Old 12-25-2012, 09:02 PM   #1
Phreaky Phil OP
Oddometer: 1,838
MONO/PARA weights
Does anyone have any weight figures of a monolever swingarm and final drive and a paralever swingarm and final drive.
Which one is lighter ?
Phreaky Phil is offline   Reply With Quote
Old 12-25-2012, 09:25 PM   #2
robtg
Oddometer: 676
Kinda like a 450# marathon runner picking out the lightest running shoes. Does it matter?
robtg is online now   Reply With Quote
Old 12-25-2012, 09:30 PM   #3
Phreaky Phil OP
Oddometer: 1,838
Yep
Old 12-25-2012, 09:37 PM   #4
robtg
Oddometer: 676
Yep
Know where your coming from, I also trim the ounces looking for pounds.
Old 12-25-2012, 10:56 PM   #5
supershaft
because I can
Oddometer: 9,116
I have always wondered the same thing. I am going to be very surprised if the Paralever is lighter. It's definitely a lot longer. Something I don't care for on the road bikes for the longer wheel base reducing cornering clearance. They do have a much larger swing radius which is good. They are like a twin wish bone setup on a car only different as far as the swing radius goes.
Those ounces do add up into pounds! I sure wish I could afford some lighter wheels for my Mono! IMO, the wheels are THE place to start but man do we have very limited options on that front! As far as mags go that is. I am tempted to go the cross spoke route but man it's some money!
Old 12-25-2012, 11:32 PM   #6
Phreaky Phil OP
Oddometer: 1,838
Sometimes it's more than ounces. For example GS front wheel is 4.5 kg heavier than my DRZ 400 front wheel.
Old 12-26-2012, 04:35 AM   #7
Prutser
Prutser's Avatar
Oddometer: 1,006
R80 G/S Final drive 7,6 KG Swing arm with drive shaft 5 KG Wheel (no tire) 6,1
R100GS Final drive 8,5 KG Swing arm with drive shaft 3,9KG Wheel no tire 6,6
R1100GS Final drive 8,9KG Swing arm with drive shaft 6,1KG Wheel no tire 6,6 (no disc)
Just some rough measurements.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 12-26-2012, 11:36 AM   #8
supershaft
because I can
Oddometer: 9,116
Well, the Para is some ounces lighter. Where the weight is at might be more important in this case?
@PP: BMW and some of their heavy wheels!!!!! The old K bike/Mono wheels weight a ton! NOT the place to be adding ounces let alone pounds!
Old 12-26-2012, 11:56 AM   #9
Phreaky Phil OP
Oddometer: 1,838
Thanks for this, exactly what I was looking for.
So the G/S Mono =18.7
GS Para = 19
1100 GS Para =21.6 plus disc/caliper etc
I did some measurements when I added the disc to mine and knew I added a couple of kgs.
An extended mono would back to the same weight as the paralever but capable of more travel and stronger.
Old 12-26-2012, 12:02 PM   #10
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
I have different numbers for this:
Rear End Comparison:
I also got curious about the conversion to the R1100GS rear end and wondered what it would weigh compared to a monolever rear end:
R1100GS
final drive 16.7
paralever rod 1.3
swingarm 7.8
drive shaft 5.2
rear wheel 14.7
disc 2.0
caliper 1.8
shock 10.0
59.5 lbs total
R100GS or GSPD
rear wheel 14.2
swingarm w/ all bearings, pins, lower boot 6.2
tie rod 1.0
driveshaft 4.4
final drive 17.8
brake shoes, cam, lever 1.9
shock 8.4
53.9 total
R80ST
swingarm w/ bearings and pivot pins 7.3 lbs
driveshaft 3.9
final drive 16.2
rear wheel 13.0
brake pads, cam, lever 1.4
shock 6.3
48.1 total
HP2 just for curiosity's sake
final drive 17.4
swingarm 9.6
paralever tie rod .9
rear wheel 11.3
driveshaft 4.8
rear disc 2.1
rear caliper 2.1
shock 4.9 (I find that very hard to believe)
53.1 lbs total
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-26-2012, 12:41 PM   #11
Padmei
enamoured
Oddometer: 3,681
Hmmmmm Phils swapping out his swingarm... is there a queue for it yet?
Padmei is offline   Reply With Quote
Old 12-26-2012, 12:57 PM   #12
supershaft
because I can
Oddometer: 9,116
Of course I don't know for sure but I suspect the weight of the FD is what matters most.
Old 12-26-2012, 01:06 PM   #13
Phreaky Phil OP
Oddometer: 1,838
Phils just planning at the moment. Having said that I have purchased 2 monolever swingarms off trademe. Just because they were there
Old 12-26-2012, 01:24 PM   #14
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
...and the wheel
Old 12-26-2012, 01:29 PM   #15
supershaft
because I can
Oddometer: 9,116
Originally Posted by Airhead Wrangler View Post
...and the wheel
+ 1 Mcmillion! The wheels make ALL the difference in the world! BTDT! Unfortunately only on customer's bikes. :(
supershaft screwed with this post 12-26-2012 at 01:36 PM
Times are GMT -7.   It's 09:10 AM.
