Old 12-31-2012, 08:19 AM   #16
JRP
Old guy
JRP's Avatar
Oddometer: 1,537
Originally Posted by LaurelPerryOnLand View Post
You run the hot wire through a slotted bolt, then a nut secures it. The wire you want to electrify goes into the nut then is secured with another
nut. There is a picture on that website. The tapped wire only ends up with a very small hole in the insulation.
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 12-31-2012, 08:20 AM   #17
rdwalker
Oddometer: 2,545
I don't know, it looks to me like a more expensive version of the Scotchlock taps, prone to loosening, corrosion and contact resistance.
I always strip a short, quarter-inch section of tapped wire, wrap the tapping wire around and solder the junction. Yes, it takes a bit more time - but now it is off-season anyway, no? Time for bike farkling.
I have had my share of IDC (insulation displacement connector) failures. OTOH, I have never had a solder splice fail on me, even if sloppily made. And you would not believe the amount of add-on wiring on my bikes - I am a hopeless gadget freak. Good connections are a must.
Robert.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT, '01 F650GS
-->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour
-->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour
rdwalker is online now   Reply With Quote
Old 12-31-2012, 08:49 AM   #18
Stinkyb
GS"eh" rider
Stinkyb's Avatar
Oddometer: 360
Posi taps look very practical in that they are very invasive. I would stick apply electrical tape around to secured the nut( that motorbike/hockey tape...ya know what I mean)
"Dear MCGuyver enclosed is a paperclip an elastic band and a toothpick, please save my dog"
Stinkyb is offline   Reply With Quote
Old 12-31-2012, 10:07 AM   #19
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,498
Originally Posted by JRP View Post
Just a note, if you use a Positap you won't have to cut or solder any wires.
http://www.posi-lock.com/posiplug.html
, and do it on the parking lamp or the running lamp for the tail light.
Jim
Old 12-31-2012, 10:09 AM   #20
JimVonBaden
"Cool" Aid!
Oddometer: 54,498
Robert.
I have used them extensively. They seal themselves with the tip of the pin penetrating the insulation, and are much less likely to damage the original wire. When removed they leave a pinhole sized hole, and do not cut any strands of wire like a schotchlock.
Jim
Old 12-31-2012, 10:44 AM   #21
rdwalker
Oddometer: 2,545
Jim
Does sound better than Scotchlock, then.
Old 12-31-2012, 11:02 AM   #22
geotherm OP
geotherm's Avatar
Oddometer: 95
when using the tailight as 'turn on', should I tap into wire at plug right before bulb? Also, do I need to have voltmeter out to make sure which wire is positive? Or, is one color always the 'hot'?
geotherm is offline   Reply With Quote
Old 12-31-2012, 11:11 AM   #23
JRP
Old guy
JRP's Avatar
Oddometer: 1,537
A voltmeter would be a good idea. You can tap into the wire at any point. I don't have my 1150 anymore but I believe all the grounds are brown so you wouldn't want one of those.
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP screwed with this post 12-31-2012 at 11:17 AM
Old 01-01-2013, 02:45 AM   #24
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,796
Originally Posted by TuefelHunden View Post
Somewhere on here is a post by JVB, maybe about fuze blocks that says to use blue/green wire in diagnostic plug for the trigger. I used it with no problems. Easy to find, close to my fuseblock, easy to tap.
This is the wire I use for my switched power relays, it won't be live until the idiot light on the dash is off.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 01-01-2013, 02:52 AM   #25
Twilight Error
Oddometer: 22,796
Tap into it somewhere you can reach and easily work on, should you have to. Tapping into a tail light wire near a socket won't make a measurable difference in volts/current going to the relay, so why force yourself to work in the tiny space with very little wire slack and no chances to correct an error?
Old 01-01-2013, 06:16 AM   #26
geotherm OP
geotherm's Avatar
Oddometer: 95
Done. I used the tail light and everything works great. I removed factory spade connector at tailight, wired 'turn on' to tail light wire and installed new spade connector. Topped off with shrink tape. I used a posi-tap for tapping into high beam for my overriding dimmer from ADVmonster. Very pleased with the dimmable model 60s.
Times are GMT -7.   It's 09:08 PM.
