop..
