Old 12-30-2012, 06:19 PM   #1
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,441
Pardon me for my ignorance... front suspension question
Guys, simple stupid question here. If I remove my front shock/spring assembly, what happens to the front wheel? Is there a stop to keep it from dropping to the floor (doesn't have far to go of course) or what?
Reason I'm asking (this will help you answer me) is I will get my Ohlins front shock rebuilt this winter, but the bike will sit in my Korean parking garage. Everything needs to look "usable" not like a garage. My idea is that I'll remove the assembly and just leave the bike sitting on the center stand while I have the shock rebuilt (probably 3-4 weeks turnaround).
I suppose once concern is the random "someone sitting on my bike" thing and surprise, the front wheel gives no support! I doubt this is an issue though, Koreans seem to leave other people's stuff alone very well.
Any precautions I need to take?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 12-30-2012, 06:33 PM   #2
rdwalker
Oddometer: 2,541
I believe it will be unstable. I changed the shock on a few Telelever bikes, but never gave a thought what happens when I am not supervising... As I recall, I had to support the machines the same way as when removing front wheel.
However: how about a bike cover? Even a tarpaulin, if dedicated covers are expen$ive in Korea? If they let you cover a bike in your location, this may be the best choice, the bike looks uninviting.
Happy New Year!
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is online now   Reply With Quote
Old 12-30-2012, 06:41 PM   #3
SourKraut
Oddometer: 7,211
On the centerstand with no front shock it will look normal but with both tires on the ground. If someone takes it off the centerstand with no shock the bike will contact the ground, probably damage some bushings/seals in the forks and be waaaaaay difficult to get back on the centerstand without a strong helper. After shock removal, reinstall the front tire and strap the front wheel to the centerstand tightly. Then it can't be taken off the centerstand and will look completely normal but if you can, put a spacer between the front wheel and lower fork brace, then nobody can screw it up unless they mean it.
SourKraut is offline   Reply With Quote
Old 12-30-2012, 06:55 PM   #4
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,343
Originally Posted by sourkraut View Post
on the centerstand with no front shock it will look normal but with both tires on the ground. If someone takes it off the centerstand with no shock the bike will contact the ground, probably damage some bushings/seals in the forks and be waaaaaay difficult to get back on the centerstand without a strong helper. After shock removal, reinstall the front tire and strap the front wheel to the centerstand tightly. Then it can't be taken off the centerstand and will look completely normal but if you can, put a spacer between the front wheel and lower fork brace, then nobody can screw it up unless they mean it.
+1
joenuclear is offline   Reply With Quote
Old 12-30-2012, 06:57 PM   #5
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 12,123
Do you have a drill? Could you get a length of water pipe, about the same length of the shock and just drill a couple of holes through it? Put that strut in there after you pull the shock and everything should be safe.
Donkey Hotey is offline   Reply With Quote
Old 12-30-2012, 08:26 PM   #6
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,441
Isn't one end of the shock (we are talking front here) or both just the pin? I can't quite picture it in my head, and I've never had to take it out. That would be harder to replicate with a water pipe.
As a positive note, I've found out there's an Ohlins guy in Seoul, but I'm wary of the prices. We'll see if I get it done locally (much faster) or in the US (slower due to shipping). In this case speed is not just a convenience, but also a safety factor with the bike sitting in the stall.
Side note-I intentionally have the bike sitting with the bars locked to the side and on the centerstand (and bags on) knowing full well that if someone plays with it, it will hit the ground immediately. It never moves. I think in the US it would already be on it's side.
Old 12-30-2012, 09:27 PM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,341
What year? 05-06 tend to weight the front wheel. 07+ weight the rear wheel.
See this: http://www.jimvonbaden.com/Ohlins_Shock_Install.html
Jim
Old 12-30-2012, 09:37 PM   #8
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,441
'06 and yes, the front wheel is weighted, the more I think about it. I'm going to need a block or pipe or something...
Good reference, Jim!
Old 12-30-2012, 10:56 PM   #9
vagueout
vagueout's Avatar
Oddometer: 1,718
Been there done that. Bike on centre stand and place a block or crate etc under the front of the eng bash plate.
i just seek clarity
vagueout is offline   Reply With Quote
Old 12-30-2012, 11:15 PM   #10
Donkey Hotey
De Jo Momma
Oddometer: 12,123
There's a used shock on Ebay for $59. Or see if somebody will sell you a known-bad shock?
Or a drilled pipe like I suggested earlier, with a bolt dropped through the upper hole, well down into the pipe (like 4" worth)? It wouldn't come dislodged unless the fork dropped down far enough for the bolt to come out. The pipe would attach to the bottom and not go anywhere.
Old 12-31-2012, 05:02 AM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 53,341
This works fine, unless you are leaving it long term and have kids or pets. For me it has always been fine.
Jim
Old 12-31-2012, 05:06 AM   #12
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,441
Thanks guys...
And now (jokingly, but true) I shall root around my neighborhood for a block of "something" about the height of my skidplate.
I do have a cover, and can choose what part of the parking garage I put it, so I might try to find a more secluded area (right now it is about 20' from the elevator).
Old 12-31-2012, 05:10 AM   #13
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,470
If you have bags or a tob box, put a bit of weight in there so the rear tire will be touching down when on the center stand. The forks will keep the front rigid while the shock is out, but won't hold too much weight.
2004 R1150GSA, 2000 BMW R1150GS, 2008 KTM 950R SE, 2001 Honda XR400R, 2003 Honda XR100R
Another Proud Small Scale Faker......
New England Pie-O-Rama
ADV Pie Map
AndyCap is offline   Reply With Quote
Old 12-31-2012, 10:10 AM   #14
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
SR1,
I believe a simple fix for your situation would be to just cut a piece of wood, say 2"x2" {50mm x 50mm or so} and sut it about the length of your shock, not counting the stem bolt on the top. Push the piece up into the steering neck shock pocket, and the other end just set it on top of the trailing arm {telelever arm} above where the lower shock would mount. Use it basically as a spacer....then put a tie down up and over the steering neck and down to the trailing arm. Tighten the tie down {ratchet tie would be best} this will hold the block of wood tight, and keep the space correct.
With this system you could even take it off of the center stand and move it around on the wheels if you had too.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 12-31-2012, 10:17 AM   #15
JimVonBaden
"Cool" Aid!
Oddometer: 53,341
Originally Posted by kellymac530 View Post
SR1,
Not a bad idea. Even a length of broom handle would work.
I've done this more than once:
Jim
Times are GMT -7.   It's 12:22 PM.
