Old 12-29-2012, 06:29 AM   #1
geotherm OP
geotherm's Avatar
Oddometer: 93
Fuzeblock mounting options
Anyone have any recommendations on where to mount Fuzeblock? It's a bit bulky.
geotherm is offline   Reply With Quote
Old 12-29-2012, 10:19 AM   #2
Z50Pilot
Sparky
Z50Pilot's Avatar
Oddometer: 243
Fuze block location
Since I do not carry the stock tool kit, I mounted my FB on the plastic tray where the tool kit normally goes.
PJ
Never lend a friend your Pacific Coast. Unless you like scratches and want a beer annuity
Z50Pilot is offline   Reply With Quote
Old 12-29-2012, 10:55 AM   #3
johnny80s
johnny80s's Avatar
Oddometer: 262
I did the same. I cut a piece of plexie glass to fit the dip in the tray and mounted my PC-8 to it. I have a spot under it to put extra fuses.
johnny80s is offline   Reply With Quote
Old 12-29-2012, 12:45 PM   #4
kevin g
Oddometer: 118
Alternative Mounting - Not Under Seat
Geotherm,
I mounted mine up in the left front at the back of the beak. There are photos in the thread below that shows the installation. One of the appealing things for me is that one can use the GPS switched power connector that is behind the oil cooler to provide the switched relay drive. The accessory connector for this is about $15.
http://advrider.com/forums/showthread.php?t=812460
kevin g is offline   Reply With Quote
Old 12-29-2012, 01:02 PM   #5
geotherm OP
geotherm's Avatar
Oddometer: 93
Thanks guys. Kevin - your install and creations look awesome!
Old 12-29-2012, 02:18 PM   #6
NoVa Rider
Oddometer: 2,936
http://advrider.com/forums/showthrea...ight=Fuzeblock
NoVa Rider is offline   Reply With Quote
Old 12-29-2012, 02:48 PM   #7
steve_k
steve_k's Avatar
Oddometer: 1,064
That's some impressive stuff Kevin! I work in electronics too and should get off my butt and do some design work like that along with the normal test and repair that I do.
The Fuzeblock is a great device in my opinion and have installed them on my Vespa GTS and G650GS. The only thing I have not liked about them is having the grounds on the opposite side of the box. Would like to have + and - next to each other. I haven't investigated too much, but that's probably to reduce the cost of the PCB by not having to use additional layers.
Originally Posted by kevin g View Post
Geotherm,
steve_k is offline   Reply With Quote
Old 12-29-2012, 04:22 PM   #8
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,024
If you don't mind spending $25, Cyclenutz has a ready-made mounting bracket for placing it on top of the airbox between the diagnostic plug and the trailing edge of the fuel tank.
LINK
That's a pretty handy location.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 12-30-2012, 06:48 AM   #9
geotherm OP
geotherm's Avatar
Oddometer: 93
Thanks Drone. I just pm'd cyclenutz. Exactly what I need.
Times are GMT -7.   It's 02:00 AM.
