Old 12-27-2012, 12:55 PM   #1
mada OP
Oddometer: 71
KTM LC4 metal shavings...any ideas?
Changed oil today and found this on the magnetic oil plug (nothing in the oil screen).
Bike has 42500 km on it and got new piston, main bearings etc at 30 000km.
Starter clutch fixed 2500 km's ago (new spring only, looked fine otherwise).
Bike starts, sounds and runs great.
Any ideas on where the pieces are comming from?
mada is offline   Reply With Quote
Old 12-27-2012, 01:09 PM   #2
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,537
Shot cam roller bearing?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 12-27-2012, 01:37 PM   #3
dnrobertson
Big Bike, Slow Rider
Oddometer: 839
First thing I would check. Especially if you have never replaced the inlet.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 12-28-2012, 01:27 AM   #4
mada OP
Oddometer: 71
Thanks, is this the bearing you refer to:
0625060040 (23 in link below)
http://ktmshop.se/index.php?parts=y&...8584360_088170
UPDATE:
Checked papers from 30 000km rebuild and the above bearing was replaced then, same with bearing # 25.
In addition to these the following were replaced:
Piston
Main bearings
Conrod repair kit
Cam chain
mada screwed with this post 12-28-2012 at 02:38 AM
Old 12-28-2012, 04:07 AM   #5
Droptarotter
Oddometer: 1,296
Nope;
#14 & #15 in this link;
http://173.74.246.25/munnracing/cata...40%20ADVENTURE
But I would also replace both the cam bearings and rebuild the waterpump while in there.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 12-28-2012, 08:12 PM   #6
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,301
These pieces do not look like they came from the cam roller bearings... If it was the cam roller you should see some small pin like needle fragments on your pickup magnet...
Is this piece magnetic/was it stuck to the magnet? It almost looks like a piece of the clutch basket but the clutch basket is not magnetic...
It looks to be about 10mm wide, maybe it is the locking tab off the clutch nut retaining washer...
You picture is not large enough to pick out the full detail, was this the only solid chunk or is there more? It is not unusual and quite normal to have a bunch of magnetic fluff stuck to the drain plug magnet but a chunk like you found would have me pulling the side cover first to look at the clutch...
What year is the engine?
gunnerbuck is online now   Reply With Quote
Old 12-29-2012, 12:26 AM   #7
MORT666
MORT666's Avatar
Oddometer: 214
Clutch bearing is a problem on them.It may be worth checking.
MORT666 is offline   Reply With Quote
Old 12-29-2012, 02:34 AM   #8
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,301
That's why I asked the year, the pre 03 engines used a ball bearing on the mainshaft which tended to go south prematurely... The fix was to install the roller from the 03 + models... The actual clutch freewheel bearing rarely has issues...
Old 12-29-2012, 06:35 AM   #9
mada OP
Oddometer: 71
The bike is a 98 adventure.
The pieces were stuck on the magnetic plug and there was quite alot of them...
mada screwed with this post 12-29-2012 at 07:34 AM
Old 12-29-2012, 08:22 AM   #10
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,301
In this picture the metal pieces do look somewhat like bearing cage debris..
I would recommend you pull the left sidecover, the clutch and visually inspect the bearings in the left side case half, especially the main shaft bearing as the 98s were equipped with the problematic ball style bearing ...
gunnerbuck screwed with this post 12-29-2012 at 10:38 AM
Old 12-29-2012, 08:50 AM   #11
Droptarotter
Oddometer: 1,296
Yep, sure looks like bearing cage........and more likely lower end/trans/clutch parts.
Keep us posted
Old 12-30-2012, 07:29 AM   #12
mada OP
Oddometer: 71
Were just about to pull the top end when you steered me towards the clutch, turns out a piece of the lock washer has broken and also made some marks on the hub.
Now I just need to figure out how to loosen the nut to replace the lock washer...
Btw, what ball bearing are you referring to? Main bearing or other?
And thanks for all replies...
Old 12-30-2012, 07:51 AM   #13
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,422
easiest way to remove the nut is with a impact wrench. you will need to have all the clutch plates in and put the bike in gear, then hit it with the impact. it will spin right off.
the bearing you are looking for is behind the clutch hub, on the main shaft.
the big question i have is, how did the lock washer get busted? something is not right...
good luck,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is online now   Reply With Quote
Old 12-30-2012, 08:13 AM   #14
Tseta
Lost
Tseta's Avatar
Oddometer: 674
In the pic above, the pressure plate is off, but the push rod assembly (or some part of it) is still there. Not a very typical disassembly, the pushrod normally comes out with the pressure plate and does not really need to be disassembled from the pressure plate itself? Something really does not sound right...
-T
Tseta is offline   Reply With Quote
Old 12-30-2012, 11:03 AM   #15
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,301
After you remove the clutch and do the bearing inspection, I would recommend that you take both oil pumps apart and inspect the inner workings... The magnet, screen/magnet on the drain plugs are designed to catch particles before they migrate into the pumps but when a lot of debris is present some will make it past... When metal particles get it into the pump it may score up the pump rotor enough to reduce the oil pressure and cause further damage down stream {piston, conrod, gearbox} if left too long...
Times are GMT -7.   It's 08:04 PM.
