Old 01-13-2014, 08:42 AM   #1
Menachem OP
Oddometer: 194
2008 GSA rough idle
So...in late October I had a pre winter service on my bike but they did not stabilize the fuel. I noticed when I was looking over the receipt last week. Bike only has 10k miles on it.
So yesterday I took it out for a short ride and to gas up and put in the StabiliZer. I noticed the bike has a rough idle with the needle bopping around and almost a small tick or something each time the revs picked up.
The 3 miles I ode it all felt good but the rough idle remained after it was warmed up. Can I blame this on 3 month old fuel and just leave it till spring?
08 BMW R 1200 GSA
07 Ducati 1098s
06 Ducati 749R...track only
06 DRZ 470 supertard
Menachem is offline   Reply With Quote
Old 01-13-2014, 08:46 AM   #2
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,289
Old gas, Dump some Techron in and ride it, it'll smooth out.
Adding Sta-bil now won't help a bit, it's too late for that unless you plan on letting it sit for a while longer.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 01-13-2014, 09:28 AM   #3
Menachem OP
Oddometer: 194
It's pretty salty out here and wet from melting snow do I won't ride much for a while.
I put 5 gallons of fresh gas yesterday so at least the stabil will hold that over.
I've already had the injectors replaced or cleaned (can't recall what they did) about 3 years ago but that time the bike wouldn't start at all or start and die.....
08 BMW R 1200 GSA
07 Ducati 1098s
Old 01-14-2014, 01:32 AM   #4
asphaltsurfer1
CatManDoo
asphaltsurfer1's Avatar
Oddometer: 125
my 08 started doing the same thing a few months ago. I ride a lot 40K plus on it and been through several tanks plus injector cleaner. I suspect maybe a coil or plug gone bad but haven't had time to confirm yet
asphaltsurfer1 is offline   Reply With Quote
Old 01-14-2014, 02:38 PM   #5
roadtrip22
roadtrip22's Avatar
Oddometer: 332
Fresh Gas and I'd go ahead and adjust the throttles. Maybe add some Fuel and injector cleaner too to help clear things up. Run about 2 tanks and be sure to get on the highway and get those RPM's up to clean things out.
Follow me on Facebook--- http://www.facebook.com/2wheeladventures
100 things all GS owners should read---http://advrider.com/forums/showthread.php?t=836736
Repair and Maintenance DVD's--- http://www.jimvonbaden.com/
roadtrip22 is offline   Reply With Quote
Times are GMT -7.   It's 10:03 AM.
