Old 12-30-2012, 07:39 PM   #1
h2only OP
Oddometer: 31
Where to buy body panel
I own a 2011 F800gs and yesterday I broke my left rear lateral panel (the one that covers the gas tank) into about 6 pieces. Any recommendations of a good place online to order a new one from?
TIA
h2only is offline   Reply With Quote
Old 12-30-2012, 08:19 PM   #2
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,080
Uh, I have an orange one oddly enough..... Didn't think anyone would want it so never posted it.
EDIT! Just reread your post, I have the rh gas filler side. Got confused.
What colour tho?
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 12-30-2012, 09:20 PM   #3
h2only OP
Oddometer: 31
What colour tho?
Alpine White
Old 12-31-2012, 06:17 AM   #4
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 266
Max BMW has it
http://www.maxbmwmotorcycles.com/fic...8&rnd=08102012
Angryrican is offline   Reply With Quote
Old 12-31-2012, 06:43 AM   #5
runnin4melife
Oddometer: 803
Any BMW dealership will have access to them, the issue is that you will pay ~$180 for it. I scoured ebay last night and couldn't find anything you needed as well as the parts section on advrider.
If you have the pieces you can use a a plastic repair kit and get them together (only do one piece at a time to ensure good placement) and then run a layer or two of fiberglass or CF underneath or a mesh backing with resin to reinforce the piece. You will have to sand it and repaint but this will be the cheapest method if you cannot source a new/used piece. As this is not a structural piece a cosmetic fix like this will work just fine.
runnin4melife is offline   Reply With Quote
Old 12-31-2012, 07:01 AM   #6
runnin4melife
Oddometer: 803
$169 -> http://www.2wheelpros.com/oem-parts/...-assembly.html
Old 12-31-2012, 09:08 AM   #7
h2only OP
Oddometer: 31
thanks everyone, I searched the web for a while and only found MaxBMW initially, I will check the other sites listed.
I wish I could say it broke from tearing up some singletrack, but alas, I was loading my CRF450x into the truck and the driveway was covered with ice. I needed to pull my truck forward a little into the garage to have a patch of dry cement to load the honda into the truck. Well, it was very early and I was very tired and hit the back of the bmw, and watched it slowly fall of it's center stand. It landed on the snowblower right in the place where there are no guards on the BMW and it broke.
Times are GMT -7.   It's 10:28 AM.
