Old 12-27-2012, 07:47 PM   #1
Spitfire151 OP
Oddometer: 27
Minor engine cover damage
So I took off the starter clutch cover on my 1981 KZ440B, it being my first time, I was overly cautious until I got too confident. What I damaged was an opening for a case bolt. Just the crest of the circle snapped off and the bolt can still do in but I've got a little chunk missing. I'm working out of a cold shed so the metal wasn't too forgiving, nor was my ignorance. What kind of epoxy can I use to fix this?
I've heard Loctite Quick Metal would work... thoughts? -Yes 'be more careful next time!'
I just got a jack for the holiday so it will go up on that so I can work on it easier.
Spitfire151 is offline   Reply With Quote
Old 12-27-2012, 08:19 PM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,550
Post a pic
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 12-27-2012, 08:23 PM   #3
ragtoplvr
Oddometer: 6,048
If the bolt goes in you may not need to fix it at all. The epoxies will set up VERY slowly in an unheated shed. As stated, a picture will help a lot.
Rod
ragtoplvr is offline   Reply With Quote
Old 01-01-2013, 02:28 PM   #4
Spitfire151 OP
Oddometer: 27
Here's a pic:
Old 01-01-2013, 02:36 PM   #5
markjenn
Oddometer: 10,393
Most would just let this ride. Mechanically, there is still plenty of material to bear the torque of the bolt and this is not a mission-critical spot anyway.
If the cosmetics bother you, I'd try some steel epoxy. You could get it welded and then ground/filed to match, but that would probably be overkill on a bike like this and the repair would require some serious refinishing work not to be noticeable.
Another option would be to find a spare at a breaker's yard.
- Mark
Old 01-02-2013, 07:49 PM   #6
Spitfire151 OP
Oddometer: 27
Thanks for all of the help, I'll try the epoxy while searching for a new one. I'm just concerned for the aesthetics, it bugs me!
Old 01-03-2013, 03:25 PM   #7
Vankaye
n00b on the move
Oddometer: 223
Shit. I'd put some bubble gum in that and get back to riding!
Of course a little bit of JB weld would last longer and would actually match the color better!
Vankaye is offline   Reply With Quote
Old 01-03-2013, 03:51 PM   #8
30Bones
30Bones's Avatar
Oddometer: 4,634
JB weld and once cured drill it out from the backside and file flush with the mating surface the bolt resides on. Do it indoors so it will cure better and I bet even you won't notice it if you take your time. Good luck
30Bones is offline   Reply With Quote
Old 01-03-2013, 04:28 PM   #9
Spitfire151 OP
Oddometer: 27
Haha on the bubble gum! Yea, I realized after I took the pic that "hey I can put this in the kitchen" so inside it goes where it's nice and toasty. I'll submit my progress when it's done/messed up ;).
Old 01-04-2013, 08:16 AM   #10
r77toy
Oddometer: 463
Even if you repair it, every time you get on the bike you'll critique it.
r77toy is offline   Reply With Quote
Old 01-04-2013, 08:37 AM   #11
chambersc
chambersc's Avatar
Oddometer: 370
Run it and hunt for a used one. That shouldnt be a problem as far as leaks or torque on the bolt. But if it bothers you, buy a spare gasket and start searching eBay and salvage yards for another one. When you find it, use your spare gasket and swap it out.
It's no mistake that the word "silent" and the word "listen" contain the same letters.
chambersc is offline   Reply With Quote
Old 01-07-2013, 05:31 PM   #12
Spitfire151 OP
Oddometer: 27
Fixed w/ JB Weld:
The second pic's shadow makes the hole look uneven, the bolt goes in just fine and the head will cover the majority of the discoloration Thanks all!
Old 01-08-2013, 02:35 AM   #13
markjenn
Oddometer: 10,393
You're going to desecrate your KZ440B by putting that hacked up piece of crapola on it? Have you no shame?
Seriously, nice work.
- Mark
Old 01-08-2013, 08:12 AM   #14
30Bones
30Bones's Avatar
Oddometer: 4,634
Very well done.
Old 01-08-2013, 06:41 PM   #15
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,460
I see a KLR in your future
Good job on the repair.
ChromeSux is online now   Reply With Quote
Times are GMT -7.   It's 04:18 PM.
