Old 12-27-2012, 08:22 PM   #1
Two Moto Kiwis OP
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 1,804
Ever Wondered What Your Renazco Seat Looks Like Inside?
So with Maya bein tall and me bein short the plan was to make a bit of middle ground.
I felt guilty opening the seat but I would have to say the build quality is absolutely outstanding.
There are 4 layers, the first is a very nice smooth slim skin, the second is a 10 mm soft top, the third is the soft sitting bit and the forth the main base structure.
In order to presserve the best of the top layers we very carefully parted the layers to expose the base structure then proceeded to cut it with an electric bread knife.
We marked it in 1 inch increments and cut a 0 to 20mm down to 45mm up to 20mm up to 0 bowl for me to sit it, a shave off the sides to narrow it up a bit which also helped standover height.
Results where good, probably spent the better part of 3 hours getting the shape right, will post up some finished pics tomorrow.
Layer immediately under the cover
Next layer
Cushy layer under where you sit
The measurements are ours so nothing to do with the original stuff
Cheers Andi & Ellen...Two Moto Kiwi Grüvers .....somewhere
Two Moto Kiwis Home Page
For More Of Two Moto Kiwis Photos
Two Moto Kiwis screwed with this post 12-28-2012 at 07:54 AM Reason: Asked to remove pics by manufacturer
Two Moto Kiwis is online now   Reply With Quote
Old 12-27-2012, 10:22 PM   #2
modeselector
Common as muck
modeselector's Avatar
Oddometer: 489
Interesting - always wondered what the secret sauce looked like.
modeselector is offline   Reply With Quote
Old 12-27-2012, 10:37 PM   #3
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,404
That's quite a bit more complicated than I thought it would be.
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 12-28-2012, 07:30 AM   #4
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 1,804
Pics removed of construction for commercial reasons.
Finished the new build so will post them shortly anyway.
Cheers Andi
Two Moto Kiwis screwed with this post 12-28-2012 at 07:55 AM
Old 12-28-2012, 07:40 PM   #5
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 1,804
Ok, these are the finished pictures.
We retained the soft top and I shaped it for better standover height being narrower, just thought I would share so any SE riders who are longitudinally challenged may be interested to look.
Along the length
From the left
From the right
Shows the shape including growing a tree out of the middle.
Times are GMT -7.   It's 07:33 PM.
