Old 12-26-2012, 08:46 AM   #1
Roll-sen OP
Hater be Hatin'
Roll-sen's Avatar
Oddometer: 133
Moly additive for trans and FD- is this product OK?
I came across a bottle of this 'Schaeffers Moly EP Oil Treatment' in my dad's garage. Obviously this is meant to be an engine additive, but would it be suitable to add to trans and FD in place of the regular moly paste that many of you use?
http://www.schaefferoil.com/engine-oil-treatment.html
MSDS here:http://www.schaefferoil.com/cmss_fil...y/MSDS/132.pdf
Roll-sen is offline   Reply With Quote
Old 12-26-2012, 08:50 AM   #2
Multiplicity
Oddometer: 172
The Moly paste is used on the driveshaft splines and the clutch output shaft. Don't add anything else to the FD or trans.
The GL5 Hypoid gear oil is all you need.
Multiplicity is offline   Reply With Quote
Old 12-26-2012, 09:40 AM   #3
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,628
Guard Dog offers moly-based additives as well, might be worth checking out if that's what you're after.
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 12-26-2012, 06:13 PM   #4
vintagerider
vintagerider's Avatar
Oddometer: 1,972
If you do not trust your refiner to use quality stocks and balanced additive package then either switch refiners or get a lubrication engineering degree so that you can build your own lubricant from scratch. Forget trying to "improve" formulated lubricants by using the shake and bake method.
Some people think that buying 91-92 octane fuel is a waste of money. They add mothballs to the tank. These folks enjoy close relationships and quantity discounts with the best machine shop and tank re-liners in the county.
for sale: 1968 R 69 S-us original condition
vintagerider is offline   Reply With Quote
Old 12-27-2012, 02:22 PM   #5
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,987
Could not agree more.
bemiiten is online now   Reply With Quote
Old 12-27-2012, 02:54 PM   #6
EddieMac
EddieMac's Avatar
Oddometer: 85
A friend of mine is a Schaffer oil rep. I recently emailed him the engine oil specs for my oil-cooled boxer and what Schaffer can offer. He sent this reply:
Schaeffer's chief chemist Larry [redacted] confirmed that Schaeffer motor oil (with moly) can be used in your BMW motorcycle. The two oils which would be suitable are:
a. 705 Supreme 7000 Synthetic Blend 20W-50 Racing Oil. This oil has moly, Penetro, and extra zinc in it. I stock this and a 12 qt case is $66.24.
OR
b. 9001 Supreme 9000 Full Synthetic 5W-50 Racking Oil (also with moly, Penetro, and extra zinc). A 12 qt case is $68.64. I do no stock this one but could get a case for you for your next visit into town.
2001 F650GS
2010 F650GS
2012 R1200GS Rallye
EddieMac is offline   Reply With Quote
Old 12-27-2012, 03:13 PM   #7
holckster
dougholck
Oddometer: 863
OR
OP was inquiring about Trans and FD additives.
I switched years ago to Redline Heavy Shockproof Gear Oil in trans of my LT and GSA and feel it shifts cleaner/smoother.
I use Liqui/Moly 75W-90 Racing Gear Oil in FD's
LT has 95K w/origional FD.
GSA FD failed at 56K now at 88K.
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster is offline   Reply With Quote
Old 12-27-2012, 04:24 PM   #8
Roll-sen OP
Hater be Hatin'
Roll-sen's Avatar
Oddometer: 133
I know A LOT of inmates here add moly to their trans or FD. Wasn't looking to open a discussion about the suitability or usefulness of doing so, just asking if this specific product would be acceptable for that specific use.
Thanks everyone for reading and replying.
Old 12-27-2012, 06:51 PM   #9
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,613
I would not use an additive in your gear oil unless it is specific for use in gear systems. The product you describe is not.
def is offline   Reply With Quote
Old 12-27-2012, 07:59 PM   #10
Lensgrinder
Oddometer: 1,326
+1
I just added Guard Dog moly for gear oil to my transmission, it shifts much smoother now.
Comparing a moly additive which is designed for gear oil to adding mothballs to gasoline, which they are NOT designed for is not a valid comparison.
BMW had added moly to the gear oil when the bike was new, so I see no problem with it.
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is offline   Reply With Quote
Old 12-27-2012, 09:46 PM   #11
Multiplicity
Oddometer: 172
Originally Posted by Lensgrinder View Post
+1
Yes, if you feel it's necessary and as long as it's designed for the intended use.
The OP had something for engine oil, not trans or FD.
Old 12-27-2012, 11:00 PM   #12
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,190
Well Said!
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 12-28-2012, 11:20 AM   #13
def
def's Avatar
Oddometer: 10,613
+1
Gear oils come in a variety of brands which seem to provide a variety of performances, even the API rated GL-5 specified for our gear systems.
They come in green, red, purple and amber with various odors and viscosities. Most contain EP additives, corrosion inhibitors, buffers, anti-foaming agents, additives for anti-slip differentials, seal conditioners and claim other redeeming properties.
Many of these oils do not improve shifting to any appreciable extent especially in a new gearbox hence the reason many GSers add some moly (MoS2 or molybdenum disulfide) to their transmission and final drive gear lube. I did so at early miles and shifting improved within several miles of riding.
Guard Dog furnishes moly gear oil additive in quantities that are sensible for motorcycle applications so you don't have to buy a drum or pail of the stuff.
Don't use mothballs for anything except killing moths.
Old 12-28-2012, 04:39 PM   #14
EddieMac
EddieMac's Avatar
Oddometer: 85
You're not the boss of me!
2001 F650GS
2010 F650GS
2012 R1200GS Rallye
Old 12-28-2012, 04:58 PM   #15
def
def's Avatar
Oddometer: 10,613
You're right. Use them wherever you see fit.
Times are GMT -7.   It's 06:55 PM.
